NBMike 2 Posted July 21, 2011 Report Share Posted July 21, 2011 Nothing to say about it, just wanted to make sure it wasn't left out! Link to post Share on other sites
nb cygnet 0 Posted November 2, 2011 Report Share Posted November 2, 2011 New to forum - but glad to see someone has a Petter PJ. Mine is a two cylinder (PJ2W). Only had it for 2 years - hoping to do a decoke,fit reconn injectors and service the water pump in the New Year now I've sourced/got some spares. What sort of oil pressure does yours run at cruising speed eg 1200/1300rpm Ken (Cygnet) Link to post Share on other sites
NBMike 2 Posted November 2, 2011 Author Report Share Posted November 2, 2011 New to forum - but glad to see someone has a Petter PJ. Mine is a two cylinder (PJ2W). Only had it for 2 years - hoping to do a decoke,fit reconn injectors and service the water pump in the New Year now I've sourced/got some spares. What sort of oil pressure does yours run at cruising speed eg 1200/1300rpm Ken (Cygnet) Hi Ken Mine is an industrial engine that I marinised. It runs at about 65PSI. Mike Link to post Share on other sites
nb cygnet 0 Posted November 3, 2011 Report Share Posted November 3, 2011 Mine starts at about 65/70 but after an hours running drops to about 25psi. Will be looking at bearings and oil pump I suspect, whilst I am doing dekoke. Might just try fitting a direct reading oil gauge first - in case electrical sender is affected by warm engine. It was supposed to have been reconditioned in 2008 - I have a vague invoice for that time so I would have expected better pressure. Any tips will be most welcome including good place to get spares/advice. Ken. Link to post Share on other sites
Springer Skipper 1 Posted November 4, 2011 Report Share Posted November 4, 2011 looking at my handbook ,it says min pressure of 40 psi. An ex genuine Petter Engineer whom I know is --Jim Perkins--01159216414.Nottingham but he travels, He found me all the spares I needed for my PH 2 Hope that helps, Robin Link to post Share on other sites
NBMike 2 Posted November 4, 2011 Author Report Share Posted November 4, 2011 I'd recommend Jim Perkins too. Very knowledgable and very helpful. Link to post Share on other sites
nb cygnet 0 Posted November 5, 2011 Report Share Posted November 5, 2011 looking at my handbook ,it says min pressure of 40 psi. An ex genuine Petter Engineer whom I know is --Jim Perkins--01159216414.Nottingham but he travels, He found me all the spares I needed for my PH 2 Hope that helps, Robin Link to post Share on other sites
nb cygnet 0 Posted November 5, 2011 Report Share Posted November 5, 2011 I'd recommend Jim Perkins too. Very knowledgable and very helpful. Ta Mike, Looks like a good source Ken Link to post Share on other sites
nb cygnet 0 Posted November 5, 2011 Report Share Posted November 5, 2011 Hi Robin (sorry if you get this reply twice) Thanks for the info Jim looks like a good source. My manual says 40psi but I'm not sure at what revs, as the engine was designed to drive a generator at constant speed - as the speed varies so does the oil pressure - so waht pressure at 1200rpm? Surely it can't be 40psi at tickover. (Or perhaps I'm trying to talk myself out of a full strip down!!) Perhaps a question for Jim? As my wife has reminded me, its decorating at home this winter - so it looks like a job for the new year!! Ta again, Ken Link to post Share on other sites
Springer Skipper 1 Posted November 6, 2011 Report Share Posted November 6, 2011 My PH2 is a close relative of your PJ2 mine ticks over all day if neccisary at about 30 psi has done for years with no ill effect.Jim will give you good advice,he has written a great book of his experiences as a Petter Service engineer,he has a web site... www.petterengines.co.uk If it aint broke dont fix it. Robin Link to post Share on other sites
nb cygnet 0 Posted November 8, 2011 Report Share Posted November 8, 2011 My PH2 is a close relative of your PJ2 mine ticks over all day if neccisary at about 30 psi has done for years with no ill effect.Jim will give you good advice,he has written a great book of his experiences as a Petter Service engineer,he has a web site... www.petterengines.co.uk If it aint broke dont fix it. Robin Ta Robin, this is a great help - perhaps I will leave it a another year - its not got any oil leaks of note, doesn't use any oil and it runs well - if a little smokey for ths first 1/2 hour. Maybe just the dekoke and check the valves. Ken. Link to post Share on other sites
sociable_hermit 85 Posted November 8, 2011 Report Share Posted November 8, 2011 I know nothing about these engines, but from what you're saying, does it need slightly thicker oil? What are you using? And what do others use? Link to post Share on other sites
