nickc330 Posted March 7, 2012 Report Share Posted March 7, 2012 ive had my engine totally rebuilt but still get diesel in oil any ideas this problem has taken a year of my time and constantly return trips breakdown back to the marina /mechanick ive had lift pumps injector pumps renewed injector would any body care to swap this seamaster 25 for a narrowboat our dream im at a loss with her but will get her running befor i sell or swap im serious my wife doesnt trust her and a women scorned etc so if theres any one out there with a heart and they want a virtually brand new boat some cosmetic work needed shes up for grabs or ideally swap so we can enjoy the canals of briton also brand new is the steering and waterpump so as you can see apart from hull shes in need of tarting up but a finer craft for some one who doesnt want to leave boating but enjoy the comfort of dry boating instead of cold wet boating and with room to enjoy comfort contact me and we can chat but getting back to my other problem please help!!! were at our wits end and want to enjoy a pleasurable cruise with our friends colin and jill not being towed back to the marina yet again Link to comment Share on other sites More sharing options...
Tony Brooks Posted March 7, 2012 Report Share Posted March 7, 2012 ive had my engine totally rebuilt but still get diesel in oil any ideas this problem has taken a year of my time and constantly return trips breakdown back to the marina /mechanick ive had lift pumps injector pumps renewed injector would any body care to swap this seamaster 25 for a narrowboat our dream im at a loss with her but will get her running befor i sell or swap im serious my wife doesnt trust her and a women scorned etc so if theres any one out there with a heart and they want a virtually brand new boat some cosmetic work needed shes up for grabs or ideally swap so we can enjoy the canals of briton also brand new is the steering and waterpump so as you can see apart from hull shes in need of tarting up but a finer craft for some one who doesnt want to leave boating but enjoy the comfort of dry boating instead of cold wet boating and with room to enjoy comfort contact me and we can chat but getting back to my other problem please help!!! were at our wits end and want to enjoy a pleasurable cruise with our friends colin and jill not being towed back to the marina yet again Being a Seamaster I assume its a Perkins 4-10X and if so have you tried it with the flame plug disconnected from the fuel system. Many flame-plugs seem to be pipes from the main fuel system and if it is a leaking flame plug will keep pouring diesel into the manifold. Personally I would fit a tap in the flame plug feed and only turn it on during cold starting (as we used to when they had the little tin bottles to supply the fuel). Link to comment Share on other sites More sharing options...
nickc330 Posted March 7, 2012 Author Report Share Posted March 7, 2012 Being a Seamaster I assume its a Perkins 4-10X and if so have you tried it with the flame plug disconnected from the fuel system. Many flame-plugs seem to be pipes from the main fuel system and if it is a leaking flame plug will keep pouring diesel into the manifold. Personally I would fit a tap in the flame plug feed and only turn it on during cold starting (as we used to when they had the little tin bottles to supply the fuel). hi yes its a 4108 and yes again we disconnected the flame plug feed so its not coming in there were stumped pre engine rebuild it never happened.post rebuild it pours in. Link to comment Share on other sites More sharing options...
soldthehouse Posted March 7, 2012 Report Share Posted March 7, 2012 I had a 4236 on a generator that spewed a large amount of diesel through the seal on the end of the fuel distribution pump shaft where it entered the timing chain chest it filled the sump in no time, probably different on yours but thought it worth a mention Link to comment Share on other sites More sharing options...
Geoff Taylor Posted March 7, 2012 Report Share Posted March 7, 2012 Hi Nick, Discounting the flame start,only 2 more ways fuel can get into your 4108,the seals improperly fitted or worn out on the injector pump and the lift pump letting fuel past the diaphragm. I have a 4108 in my boat and as a diesel engineer in plant,commercial and agricultural equipment have a lot of experience with Perkins engines and nearly all of the fuel dilution problems I have experienced have been 99% lift pump diaphragm failures,I have personally never witnessed a flame start failure,I do have a tap on the reservoir of my engines flamestart system as a failsafe,more so for fuel line failure. It must be very frustrating for you but concentrate on lift pump first,inj pump 2nd.Hope this helps.(you will find your problem). Link to comment Share on other sites More sharing options...
Tony Brooks Posted March 8, 2012 Report Share Posted March 8, 2012 One must now question the competence of whoever overhauled/supplied the "new" injector & lift pump. It just has to be one of those. If this was done by a paid for mechanic I would be demanding to see the invoices and that they put it right FOC. If the items were secondhand, Ebay sourced etc. and self fitted I would be sending them to a diesel equipment specialist for a proper overhaul. It is interesting to note that the incidence of leaking DPA injector pumps seems to be rising now. This is probably due to the seals that had previously swollen because of the sulphur in the fuel now shrinking back to size but are now worn. This applies to DPA and rotary pumps only (BMC 1.x, Perkins 4-10x, Ford XLD, Bukh DV36, Marinised Peugeot diesels). Link to comment Share on other sites More sharing options...
