Skip to content
Location of LiFePo4 batteries
Featured Replies
#1
I have been thinking about the best location for my two Ecoworthy 314Ah batteries. Boat is trad with engine room and front and back cabins. I was thinking about putting them in the bow locker but that’s a long way from the engine and next to the gas locker. I am thinking now about under the floor in the engine room so at least if there is a problem there are exits in all directions and placing them on the baseplate with steel containment to maintain a steady and hopefully cool temperature. Not sure of any regs likely to be coming soon. Any other suggestions welcome.
#2
Any problem (e.g. battery fire) is extremely unlikely with a decent installation, suggest you read the IWA/CA Guidance Note if you haven't already.
https://waterways.org.uk/about-us/news/new-guidance-helps-boaters-navigate-the-switch-to-lithium-batteries
Nobody knows for sure what regulations that boaters will have to follow are coming or when, but it's likely that the ISO standards will make their way into RCR/RCD/BSS rules at some point, and the BSS rules apply to all boats (at next 4-yearly inspection) not just new ones. New rules may make their way into insurance conditions more quickly than this, but again nobody knows for sure.
That's why the Guidance Note say that "best practice" is to install the batteries so they're isolated from the living space, because the ISO standard says that any toxic/explosive gases which may emitted due to fault/overcharging must be kept away from people -- which in practice means venting them overboard, like gas locker rules. There's no requirement to do this today, but not doing it is likely to cause problems in future so it makes sense to do it with a new installation.
Putting LFP batteries in the open in an engine room which has doors to the living space is unlikely to comply with this; if they're in a box/locker closed off from the engine room and with vents to outside the boat (like a gas locker) this will be fine, it doesn't even have to be steel (but steel is good). Of course a box/locker like this can go anywhere convenient (even inside the living space) so long as any gases end up outside.
Hope that helps... 😊
Edited by IanD
#3
Do your batteries need a bluetooth connection to see the state of charge etc? If so, isolating them in a steel box or under steel floor plates isn't going to work.
I have wondered about fitting a box made of fireboard (with angle iron framing) around mine, incorporating a vent duct to the outside.
#4
Even plywood would be fine; the purpose of the box is to contain any gases and dump them overboard, not to resist a ferocious lithium battery fire for 30mins (as has been suggested elsewhere...). If you're actually worried about this happening (as opposed to just needing to meet the rules) it would also make sense to have a gas detector inside the box which can set off an alarm outside to warn the boater if things** start to go wrong -- which may also end up in the rules, who knows... 😉
It's still possible that the only actual LFP precaution needed to stop your boat ending up like the ABC dayboat is not to have a 15-cell battery with 16-cell charger settings and that otherwise LFP really is as safe as everyone used to think, but since ABC won't reveal the cause of their fire nobody knows... ☹️
Until the rules become clearer (and compulsory!) I'm not convinced it's worth making big changes to an existing installation (including moving the batteries or boxing them in) unless it's reasonably simple and cheap to do or you want peace of mind -- but it's definitely worth doing with a new install.
** though any decent BMS should have detected any overvoltage/imbalance/cell short long before this and raised the alarm anyway.
Edited by IanD
#5
Ecoworthy seem to suggest a minimum discharge temperature of 20 degrees for their 12v 314ah battery… surely that can’t be right?
#6
The minimum discharge temperature for the Eco-Worthy 314Ah LiFePO4 battery is -20°C (-4°F). [1]
Key Temperature Specifications
  • Discharge Temperature Range: -20°C to 55°C (-4°F to 131°F)
  • Charge Temperature Range: 0°C to 55°C (32°F to 131°F) (Note: Low-temperature charging protection stops charging below -7°C / 19.4°F or 0°C depending on the specific model documentation)
A battery sitting in a box on the baseplate (like mine) is unlikely to ever even get down to 0C; over the last 3 winters mine has never got below +3C even in the coldest weather.
Edited by IanD
#7
I think that is a poorly-formatted -20 degrees.Screenshot_20261103_140127_Samsung Browser.jpg
#8
So if the Lithium batteries are on the base plate inside the boat in a mid engine area, best practice would be for them to be in a totally sealed metal box, with forced air ventilation/extraction venting at least, say 6-12” above the waterline, with all cable glands sealed so no flammable/toxic gases can escape into the living area?
