Skip to content
Anyone willing to provide view on quality?
Featured Replies
#1
Extra Edit:
From details provided,
it’s a circa 1990 engine, 20Hp.
Original:
Hello and thanks for looking,
Can’t say too much currently as in discussions on whether to buy, but currently looking at an older boat with this inboard LPWS2, which admittedly runs soundly at idle whilst moored.
Unfortunately I’m not (as yet) familiar with older marine diesel blocks.
I see evidence on engine box cover of previous water staining from where hose had clearly split, possible new water pump, plus the block looks to have untidy layout, missing covers, chipped & rusty protective paintwork, taped hosework etc.
I know they are solid and reliable if maintained, which I would undertake ASAP.
My questions…..
Is there anything you see from photo’s that would have your alarm bells ringing and could be easily by me tested at next viewing???
Thanks for any responses👍
Edited by Shireman
Additional Info
#2
Don’t see any lister branding
#3
It is a very early LPWS2. Probably from around 1990. Fitted with a Polar heat exchanger, which is now obsolete. A few design issues on these early engines such as your raw water pump only fixed with one bolt and no adjusting link, therefore relying on the tightness of the bolt to keep the pump adjusted. There were many improvements made on the later engine. But in saying that if it is still running OK you probably have one of the better ones.
#4
Lister SR2
2cyl air cooled 13HP 1978
Starts first turn of the key
Bit late now people with more knowledge than me willbe along
To give you the answers you seek
Cheers
  • Author
#5
boat registered 1990, original Lister Petter I’m advised 🤷‍♂️
#6
Looks to me as though there has been water pump trouble as the metal looks cleaner and newer than the rest of the engine. Looks like a new pulley on it too, which seems a little odd.
These early LPWS engines need almost impractically frequent oil changes IIRC. Something wild like every 50 or 100 hours.
#7
I suspect that if OP has to ask, this boat is not suitable. It would certainly make me walk away.
There are plenty of old boats with good engines, keep researching.
Edited by LadyG
#8
I have a later 4 cylinder version. Plenty on here with the 2 and 3 cylinder version too. If Steve56 says it's an early one then it is. Usually they are lister green and branded lister. The marine versions were marketed as "canalstar" but they are based on the lister alpha industrial engine often found in generators and water pumps.
Spares are reasonably priced and not hard to find.
@MtB is being a bit alarmist, these engines need frequent oil changes at 100 hours, but are very simple to service. It's never been an issue for us. They do need the oil changing as specified, as dirty oil is alleged to cause issues with the hydraulic tappets . If it starts well, runs OK without smoke and the oil and water are OK then it should be fine.
Generally they just work...
#9
I have one it’s a good little engine. I’ve had it for 10 years. Suggest you search LPW on this site, There is a lot of info
What’s it like if you start it without heaters. Mine will start fine without the heaters. I get a puff of black smoke then it’s clear. Can you video it starting and running? Oil change is not a problem it only takes a couple of litres of oil. I have a routine but with these hydraulic tappets engines you must use the correct oil and change it every 100 hours. I have £5 hours counter
It is classed as a modern high revving diesel and as such will not stand the abuse and lack of servicing the older Listers could allegedly tolerate
I strongly suggest you spend time searching CWF there is a lot of info
#10
What a silly post. He's come on here asking for help, very sensibly and you have nothing helpful to say, so post some nonsense. Presumably you don't like the shade of blue or do you have some actual knowledge to share like what a better engine might be or what to look out for on these engines.. ?
Thought not...
#11
Thought not...
But "got to keep the post count up !"
19 minutes ago, jonathanA said:
.........these engines need frequent oil changes at 100 hours, but are very simple to service. It's never been an issue for us. They do need the oil changing as specified, as dirty oil is alleged to cause issues with the hydraulic tappets .
These are easy to service / oil change when fitted into a Narrowboat, and there is room to work around it - but - this looks like it is shoe-horned into a GRP cruiser and there doesn't look to be room to even get your hand down to the oil filter.
I bet there is no service history available - if it's dificult to do, it doesn't get done !
I had a LPwS4 (the 4 cylinder variant) that needed the oil change every 100 hours - that was about once every 4 or 5 weeks for us.
I wouldn't want an engine instalation like that if I needed to do regular maintenance.
That alone would make me walk away.
#12
Agree it has been fitted with a new water pump. Not really anything to worry about on a 36 year old engine. The reason for the new pully is that it is part of the pump and not changeable.