The Bagdad Boatman (waits) Posted March 8, 2012 Report Share Posted March 8, 2012 One possibility is unburnt diesel due to poor condition of rings/bores have you had a compression test done? I replaced liners and pistons on my 4107. Link to comment Share on other sites More sharing options...
Tony Brooks Posted March 8, 2012 Report Share Posted March 8, 2012 One possibility is unburnt diesel due to poor condition of rings/bores have you had a compression test done? I replaced liners and pistons on my 4107. Agreed BUT he says he has had the engine rebuilt. It seems to me that he has picked a "wrong un" to do his work or if he has done it himself has picked the wrong "specialists"/suppliers. Link to comment Share on other sites More sharing options...
GSer Posted March 8, 2012 Report Share Posted March 8, 2012 I wonder if there could have been a spacer between the lift pump and the block, (as there is sometimes) this spacer was mislaid during the rebuild and now the lift pump is over stroking, destroying the diaphram in an instant, a bit far fetched i know, but it is an odd problem and even rare things have to happen to somebody! Link to comment Share on other sites More sharing options...
bizzard Posted March 8, 2012 Report Share Posted March 8, 2012 (edited) I wonder if there could have been a spacer between the lift pump and the block, (as there is sometimes) this spacer was mislaid during the rebuild and now the lift pump is over stroking, destroying the diaphram in an instant, a bit far fetched i know, but it is an odd problem and even rare things have to happen to somebody! It well could have,they are there to act as an insulator,a sort of ''heat sink''especially on petrol engines but also on most diesels to stop the lift pump getting too hot,and if left out the pumps diaphram would be strained as you say.I can't remember on your Perkins engine but it almost certainly should have one.Check in your manual. PS The spacer would be about 1/4'' to 3/8''thick,non metal,a white fibre'y heat froof material. Edited March 8, 2012 by bizzard Link to comment Share on other sites More sharing options...
Tony Brooks Posted March 8, 2012 Report Share Posted March 8, 2012 I wonder if there could have been a spacer between the lift pump and the block, (as there is sometimes) this spacer was mislaid during the rebuild and now the lift pump is over stroking, destroying the diaphram in an instant, a bit far fetched i know, but it is an odd problem and even rare things have to happen to somebody! The manual shows one so its a distinct possibility. Link to comment Share on other sites More sharing options...
Geoff Taylor Posted March 8, 2012 Report Share Posted March 8, 2012 Hi, It is worth noting that whenever an older type injector pump is serviced/reconditioned to make sure Dupont viton seals are fitted as they are designed to cope with low sulphur and bio diesels. Any reputable service agent will fit this type automatically,some will still be using up old stock,so be aware and ask!.I believe that any make of injector pump produced after 1998 is fitted with viton seals as standard. Link to comment Share on other sites More sharing options...
nickc330 Posted March 10, 2012 Author Report Share Posted March 10, 2012 I had a 4236 on a generator that spewed a large amount of diesel through the seal on the end of the fuel distribution pump shaft where it entered the timing chain chest it filled the sump in no time, probably different on yours but thought it worth a mention thanks for replying all ideas worth investigating i feel like sherlock homes Hi, It is worth noting that whenever an older type injector pump is serviced/reconditioned to make sure Dupont viton seals are fitted as they are designed to cope with low sulphur and bio diesels. Any reputable service agent will fit this type automatically,some will still be using up old stock,so be aware and ask!.I believe that any make of injector pump produced after 1998 is fitted with viton seals as standard. thanks ill check that one out ive lost more diesel in sump and over £60.00 oil changes fresh oil etc id rather be cruising The manual shows one so its a distinct possibility. thanks ive informed the mechanic of this and he was going to check this out im desperatly looking on internet ive got a parts book and workshop manual on board but cant get there till next week but this seems a most plausible idea weve had as ive bought a new lift pump and still no change im excited about this and thanks for repling will let you no if indeed it has been the problem all this time. I wonder if there could have been a spacer between the lift pump and the block, (as there is sometimes) this spacer was mislaid during the rebuild and now the lift pump is over stroking, destroying the diaphram in an instant, a bit far fetched i know, but it is an odd problem and even rare things have to happen to somebody! thanks for replying all ideas worth investigating i feel like sherlock homes thanks ill check that one out ive lost more diesel in sump and over £60.00 oil changes fresh oil etc id rather be cruising thanks ive informed the mechanic of this and he was going to check this out im desperatly looking on internet ive got a parts book and workshop manual on board but cant get there till next week but this seems a most plausible idea weve had as ive bought a new lift pump and still no change im excited about this and thanks for repling will let you no if indeed it has been the problem all this time. I wonder if there could have been a spacer between the lift pump and the block, (as there is sometimes) this spacer was mislaid during the rebuild and now the lift pump is over stroking, destroying the diaphram in an instant, a bit far fetched i know, but it is an odd problem and even rare things have to happen to somebody! i think you may have found my problem cant wait to get the boat back to the mechanic thanks i owe you one Link to comment Share on other sites More sharing options...
