Skip to content
Ideas to attach CCTV cameras?
Featured Replies
#1
Hi all,
Well, we finally have a boat and we are beyond over the moon!
We moved her through London on the slow journey to the Midlands.
We had to leave her for a few days before going back to move her more and I cannot stop thinking about it and slightly worried!
Can anyone advise on ways you have attached wireless CCTV onto your boats? Any pictures of it would be amazing.
Thanks so much!
  • Popular Post
#2
Don’t see the point really.
If any one tampers with the boat what are you going to be able to do about it if you’re miles away?
Plus the scrotes will be masked up so the police won’t be interested.
But I suppose if it gives you a bit of peace of mind it’s worthwhile.
CCTV and security lights are a bit of a bugbear of mine.
Causing light pollution.
You see more and more these days.
I just think if you’re that worried, stay in the marina.
#3
As @plato says, you can't do anything about someone breaking in or tampering with the boat when you are miles away. The risk you would want to know about is someone stealing the boat. Having a gps tracker module fitted that alerts you when the boat is moved more than a few metres, and gives location updates so you can recover the boat would be more use.
#4
I've left my boat in lots of places for a couple of weeks at a time, but my boat isn't the easiest to break into. They'd have to come tooled up and that's not the MO of most boat break-in opportunists.
You're better off beefing up your locks, etc, than fitting CCTV and mooring near other boats.
#5
I put chains round the interior door handles as that is the obvious entrance.
My sliding hatch has an Abus padlock, so a power saw required to open i leave a coffee mug or other signs of habitation in or around the boat, some LED lights.
You can use chain and padlock instead of mooring ropes.
I tend to moor near other boats.
There will be a method of preventing the engine firing up.
Edited by LadyG
#6
Walked down the towpath last hight at Hawkesbury and a bloody LED spotlight came on straight into my eyes then a flood light on the other side of the canal. Now I see someone is selling fender hooks with built in lights.
Edited by ditchcrawler
Spilling
#7
Very nickable at £20 each -- and I bet they don't float either... 😉
#8
There are lots of options with Wireless CCTV, but you'll have to consider how to power it all when you're away from the boat. No problem in summer if you have even a modest solar setup but mid winter it can be problematic if you're on a towpath and away for a prolonged period.
The whole setup (including router for internet) might only draw a couple of amps, but that's 50Ah a day you need to generate. Without knowing your battery and solar setup it's hard to give any firmer advice.
#9
14 minutes ago, IanD said:
.Very nickable at £20 each -- and I bet they don't float either... 😉
That's them, quite a neat thing but as you say, very nickable
#10
I’ve got eufy s340 cameras which are solar powered. They work really well and track movement down the towpath.
They are attached by a magnetic mount as below
https://amzn.eu/d/0gttWBvc
Ignore all the usuals. If you want to put up cameras do it. There’s will be the boat moored behind that the thief will pick on because it doesn’t have cameras.
#11
They look to be the type of fender hooks to which a fender cannot be hooked?
#12
Where do you moor? I fancy some free cameras.
Moor near an expensive boat, don't wash yours too often. Leave lots of rubbish on the roof. Fit an engine immobiliser. No one will touch it.
#13
I left one of mine for two weeks on the towpath somewhere or other and when I came back, the stern doors were open, slide pushed back and the tiller bar on. Nothing inside was missing or disturbed in any way.
After a bit of hard thinking I could not remember closing the stern up two weeks previously, but I DID remember leaving via the bow doors...
#14
Agree there are better ways of mitigating breaking or theft than CCTV, all pretty much mentioned above: tops for me are consideration of mooring location. But perhaps CCTV useful should your boat precariously list while you’re away from it, if water levels change or taking on water. You’d likely have time to get to your boat to sort. But a camera on the roof likely alerts the scrotes to something valuable inside.
#15
I wouldn't bother with CCTV myself, too much money and effort.
That being said, if I were to then a magnetic mount like this would be a good option I think. I'd move it every now and then to prevent any moisture trapped under it from affecting the paint/steel over time.
https://www.ebay.co.uk/itm/185241032710?_ul=GB&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338365712&toolid=20006&customid=CjwKCAiAqabXBhBUEiwAw_SQpa5icUehERQRQyrFqQTxfVqa_jOfKb414Pwr6v5xtdqoqxR8wZ1lBBoC0eEQAvD_BwE%7Cnull%7Cnull&gclid=CjwKCAiAqabXBhBUEiwAw_SQpa5icUehERQRQyrFqQTxfVqa_jOfKb414Pwr6v5xtdqoqxR8wZ1lBBoC0eEQAvD_BwE&loc_physical_ms=9194966&adtype=pla
#16
I tend to agree with the futility against determined individuals up to no good, especially if they conceal their identity. However, the option to monitor the surroundings when away particularly water levels strikes me as very useful.
#17
I came back to my boat above Stonebridge Lock, (Tottehnam) after a weekend taking the daughter up Malvern then over to Blackpool, and then back down and skating in Canary Wharf...up to Leicester to drop her off..to find my front doors open under the closed cratch, expecting the worst...
I had left them open .
Cratch was shut.
No visible outside locks, stove was probably producing smoke for 18 hours...
Just make your boat non- viable.
#18
What do suggest to achieve non viability?
Sinking it?
  • Moderator
#19
Big enough to mount several cameras, to provide overlapping fields of view, so no one can sneak up in the blind spot and steal it!
#20
Now available in 3 different colours .
  • Author
#21
Thanks all for your feedback, some made me giggle I have to admit.
For me it isn't just the theft/deterrent side of things, obviously that helps, it's more to monitor when I'm away, water levels, if I tied it well enough! If some inbred untied it! That kind of thing.
I just feel very protective over it I think because I love it so much!
#22
We have two Blink cameras, one in the boat, and one on a magmount at the front.... its easy to steal but so far nobody has. i like it as it shows me the nice marina views when i cant be there, and the occasional near miss (in Aston marina especially!)
#23
I wouldn't ignore anyone who takes the time to reply. That's why you've posted a question. Listen to all opinions and then make your own mind up. That's the idea of the forum.
#24
Everyone worries a little when we leave our pride and joy unattended i guess. Even in a boatyard something might go wrong. (Even craned out) but the odds are very much in your favour. Moor somewhere sensible. I use high quality combination locks because i know how easy padlocks are to pick. Plus i cant loose the keys lol. Most thieves would just go through a window though. Cameras have no effect really. But dont worry. The statistics are in our favour.
#25
I’ve done the same thing.
Was only for a few days.
No problems.
It’s all pot luck really.
Having cameras also says there’s stuff worth nicking aboard.
Also visible padlocks on the doors etc is a tell that no one is aboard.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