#13
Back in the day the marine department never used the traditional green paint on there engines. As the majority of there business at the time was work boats and fishing boats, they would loose business with a green engine. Apparently amongst the very superstitious fishermen green was bad luck and they wouldn't set to sea with anything green on a boat. I suppose in later years when the majority of engines went into leisure boats it was not such an issue. In fact the narrowboaters would prefer the traditional green. Don't know if this is true or just an old wives tale, but that was the story I was told.
#14
1 hour ago, jonathanA said:
What a silly post. He's come on here asking for help, very sensibly nd you have nothing helpful to say, so post some nonsense. Presumably you don't like the shade of blue or do you have some actual knowledge to share like what a better engine might be or what to look out for on these engines.. ?
Thou
It has the look of a neglected engine.
Rust in one area and a fine coating of black oil elsewhere, where has that come from ...
Edited by LadyG
#15
An engine that has spent 36 years in a poky engine space, probably sitting above bilge water which evaporates and condenses on engine parts with changes in weather, never repainted since new, and has had various nuts and bolts undone and redone in the course of maintenance . Hardly surprising that there is some missing paint and rust.
#16
Exactly, the Q is quality, the Question is what is the quality., in my opinion its not been looked after as I look after my engine. Therefore the quality is less than optimum
#17
It looks a lot better than most that I see. If it starts and runs without any nasty noises it will do so for a good while more.
I had an LPWP 4, yes, it needs frequent oil changes but they are an industrial engine not a nasty Italian fuss box.
I only changed the filter every other oil change and it did it no harm, tight fisted boater.
#18
really ? its clearly had a new water pump, the alternator drive belt looks reasonable, no sign of rubber dust that would indicate a problem.
i can't see the black oil, in fact i'd say that engine looks very clean. no debris or crap down by the rocker covers, sure some light surface rust where the paint has flaked or been knocked off, but looks like fair wear and tear for a nealry 40 year old engine.
it looks like someone has fitted nice new silicone hoses with decent jubilee clips.
I'm not quite sure whats going on with the electrics near the big bit of yellow/black hazard tape, but it appears well taped up and secure.
I would want to chat to the owner to see what the story is with the water pump - did the engine overheat, did he have to have the cylinder head off, you might not get the truth, but the answer would tell you something.
looks far from neglected from what we can see. obviously if the bilge is full of black oil and theres streaks down the side of the block that we can't see, i might be more concerned....
Alan makes a fair point about access and i'd want to see if there are more panels that can be removed to give more access, I like to fill mine up from the filler under the exhaust manifold (straight into the sump) and that looks tricky on this one becuase of the heat exchanger, but not that big a deal. Air filter and alternator belt look accessible and the oil filter will only be small on that engine so all service items easy to get at.
right so is it a good engine that hasn't been looked after or is a bag of spanners regardless of how its looked after ?
opinions on here suggest its a good engine and with a good reputation for reliability. But like many more modern engines does need maintaining, perhaps more so than than the old air cooled dumper engines and the like. on the face of it, it seems quite tidy, but the OP needs to give it a good looking at and chat to the owner about its history if he can. But that would be the same with any boat with any engine...
We've certainly seen some truly horrible ones before today and many much newer than that...
#19
But I thought you were perfect
#21
Sorry Lady G I am irritated. The OP is asking a perfectly reasonable question and getting good advice from members that have direct experience or own/have owned Lister Petter LPW engines. These members are all “hands on” and between us we have I’m sure installed, serviced, rebuilt the LPW engines as well as running them for thousands of hours and thousands of miles on canals. Yet we do not claim to be experts
Your experience I suspect is limited to paying others to do such minor work as oil changes. With respect you do not seem to travel very far and probably mostly run your engines to charge your batteries
Your use of your Narrowboat is fine i am not criticising that even if you don’t get very far and I admire you for your pluck but wish you would rein it in when you are dishing out “authoritative advice” to new posters. It does the forum no favours and surely drives them away
Hoping you and Fernando are well and survive the bangs tonight my old Collie used to be terrified
#22
1 hour ago, Peugeot 106 said:
Sorry Lady G I am irritated....
Deleted
Edited by LadyG
#23
1 minute ago, LadyG said:
I am moored out in the sticks, no fireworks so far ...
You’re lucky. Some years we didn’t seem to be able to avoid them. One bonfire night I got the Manchester Heathrow shuttle. It was brilliant looking down
#24
On our share boat many years ago we drew a fireworks week so with our nervous dog in mind carefully chose a remote spot for the night of the 5th. All was well until just before dusk, when a boat moored next to us. No problem until they disembarked to enjoy their firework party. It's a long time ago but IIRC they set off after the display for drinks at the next pub. At least it was quiet after they left.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
