Skip to content
Bathroom Sink Waste Pipe
Featured Replies
#1
Do I really need a waste trap on a bathroom sink waste pipe on a boat? I get it in a house because it stops smells coming up from the drains but as thepipe goes straight overboard do I need to re-fit this trap. Or would a bit of flexible pipe like this work? link
Maybe I could arrange it so it has a dip in it so some water will sit in it to stop drafts.
I ask because the cupboard under the sink is very compact and not having a dirty great waste trap in there would make things much easier.
Edited by Alway Swilby
#2
Be fine without (mine is) 🙂
#3
Bathrooms and shower rooms have basins not sinks.
You certainly don't need a 3" deep seal bottle trap but the correct 1 1/2" seal 1 1/4" trap takes up a lot less space and makes connecting to the basin waste fitting much easier.
#4
course you need a trap so as when your ring slides off of your finger it will fall into the trap and not into the canal
#5
you don't need a trap - simple as. however how you get from the 1 1/4 basin waste to whatever skin fitting you have is the tricky bit...
and usually needs a few fittings, bit of flexible pipe and some jubilee clips...
Edited by jonathanA
add a bit
#6
Yes, but that's not plumbing, more like bodging.
#7
No you don’t need one.
#8
We've got flexible pipe with a bend/dip in it like you suggest. I'm not sure it takes up that much less space in practical terms though, it still gets in the way under there.
#9
My boat came with 90 degree elbow under the basin, but in windy weather it howled and made the bathroon cold. So I shopped around and found a small bottle trap which I fitted. No problems since and it has increased the drop to the skin fitting so it drains faster.
#10
Does this happen regularly, or just after an episode?
#11
Never as being an ex avionic engineer don't wear rings.
#12
More like false teeth and glass eye at my age 😁
#13
Or the vital screw you put in the sink so you wouldn’t lose it when fixing something
#14
This is made for the job, short length of flexible to a skin fitting jobs a goodun.
You don't need 32mm pipe for a washbasin!
#15
but when is anything on a boat 'plumbing' ? there is always an element of bodgery - its the nature of the beast....
#16
No most use plastic pipework, not lead... 🤣
#18
7 minutes ago, Kingdom Isambard Brunel said:
Plumbus.
Plumbum.
#19
2 hours ago, IanD said:
Plumbum.
Wot, lead waste pipe?🙂
#20
If you have any old lead waste pipe I'll happily weigh it in for you 😉
#22
1 minute ago, Jen-in-Wellies said:
Sounds like an embarrassing medical condition that you wouldn't want shouted out in the waiting room. "Where's the doctor to see this plumbum case?"
Maybe explosive diarrhoea caused by eating too much ripe fruit? 🤣
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
