Skip to content
Ruston Hornsby 3VRHN
Featured Replies
#1
Hi what coolant is recommended for the 3VRHN lump? šŸ™‚
#2
De-ionized water and anti freeze, I’d suggest will be fine. Have you checked what the manual says?
  • Author
#3
Unfortunately not yet been able to obtain a manual
#4
If this is an ex plant engine it will likely have run with plain water - not deionised and not necessarily drinking water quality, plus whatever antifreeze was available at the time it was built. If it is a raw water cooled marine engine it may well have had salt water as a coolant.
In other words, don't worry too much about it!
#5
All true but the OP what was recommended, and I reccommend de-ionised water as any hard water used will precipitate the calcium in it and deposit it on the inside faces of the water galleries. I also recommend antifreeze having spent £5k (ish) having had frost damage to a similar engine block stitch-welded.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