Springer Skipper 1 Posted November 8, 2011 Report Share Posted November 8, 2011 I have always used the manufacturers recommended grades,if you put a heavier grade in cold weather you can compromise the manual start capability that is a useful feature of these old engines. In my case I use a CC spec 30 monograde, HDX 30, supplied by by Agritec-online.com.This for older normally aspirated engines,used in agriculture and construction purposes.Too high a spec may lead to bore glazing if a sustained time on tickover or low power is the mode of use. Robin Link to post Share on other sites
onionbargee 249 Posted November 8, 2011 Report Share Posted November 8, 2011 PJW's use a very thin 10w40 oil. Link to post Share on other sites
NBMike 2 Posted November 8, 2011 Author Report Share Posted November 8, 2011 PJW's use a very thin 10w40 oil. I use Castrol 30 monograde in mine. And the same in 'self changing gears' box Mike Link to post Share on other sites
onionbargee 249 Posted November 8, 2011 Report Share Posted November 8, 2011 I made a mistake there, i meant 10W30. Link to post Share on other sites
nb cygnet 0 Posted November 10, 2011 Report Share Posted November 10, 2011 I use Morris Sae 40 in summer and Sae 30 in Winter - it gets quite warm in the engine room - so hence Sae 40 in summer (I think Morris quote tropical ie +35degs). If SAE 40 is used in winter it creates quite a drag on starting. I am concerned in cold weather that the small bore pipes up to the top of the engine may starve the valves etc.. of lubricant. Link to post Share on other sites
sociable_hermit 85 Posted November 10, 2011 Report Share Posted November 10, 2011 I use Morris Sae 40 in summer and Sae 30 in Winter - it gets quite warm in the engine room - so hence Sae 40 in summer (I think Morris quote tropical ie +35degs). If SAE 40 is used in winter it creates quite a drag on starting. I am concerned in cold weather that the small bore pipes up to the top of the engine may starve the valves etc.. of lubricant. Ok, yours is the boat I was asking about. You're already doing what I was thinking about i.e. using thicker oil in the summer to compensate for the thinning of the oil thanks to the temperature. So, another solution required! Link to post Share on other sites
br4k3s 2 Posted February 27, 2016 Report Share Posted February 27, 2016 Have reopened this topic to get some advise if out there, Have contacted Jim Perkins and unfortunatle he has now retired, is there any other persons out there who might have any information or know's where there is a source of spares and servicing parts for my Pitter PJW 3 ? Link to post Share on other sites
onionbargee 249 Posted May 11, 2016 Report Share Posted May 11, 2016 Has Jim given up supplying spares ? His website is still going.http://www.petterengines.co.uk/index.html I have a PJW3 in Tadworth, its never let me down. Link to post Share on other sites
denboy 2 Posted May 11, 2016 Report Share Posted May 11, 2016 rocking horse droppings springs to mind Link to post Share on other sites
RLWP 1555 Posted May 11, 2016 Report Share Posted May 11, 2016 rocking horse droppings springs to mind Y'think? I have been stocktaking Petter parts all evening. I'm not guaranteeing there are any PJW parts, I wouldn't be surprised though Who buys valve seat inserts? Richard Link to post Share on other sites
br4k3s 2 Posted May 16, 2016 Report Share Posted May 16, 2016 Has Jim given up supplying spares ? His website is still going.http://www.petterengines.co.uk/index.html I have a PJW3 in Tadworth, its never let me down. No sorry worded post wrong, he still has various parts it's that he has stopped doing work on 3cyl engines. i'm sure if you get in touch with him he will help you out if he can. Link to post Share on other sites
br4k3s 2 Posted May 16, 2016 Report Share Posted May 16, 2016 rocking horse droppings springs to mind Y'think? I have been stocktaking Petter parts all evening. I'm not guaranteeing there are any PJW parts, I wouldn't be surprised though Who buys valve seat inserts? Richard Ah company that is to do engine work on my PJW3 has sourced a lot of parts for internals, valve seat inserts included, was surprized at quantity of parts out there, am having rebuild so needed to find what could be sourced before they started to see if parts were out there if required. Am removing engine shortly then taking to engineer's for rebuild, engine running ok at present have had boat 10yr just want engine right for future cruising as part of long term upgrading of boat. So if ok might contact you if there is something needed thanks. Link to post Share on other sites