#9
How are you going to power the forced ventilation when the battery goes awol
#10
Have an out of box dedicated Lead Acid battery?
I think if all the IWA JWW guidelines were adopted by the BSS(hopefully not) it will be difficult for the majority of current narrowboats to comply. So boaters may have to think outside the box, if they want to post fit a Lithium battery install. We’ll have to wait and see what eventually happens.
Edited by BoatingLifeUpNorth2
#11
Why with a separate battery, of course... 🤣
Don't forget that anything else safety/battery system/alarm-related also needs to run off this, like any system controller/modem/router/alarms/gas detector/emergency lights/automatic fire extinguishers. Well, that's what the MCA MGN 550 Am1 rules say, but let's just ignore the fact they don't apply to UK inland waterways boats for the moment... 😉
Or you could just run a duct/tube from the battery box to the outside so any gases can escape. That's what most sane people would do, as opposed to pernickety regulation-writers -- or even people trying to have a dig at anyone trying to post advice that might actually be helpful... 😉
  • Author
#12
The problem with a completely sealed metal box is getting the signal from the batteries to the app on my phone so I would need say a wood or frp top to the box plus ducting with a fan which could be driven from the LA battery plus an alarm and possibly water flooding with a solenoid valve.
I’m not sure how they fail so would a suitable gas alarm in the compartment do the job plus a fan while they are charging. If they are going to catch fire the priority is just to get people out. Do they fail while charging or at any time just sitting there. The batteries I have seem lots of protection built in but I am still unclear of the process when they self destruct.
#13
so lithium batteries in a cruiser/semi trad engine 'ole that has a full bulkhead between the engine compartment and the living space (e.g majority of cruiser/semi-trads ) would meet the requirement and count as a 'battery box' so long as there was some vents to the outside. As we are talking lighter than air gases the normal vents would seem to suffice.
maybe a bit of a fuss about nothing for many boats ?
#14
My understanding is that the answer is "yes" -- which is fortunate because that's the setup I've got... 😊
It's not absolutely ideal because in a big space like that there's a very small chance that any gases might build up to an explosive concentration, but this is less likely with ventilation. If it does go horribly wrong (which is very unlikely), at least it's in a separate sealed-off engine space (like an engine/electrical fire) not in your living area, and I expect this would lead to the conclusion that it was a safe installation -- especially if all the hatches/covers to the engine space are steel, which will act to contain any fire.
Unfortunately it's not a "fuss about nothing" for all the boats that have LFP installed in the living space, for example under a bed or in a cupboard or under the rear steps or in the rear cabin, and there are plenty of these -- indeed some new boats are still being built this way, and installations are still being done like this by professional installers. It's not against the rules today, but that's unlikely to stay the case in the future.
Edited by IanD
deleted "and locked closed"
#15
Doing a quick search, there seems to be companies that have thought about all this and are building dedicated Lithium battery enclosures. I’m sure they’ll be expensive though. Also, would they work as a dedicated install on a Narrowboat?
https://www.evengineeringonline.com/designing-lithium-battery-systems-with-built-in-fire-suppression/
#16
My understanding is that if LFPs gas, the volume and rate of gas production is enormous. So given a simple vent of a battery container, almost all the gas produced will be expelled to the outside air, and only a minimum quantity will remain in the container and vent duct when the gassing has finished. So no fan needed, and therefore no separate battery to power it, and one potential source of unreliability removed.
#17
That is also my understanding, having spent a lot of time looking into this along with the JWG.
The problem with putting in any active measures is that they all have to carry on working even if the battery has done a HV disconnect or caught fire, so you need a separate backup battery to power BMS, contactors, fans, gas detectors, alarms and sounders, battery system control, automatic fire extinguishers -- all fine for a big expensive installation on a commercial seagoing vessel with passengers (which the MCA rules may apply to), but inappropriate overkill for a boat on the inland waterways.
