David Schweizer Posted April 1, 2012 Report Share Posted April 1, 2012 I am about to fit a couple of TV Coaxial sockets on the boat and have noticed that some seem to have a small resistor in the signal line, whilst others are wired direct. Does anyone know what the function of the resistor is, and as some sockets do not have one how important is it? Link to comment Share on other sites More sharing options...
Guest Posted April 1, 2012 Report Share Posted April 1, 2012 I am about to fit a couple of TV Coaxial sockets on the boat and have noticed that some seem to have a small resistor in the signal line, whilst others are wired direct. Does anyone know what the function of the resistor is, and as some sockets do not have one how important is it? Possibly to attenuate the signal if being used in a very strong signal area?? I've fitted loads of these over the years at home and in caravans and TBH I've never encountered one with a resistor in and never noticed any adverse affects by fitting one without. Link to comment Share on other sites More sharing options...
bizzard Posted April 1, 2012 Report Share Posted April 1, 2012 One might have trouble plugging something into a socket that resists too. Link to comment Share on other sites More sharing options...
Nickhlx Posted April 1, 2012 Report Share Posted April 1, 2012 One might have trouble plugging something into a socket that resists too. It might be an inductor - to act as some sort of interference filter... some look like resistors Nick Link to comment Share on other sites More sharing options...
bizzard Posted April 1, 2012 Report Share Posted April 1, 2012 (edited) It might be an inductor - to act as some sort of interference filter... some look like resistors Nick It might even have a seducer which would try to lure you to plug a plug into it. Ps Most sockets being of the female type like. Edited April 1, 2012 by bizzard Link to comment Share on other sites More sharing options...
Nickhlx Posted April 1, 2012 Report Share Posted April 1, 2012 It might even have a seducer which would try to lure you to plug a plug into it. Ps Most sockets being of the female type like. Inductors induce ! Nick Link to comment Share on other sites More sharing options...
bizzard Posted April 1, 2012 Report Share Posted April 1, 2012 Inductors induce ! Nick Right you are. A Sinductor then. Link to comment Share on other sites More sharing options...
David Schweizer Posted April 1, 2012 Author Report Share Posted April 1, 2012 (edited) Right you are. A Sinductor then. Why do you seem to be determined to derail this thread Bizzard? Has no one told you that repeating the same old joke does not make it any funnier? Edited April 1, 2012 by David Schweizer Link to comment Share on other sites More sharing options...
by'eck Posted April 1, 2012 Report Share Posted April 1, 2012 I am about to fit a couple of TV Coaxial sockets on the boat and have noticed that some seem to have a small resistor in the signal line, whilst others are wired direct. Does anyone know what the function of the resistor is, and as some sockets do not have one how important is it? Splitters have resistors in to maintain the correct 75Ω impedance match to connected devices and so that one device doesn't affect the other. Link to comment Share on other sites More sharing options...
Arthur Brown Posted April 1, 2012 Report Share Posted April 1, 2012 The aerial downlead is a transmission line, and signal arriving at a cut end is reflected back along the line. If you have one aerial feeding one socket it matters not, but if you have one aerial feeding several sockets by T junctions the reflected wave will re-enter the aerial cable and arrive at other sockets at a different time from the direct signal. This will impair the TV performance and may give ghosting effects, or may just make finding the right station harder. Other failure modes will happen in the digital domain. The resistor absorbs the energy that would have been reflected. Link to comment Share on other sites More sharing options...
alan_fincher Posted April 1, 2012 Report Share Posted April 1, 2012 The aerial downlead is a transmission line, and signal arriving at a cut end is reflected back along the line. If you have one aerial feeding one socket it matters not, but if you have one aerial feeding several sockets by T junctions the reflected wave will re-enter the aerial cable and arrive at other sockets at a different time from the direct signal. This will impair the TV performance and may give ghosting effects, or may just make finding the right station harder. Other failure modes will happen in the digital domain. The resistor absorbs the energy that would have been reflected. I haven't read the other obvious (just from the thread title) April 1st threads, but this single post certainly rates as "nice try" ! Link to comment Share on other sites More sharing options...
David Mack Posted April 1, 2012 Report Share Posted April 1, 2012 Splitters have resistors in to maintain the correct 75Ω impedance match to connected devices and so that one device doesn't affect the other. Fibreglass boats have resistors ??? Just finding my coat... David Link to comment Share on other sites More sharing options...
Arthur Brown Posted April 1, 2012 Report Share Posted April 1, 2012 Actually Alan that's a fair explanation of a UHF transmission line. It's long after noon. Link to comment Share on other sites More sharing options...
Semitrad Posted April 2, 2012 Report Share Posted April 2, 2012 I am about to fit a couple of TV Coaxial sockets on the boat and have noticed that some seem to have a small resistor in the signal line, whilst others are wired direct. Does anyone know what the function of the resistor is, and as some sockets do not have one how important is it? These resistors can be used as a DC block, where a masthead amplifier is used and the main cable carries the 12V supply. Link to comment Share on other sites More sharing options...
