bizzard Posted July 9, 2012 Report Share Posted July 9, 2012 There is no mention of diluting oil with diesel in my copy of the LRM/SRM handbook. Sounds a bad idea to me. Page 16 in mine.1966. Book 1029/766.Orangey colour. Price 10/- . Link to comment Share on other sites More sharing options...
The Bagdad Boatman (waits) Posted July 9, 2012 Report Share Posted July 9, 2012 With older engines it was common to blow injector pipes as they got worn, putting on new pipes was a normal procedure if it constantly blew pipes then replacing the injectors because the seats where knackered cured the problem. Link to comment Share on other sites More sharing options...
Narrowboat Communicator Posted July 9, 2012 Author Report Share Posted July 9, 2012 looks like I'm going to order a new injector pipe. If it starts leaking again I'll just change it. Link to comment Share on other sites More sharing options...
tedy Posted August 10, 2012 Report Share Posted August 10, 2012 Hello ,The classic diesel leak on th the Lister range of enclosed fuel pumps I have worked on over the years is the delivery valve holder thats the union in the top of the fuel pump, they can lead you a merry dance , they tend to leak with the changes in temperature,just make sure they are good and tight !. Link to comment Share on other sites More sharing options...
Lord Belvoir Posted March 11, 2020 Report Share Posted March 11, 2020 (edited) Just a update on this post....I know it's been a while but I am the new owner of this boat.....reasons for diesel in the oil....piston rings knackered,barrel bores at .061,lift pump diaphragm split, injectors assembled incorrectly, fuel lines bodged,steel washers where there should be copper washers, infact so many cowboy bodges too many to list but theres just a few to get on with .....barrels have been replaced back to standard new pistons and rings a complete overall of the diesel fuel system+lift pump....oh not to mention that many cat hairs around the cooling fan and fins I could have built a tiger!!!!!....now alls good? Edited March 11, 2020 by Lord Belvoir 1 Link to comment Share on other sites More sharing options...
alan_fincher Posted March 11, 2020 Report Share Posted March 11, 2020 7 hours ago, Lord Belvoir said: Just a update on this post....I know it's been a while but I am the new owner of this boat.....reasons for diesel in the oil....piston rings knackered,barrel bores at .061,lift pump diaphragm split, injectors assembled incorrectly, fuel lines bodged,steel washers where there should be copper washers, infact so many cowboy bodges too many to list but theres just a few to get on with .....barrels have been replaced back to standard new pistons and rings a complete overall of the diesel fuel system+lift pump....oh not to mention that many cat hairs around the cooling fan and fins I could have built a tiger!!!!!....now alls good? You did well no find standard sized new bores, piston and rins. For both the HAs I have had rebuilt in recent years my restorer used oversized ones because that was all he could source at the time. Or more accurately I could have had Indian made parts in a standard size, but wanted to avoid non English parts due to reported problems with the former. Good engines when in good order, and still seem to often manage to keep going when they are not! Link to comment Share on other sites More sharing options...