And if that separate backup battery is LFP, what protects that against failure -- another set of safety precautions and a third battery to power them? What happens if the backup battery fails, so there's then no power to the BMS and all the detection/alarm systems? All of which ignores the fact that almost all BMS derive their power from the battery they control... ☹️
The ISO standard doesn't mandate any specific precautions about venting or fire suppression (e.g. "lithium" extinguishers) because it recognises that these depend on the installation, it just says this (see below) -- in other words it's down to the installer (or regulators) to define what is "safe". I'm pretty confident that LFP batteries in an (under-stern?) engine space separated from the living space(s) by a bulkhead and with ventilation to the outside will meet these requirements, as would a sealed box anywhere on board (including the living space) vented to the outside (like a gas locker)... 😉
7.2 The battery manufacturer's recommendation(s) shall be followed to protect against fire hazards,
including venting and specific fire suppression mechanisms (e.g. specific fire-extinguishing medium).
The arrangement of the energy storage system spaces shall be such that the safety of passengers, crew and
vessel is ensured. The safety philosophy for the energy storage space (ESS) shall be documented. The safety
philosophy should cover all potential hazards represented by the type of ESS and cover at least:
— gas development hazard (toxic, flammable, corrosive);
— fire hazard;
— necessary detection, monitoring and alarm systems (off-gas detection, fire detection, etc.) and ventilation;
— explosion hazard;
— ventilation handling in case of off-gas release and/or fire;
— external hazards (fire, water ingress, etc.).
NOTE Lithium-ion batteries can emit toxic, flammable or explosive gases during a thermal runaway event.
Edited by IanD
#18
I was thinking of getting a small open butty with a solar roof for my batteries connected to the main boat by an umbilical, saves all the agro 😂😂
#19
My concern would be that the rate of production is far faster than can be cleared by a simple vent. And that although there is probably a lot of lighter-than-air gases that will escape through say a high vent there may also be heavier-than-air gases that would pool in any passive box. Potentially building up to some sort of explosive mixture. So an active fan, and possibly quite a powerful one, might be needed.
  • Moderator
#20
34 minutes ago, BoatingLifeUpNorth2 said:
Explosive gas mixtures in air have an upper and lower explosive limit. Having a lot of gas produced very quickly in a confined space can be safe, as there is too little oxygen to go bang. What you don't want is for that oxygen deficient mixture to be asphixiating, or poisoning someone, say if it is happening in a boat cabin. Venting the mix to the outside, where it can dissipate in the large air volume of the planet's atmosphere, there will be a time period, where the mix is in the danger zone between the upper and lower explosive limits and any ignition source in the battery area could set it off. That will happen no matter how powerful the fan, or with no fan at all.
#21
If there is lots of gas produced, it can't just pool in the bottom, there simply isn't space. So it must be expelled out through the vent. All a fan will do is blow out the small quantity of residual gas left after the gassing has finished.
#22
If you plug the actual (well, guesstimated...) numbers in for rate of gas production, then even for a mahoosive propulsion LFP battery like mine (51.2V/700Ah/35kWh) the vent normally fitted for an engine/generator (typically 4"-5" diameter) will be plenty big enough, and this will normally be near the top of the engine space for obvious reasons. For a more normal size domestic battery a couple of inches diameter duct/vent should be fine.
Go on, guess what some of the you-can't-have-too-many-safety-regulations proponents are suggesting... 😉
  • Moderator
#23
A battery is an ignition source. No batteries to be installed in the battery area! 🤪
If the battery area is small, especially a boxed in area, then a bang doesn't matter that much. Even an under deck engine area wouldn't be so bad. Unless you were standing on the deck at the time. Unlike a possibly occupied living cabin.
#24
The other problem with boat cabins -- apart from being the obvious one of potentially being full of people who toxic gases don't get on well with -- it that they're pretty damn big, making it less likely that any gases will essentially push out most of the air and more likely that the result is a large quantity of explosive gas-air mixture, and which if it goes off bang will also find plenty of stuff like wood to start a nice hot fire with and comprehensibly burn the boat interior up.
Which is exactly what happened to the ABC dayboat... 💥
LFP in the (much smaller) engine space under the rear deck is far less likely to cause such problems, and stuff under there is normally a lot less flammable than a lined cabin full of furniture... 😊
Edited by IanD
#25
On the other, other hand, on the ABC day boat had there been people in the cabin, I suspect they might have noticed the battery gobbing out flames and white smoke and probably fizzing and possibly done something about it.
Also, had the boat not been plugged into a shoreline and been under fast charge unattended, the accident might not have happened.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
