stuart Posted July 24, 2006 Report Share Posted July 24, 2006 (edited) Moley, Ive to a monobloc tap in the kitchen and no problems what so ever with pressure (its actually a bit strong!). Its 15mm plasic pipe to the tap and then 2x metal tails (about 10mm each). I've got a 30psi pump and accumulator tank similar in size to yours (must be Limekiln ) Is the tap okay? Perhaps one of the washers (or ceramic disc?) inside stuck or set incorrectly? If you remove the tap does the water fire out of the pipe okay? (try not to sink your boat while you're doing this!!) Edited July 24, 2006 by stuart Link to comment Share on other sites More sharing options...
Moley Posted July 24, 2006 Author Report Share Posted July 24, 2006 Stuart, yes, tap is now fine (this is the one that was on the boat originally, not the brand new ceramic disc one that came with the sink). And no, I'm not about to bu99er about with the new one to try to improve its flow. And yes to Limekiln's accumulators, they had another £170 off us on Saturday. This included two new 115A/h leisure batteries. I seem to recall saying that I thought we'd got volts but precious few amps, well if the bateries have been on mains charge and the fridge is flashing ‘insufficient power’ after just a few hours, with engine running, that would seem to indicate to me that batteries are also on their way out. And their voltage is dropping overnight with everything isolated. But we've broken the grand now with Limekiln, so 5% off any future purchases. Link to comment Share on other sites More sharing options...
stuart Posted July 24, 2006 Report Share Posted July 24, 2006 (edited) But we've broken the grand now with Limekiln, so 5% off any future purchases. My discount card has just expired Edited July 24, 2006 by stuart Link to comment Share on other sites More sharing options...
Moley Posted August 10, 2006 Author Report Share Posted August 10, 2006 (edited) So, our holidays are looming and time’s fast running out. There’s still lots to do, but she’s usable, and I’m working on the niceties. The bathroom has now been completed. All wall tiling is up and grouted, the shower’s in, I just need to attach one shower rail bracket and clean up a bit. It still has a curtain where a door should be. The galley is completed, just needs the toe-kicks under the cupboards etc. installed and some vertical strips of floor tiles. That can wait. Splashbacks are tiled and grouted, an extra bit of worktop has been added (I like this touch, cut out so you can stand comfortably at the sliding window to feed the ducks or watch the world go by). This will have a couple more shelves installed below it; again, that can wait. At the front end, I still need to machine quite a bit of oak strip to cover some of the cracks in the walling laminate, but that can wait. The OSB has gone and all the ash faced ply is up, apart from some little bits on the front wall. I will be constructing some cupboards and shelving at the front, but for now an old dropleaf table with the back leaf removed is being temporarily fixed. This will serve for now as a TV stand and a table, and hides the water filter. The steps need to be oak clad and some decent treads made. All windows need some facing strips to cover the join between window suround and ash ply. Lynn’s been busy making curtains, I’ve still got to polish and re-fit the brass rods. I’ve been sidetracked as it would appear that the guinea pig is coming on holiday too and yes, I know the front paintwork is in serious need of attention. The kids were still going to be sleeping on airbeds, but the start of our hols has been delayed by not going to Cropredy and unforseen circumstances with cats and vets (we should have been away by now but it’s looking like Sunday might be our best hope). I’ve therefore got time to knock together some seating / bed bases. For now these will simply be box or ladder frames with boards on top, I will add sides and face-frames later. After a bit of time to make an accurate double-sided dowelling jig, the construction should be strong and fairly swift. edited for spelling As I say, still lots of finishing touches to add, but I've just had a look back at the pics on page 1, and all-in-all, I think I've done okay, considering. Edited August 10, 2006 by Moley Link to comment Share on other sites More sharing options...
stuart Posted August 10, 2006 Report Share Posted August 10, 2006 Once again ,well done Moley, have a great holiday - the boat is coming along very quickly - wish mine was that quick!! Link to comment Share on other sites More sharing options...
Janet S Posted August 10, 2006 Report Share Posted August 10, 2006 Well done Ade. You've got an awful lot done since we saw her back in May. Have a great time, and make sure you post a report when you get back! Janet Link to comment Share on other sites More sharing options...
Moley Posted August 10, 2006 Author Report Share Posted August 10, 2006 Have a great time, and make sure you post a report when you get back! Thanks Janet, and will keep a log. I've still got your mobile number, maybe you could relay a few texts? Link to comment Share on other sites More sharing options...