Nickhlx Posted April 2, 2012 Report Share Posted April 2, 2012 (edited) These resistors can be used as a DC block, where a masthead amplifier is used and the main cable carries the 12V supply. I thought (know) it is capacitors that are able to DC block - resistors just resist DC flow ( and absorb reflection energy) Nick Edited April 2, 2012 by Nickhlx Link to comment Share on other sites More sharing options...
smileypete Posted April 2, 2012 Report Share Posted April 2, 2012 I am about to fit a couple of TV Coaxial sockets on the boat and have noticed that some seem to have a small resistor in the signal line, whilst others are wired direct. Does anyone know what the function of the resistor is, and as some sockets do not have one how important is it? Sure it's a resistor? Why not put a meter on it. cheers, Pete. Link to comment Share on other sites More sharing options...
David Schweizer Posted April 2, 2012 Author Report Share Posted April 2, 2012 Sure it's a resistor? Why not put a meter on it. cheers, Pete. Yes! Link to comment Share on other sites More sharing options...
Keeping Up Posted April 2, 2012 Report Share Posted April 2, 2012 Can you tell the value of the resistor (may be printed on; or if it's got bands of coloured paint showing the value, what are the colours?) The only use I can guess at is possible protection against short-circuit in a system that is fed with 12v dc for an amplifier. Link to comment Share on other sites More sharing options...
David Schweizer Posted April 2, 2012 Author Report Share Posted April 2, 2012 Can you tell the value of the resistor (may be printed on; or if it's got bands of coloured paint showing the value, what are the colours?) The only use I can guess at is possible protection against short-circuit in a system that is fed with 12v dc for an amplifier. The there are three resistors in the socket I am looking at, one each from each input and joined together at the output end which is joined to another one which is connected to the socket centre, They are all the same value - colours red, purple, black, silver. If my memory serves me correctltly that makes them all all 27ohms with a 10% tolerance. Link to comment Share on other sites More sharing options...
Nickhlx Posted April 2, 2012 Report Share Posted April 2, 2012 (edited) The there are three resistors in the socket I am looking at, one each from each input and joined together at the output end which is joined to another one which is connected to the socket centre, They are all the same value - colours red, purple, black, silver. If my memory serves me correctltly that makes them all all 27ohms with a 10% tolerance. (rough) Impedance preserving ? Nick Edited April 2, 2012 by Nickhlx Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2012 Report Share Posted April 2, 2012 Can you tell the value of the resistor (may be printed on; or if it's got bands of coloured paint showing the value, what are the colours?) The only use I can guess at is possible protection against short-circuit in a system that is fed with 12v dc for an amplifier. Aren't they normally in the splitter box though not the co-ax socket?? Link to comment Share on other sites More sharing options...
by'eck Posted April 2, 2012 Report Share Posted April 2, 2012 The there are three resistors in the socket I am looking at, one each from each input and joined together at the output end which is joined to another one which is connected to the socket centre, They are all the same value - colours red, purple, black, silver. If my memory serves me correctltly that makes them all all 27ohms with a 10% tolerance. That confirms it is definitely a two way splitter as per post #9. The three nominally 25Ω resistors (27Ω is nearest common value) should be in a star configuration. This will maintain the correct 75Ω impedance to match each connected device as well as isolating each to prevent reflected signals. It will give around 6dB loss though leaving you with ¼ of the signal. An alternative to this passive device is an active amplifier/splitter. More info here. Link to comment Share on other sites More sharing options...
jelunga Posted April 2, 2012 Report Share Posted April 2, 2012 Possibly to attenuate the signal if being used in a very strong signal area?? I've fitted loads of these over the years at home and in caravans and TBH I've never encountered one with a resistor in and never noticed any adverse affects by fitting one without. I thought resistors would not work as resistors on AC circuits, and a ~TV signal is certainly AC. More likely it is to reduce interference from other ellectical devices Link to comment Share on other sites More sharing options...
Semitrad Posted April 2, 2012 Report Share Posted April 2, 2012 The there are three resistors in the socket I am looking at, one each from each input and joined together at the output end which is joined to another one which is connected to the socket centre, They are all the same value - colours red, purple, black, silver. If my memory serves me correctltly that makes them all all 27ohms with a 10% tolerance. That sounds more like a splitter unit than a simple socket! Link to comment Share on other sites More sharing options...
David Schweizer Posted April 2, 2012 Author Report Share Posted April 2, 2012 That sounds more like a splitter unit than a simple socket! Yes it is, but there is also a resistor in the single socket plate currently on the boat, which is what prompted my original question. Link to comment Share on other sites More sharing options...
