colin loach Posted August 30, 2011 Report Share Posted August 30, 2011 Hi all. I need to change the fuel filter on my Isuzu 42. The new filter is very small compared to the cylinder where the diesel enters. I think this is where I now and again should get any water out of the tank although I have never done this. Has anyone got a picture of the filter unit and could they explain how I change the filter and drain any watter. Thanks Colin. Link to comment Share on other sites More sharing options...
steelaway Posted August 30, 2011 Report Share Posted August 30, 2011 Hi all. I need to change the fuel filter on my Isuzu 42. The new filter is very small compared to the cylinder where the diesel enters. I think this is where I now and again should get any water out of the tank although I have never done this. Has anyone got a picture of the filter unit and could they explain how I change the filter and drain any watter. Thanks Colin. Is it this one Vetus ? Alex Link to comment Share on other sites More sharing options...
colin loach Posted August 30, 2011 Author Report Share Posted August 30, 2011 it look very similar. Link to comment Share on other sites More sharing options...
steelaway Posted August 30, 2011 Report Share Posted August 30, 2011 it look very similar. Hi The filter element only takes up a small area inside the housing, the bottom half is designed to collect the water from the fuel and is drained by a screw in the bottom. Simply remove the canister and replace the filter element inside. If your engine has an electric pump it will self bleed given time (before you try and start the engine). If you are unlucky you may have to bleed the air out manually by undoing the bleed screw on the top and maybe the injectors. Alex Link to comment Share on other sites More sharing options...
colin loach Posted August 31, 2011 Author Report Share Posted August 31, 2011 Hi The filter element only takes up a small area inside the housing, the bottom half is designed to collect the water from the fuel and is drained by a screw in the bottom. Simply remove the canister and replace the filter element inside. If your engine has an electric pump it will self bleed given time (before you try and start the engine). If you are unlucky you may have to bleed the air out manually by undoing the bleed screw on the top and maybe the injectors. Alex Thanks Alex, you have been a great help. Link to comment Share on other sites More sharing options...
ditchcrawler Posted August 31, 2011 Report Share Posted August 31, 2011 Thanks Alex, you have been a great help. Take a look at Tony's pages and try and do one of his courses Link to comment Share on other sites More sharing options...
colin loach Posted September 1, 2011 Author Report Share Posted September 1, 2011 Take a look at Tony's pages and try and do one of his courses thanks for the information. Link to comment Share on other sites More sharing options...
blackrose Posted September 4, 2011 Report Share Posted September 4, 2011 Don't forget to turn the fuel tap off first. Link to comment Share on other sites More sharing options...