Janet S Posted August 10, 2006 Report Share Posted August 10, 2006 Yes, do that, and I'll post them for you. I only have PC access at work though, so there may be slight delays. I'm sure everyone will be interested to keep up with your progress - I certainly will! Janet Is the guinea pig related to Snibble? Link to comment Share on other sites More sharing options...
Moley Posted August 10, 2006 Author Report Share Posted August 10, 2006 Is the guinea pig related to Snibble? Let's stop this now, or it's going to get very off-topic and very convoluted, but it looks like we could be taking the whole damned menagerie that's one guinea pig under the front seat, four budgies in a hamster cage (half the price of the same sized birdcage, apparently), and, subject to vet's check-up tomorrow, possibly two cats And two of us, and two kids Or I might just leave the lot of 'em at home and try solo cruising Link to comment Share on other sites More sharing options...
DHutch Posted August 10, 2006 Report Share Posted August 10, 2006 Its looking great moley! As always! - It can be hard "finishing" everything, the details always take longer than you thing, and seam to go slower. But your still going as well as before!! Daniel Link to comment Share on other sites More sharing options...
Callum Posted August 10, 2006 Report Share Posted August 10, 2006 (edited) Utmost respect to the molemeister on progress so far. Being the sort of person who WOULD go off in search of a left-handed screwdriver (although I really mean to learn), I am in awe of the DIY prowess shown. Incidentally, I think FUBAR is an Americanism (possibily military) standing for F**ked Up Beyond All Repair. Edited for typos. Edited August 10, 2006 by Callum Link to comment Share on other sites More sharing options...
Moley Posted August 10, 2006 Author Report Share Posted August 10, 2006 I think FUBAR is an Americanism (possibily military) standing for effed Up Beyond All Repair. Correct. Derivation American military, certainly used in one of the Vietnam films (possibly Platoon), Beyond All Recognition, but first encountered by me in its Anglicised version (Beyond All Reasonable Doubt), in the early 80's, source Marconi Avionics, but probably other British military development. Link to comment Share on other sites More sharing options...
Janet S Posted August 10, 2006 Report Share Posted August 10, 2006 (edited) I think I first heard FUBAR in a science fiction film, the name of which completely escapes me.... Janet Was is possibly "Dark Star"? Edited after reading earlier post regarding animals - it's not a narrowboat, it's a flaming ark! Edited August 10, 2006 by Janet S Link to comment Share on other sites More sharing options...
Moley Posted August 10, 2006 Author Report Share Posted August 10, 2006 I think I first heard FUBAR in a science fiction film, the name of which completely escapes me.... The term was used in the movies Tango and Cash (1989) and Saving Private Ryan (1998). Sorry, anyone broad-minded has gotta see the related acronyms etc. http://en.wikipedia.org/wiki/Fubar innit amazin' wotcha can find on this innernet thingy Link to comment Share on other sites More sharing options...
TeeELL Posted August 14, 2006 Report Share Posted August 14, 2006 Ade, as ever your prodigious work rate and quality of workmanship shames us. I very much hope that you will be around on Sun 10 Sep when I bring ‘Elemiah’ down past your moorings; so I can see first hand your efforts and the progress you have made since my last visit. Have a great cruise. Link to comment Share on other sites More sharing options...
Roy n paula Posted August 14, 2006 Report Share Posted August 14, 2006 I hope I never see FUNDY on me medical records. Link to comment Share on other sites More sharing options...
Moley Posted September 6, 2006 Author Report Share Posted September 6, 2006 Well the plan was to have headed down to Cropredy for the folk festival (3 nights camping, Thurs - Sat), home on Sunday then straight off on the boat for a fortnight. But, “the best laid plans o' moles and men...” (or something like that). We never quite got round to sending off for the tickets (something to do with our disposable income, and then some, being disposed of in the directions of Limekiln, B&Q and suchlike). So I cancelled my Thursday and Friday off work (to take them later in the year), but gained a couple of evenings to work on the boat. It turned out just as well really, thanks to cats and rosebushes and vets we'd probably not have been able to go anyway. I was therefore able to continue to chuck together some front bed/seating. Sturdy, but nothing fancy about the construction (joints are dowelled or half-lapped or both), for the time being I've re-used the seating pads which came with the boat, but will have new ones made in due course. No seating yet has end panels, face frames or drawers. Seating base to the left is screwed to the floor, but I'm pleased with the back support, which will prop up to give a comfortable angle or hinge down flat for a wider single bed. To the right I currently have an old dropleaf table screwed to the front wall, will make something similar but better for TV plus storage plus table. Two 2-foot seat bases, movable. The one nearest the stove will have a tiled, fire-boarded end panel. Top hinges over to make another 6ft bed. Will probably wall mount another dropleaf table, to use between separated seats. Not too pretty, but for now, it works. and in use: Note: the cuddly-toy moles came too. Link to comment Share on other sites More sharing options...
Bones Posted September 6, 2006 Report Share Posted September 6, 2006 Gosh, that kept my pencil scribbling for quite some time. You must be really chuffed with all the work you have done on the boat moley! Well done. Here's a beer. Link to comment Share on other sites More sharing options...
alan_fincher Posted September 6, 2006 Report Share Posted September 6, 2006 I've re-used the seating pads which came with the boat, but will have new ones made in due course. Unless you know somebody in the trade, prepare for a possible nasty shock.... But then, with your usual good fortune, you'll probably see ones of exactly the right size, colour and supportiveness being skipped by someone, somewhere!.... ...................but I'm pleased with the back support, which will prop up to give a comfortable angle or hinge down flat for a wider single bed. Excellent idea, and I'm not sure I've ever seen anything similar, despite being a good way of tackling this problem. We also have boxes with inbuilt storage that act as our settees during the day, but to become single beds long enough for our boys overnight. The one slight irritation of the approach, is finding somewhere to lose the seat backs to overnight, as they don't form part of the actual beds. Fortunately we decided to have them made up as two half length backs for each berth, meaning we only have to be able to stow cushions just over 3 feet long, rather than trying to find a home for 6 foot plus of foam cushion overnight. In fact, if they are not too full of everything else, our seat back cushions can actually be stowed in the lockers under the beds themselves. Link to comment Share on other sites More sharing options...
stuart Posted September 6, 2006 Report Share Posted September 6, 2006 Excellent idea, and I'm not sure I've ever seen anything similar, despite being a good way of tackling this problem. Copy cat!! Link to comment Share on other sites More sharing options...
Moley Posted September 6, 2006 Author Report Share Posted September 6, 2006 Unless you know somebody in the trade, prepare for a possible nasty shock Yes, I know I'm not sure I've ever seen anything similar, despite being a good way of tackling this problem. Seemed logical, the back needs angling for comfort, so a question of trying to accommodate son when lying down, but not reducing it too much for Lynn's a**e when seated. (Hard hat please). Apologies to Stuart, but as I've not seen your solution, it must just be a case of 'great minds think alike' (or is that 'fools seldom differ'?) As we'll have two (approx.) 6' x 2' pads and four 2ft squares, storage for the spare bits isn't a problem. New back pad will be 3 or 4 inches wider, panel won't be seen. Bones: Ta for that, Link to comment Share on other sites More sharing options...
Bones Posted October 9, 2006 Report Share Posted October 9, 2006 Moley, What did you use for an end panel on the kitchen units (I am thinking of the one by the fridge) Link to comment Share on other sites More sharing options...
Sir Nibble Posted October 9, 2006 Report Share Posted October 9, 2006 Out of interest. I note that you have used the time honoured method of tucking curtains behind a dowel to hold them back. We found it awkward to upon/close curtains like that, and found they caused the dowels to bow and become loose. We came up with the following solution, (don't know if it's original). We sewed brass curtain rings to the back of the curtains and threaded them on the dowel which is now behind the curtain. It's very much more user friendly now, and we think it looks nicer too. Link to comment Share on other sites More sharing options...
Moley Posted October 9, 2006 Author Report Share Posted October 9, 2006 (edited) Moley, What did you use for an end panel on the kitchen units (I am thinking of the one by the fridge) It's just an offcut of 25mm MDF with a skin of my 7mm oak flooring laminate bonded to it with a polyurethane glue, and then a solid oak edging strip biscuit jointed on the front. I note that you have used the time honoured method of tucking curtains behind a dowel to hold them back. We found it awkward to open/close curtains like that, and found they caused the dowels to bow and become loose. The dowels are only temporary and will be replaced with brass rod when I get a round tuit, but they seem in short supply at the moment. Edited October 9, 2006 by Moley Link to comment Share on other sites More sharing options...
John Orentas Posted October 9, 2006 Report Share Posted October 9, 2006 It's just an offcut of 25mm MDF with a skin of my 7mm oak flooring laminate bonded to it with a polyurethane glue, and then a solid oak edging strip biscuit jointed on the front. The dowels are only temporary and will be replaced with brass rod when I get a round tuit, but they seem in short supply at the moment. I have tried all those curtain retention methods, brass rod (that's the worst) chains, fixed battens. This method I have found to be far best. A combination of polished 25mm dowel and chain. http://www.canalworld.net/forums/index.php...&cmd=si&img=908 Link to comment Share on other sites More sharing options...
