Skip to content
Solar to battery connection
Featured Replies
#1
Hi, me again, need a bit of guidance to connect solar to my battery bank, not sure where to connect the positive and negative to, any electrical minded people able to help ,thanks
  • Moderator
#2
The leisure batteries are four big ones to the rear of the pics. The starter batt is the smaller Halfords obe to the front of the pics. The +ve of the solar controller needs to go to the +ve and connection to the leisure batt. The negative needs to got to the right hand connection of the shunt thst is bolted to the bulkead. You will also need to have a fuse in the wire to the solar controller +ve. What make and model solar controller have you got? How far is it from the batts? What wire size do you plan to use?
Incidentally, and someone is going to mention this, the connections to the four leisure batts are not optimal.
  • Author
#3
Yes I understand which are the leisure and starter batteries, I’m unsure which terminals to attach the solar to, I didn’t fit the batteries, an expert did, how are they not optimal ? Maybe I can get a refund 😂
#4
Whilst the connection arrangement is as Jen says, sub-optimal, the 'sub-ness' is so tiny that I doubt you'll ever notice it.
Posters on here just LURVE to obsess over battery cable connection layouts, but all of them work fine and they don't really matter, in my experience.
#6
But to your question, attach the positive output from your solar controller to any convenient positive battery terminal, and the negative to any convenient negative terminal. This is also sub-optimal but will work fine.
Oops, I forgot you have a shut. Do as Jen says with the negative as if you have an AmpHour counter, it needs the solar charge current to pass through the shunt.
  • Moderator
#7
There is a shunt in the negative. The negative solar connection needs to be on the non battery side of the shunt, or any attached battery monitor is not going to register the solar charging. See my annotated pic.
  • Author
#8
Almost got it right , I was thinking the negative to the other post on the shunt and the positive to the first leisure battery which the inline fuse going to it. Good job I asked for help. I’ll connect it tomorrow,too dark now , thanks for helping
#9
I take it you have a fuse in the line from the solar controller to the battery?
#10
13 minutes ago, Boat3r said:
42 minutes ago, Boat3r said:
.............. need a bit of guidance to connect solar to my battery bank
A 'just in case question'
You are not connecting the output from the solar panels directly to the batteries are you ?
You do have an MPPT controller between the panels and the batteries don't you ?
  • Author
#11
Can’t figure how to reply individually, but yes I have mppt controller and a breaker fuse between ,thanks
#12
Just to add to he "fun", remember, connect the MPPT to the batteries BEFORE connecting the solar panel(s) to the MPPT. It may not matter with a modern controller, there is a fair chance it will.
  • Author
#13
Yep read that somewhere , maybe the manual 👍🏼 thanks
#14
The 4 leisure batteries also seem to be of two different types/sizes, which may indicate that two have been replaced more recently. Not necessarily a problem, but there may be a risk of two new good batteries being dragged down by an older battery that is failing.
  • Author
#15
There’s around 2 to 3 summer months between battery purchases, so should be ok.
I’d already bunged out the extra thousand… BOAT 😂
#17
3 years is quite a long time for LA boat batteries
  • Author
#18
Meaning, June, July, August, all in one year ,sorry for confusion
#19
Also, just a quick note - the fuse should be near the battery end of the cable, not the MPPT end. The MPPT is a current limited source, but the battery is not.
#20
Ours are about 13 years old.
#21
How long they'll last is heavily dependant on how you use the boat, you can't compare without giving your use case.
The batteries on a boat which lives in a marina on shore power 24/7 with a decent charger will last many years - even when they start to degrade, it won't be noticeable. Similar for a leisure boat which is in a marina most of the year and then goes on long summer cruises, with the engine running for long periods every day and ample solar.
However, the batteries on a boat used as a liveaboard without shore power will have a much shorter lifespan. Any drop in capacity is very noticeable, and in winter the batteries will be heavily cycled. 3-4 years is a good amount of time for this.
#22
That's about the age the end blew off my starter battery with a crack like a rifle and spilled a cell-full of acid into the bilge.
Scared me witless as I was in the engine room with it, cranking the engine over when it happened!
#23
Blimey! You were lucky it didn't get your eyes. 😳
#24
That's actually the point I was making.
For @ditchcrawler to say 3 years is a long time without knowing how @Boat3r uses their boat wasn't any help at all and anyone new to batteries might think they have to replace them way before they actually needed to based on their usage. Also the 3 years is a long time comment was moot anyway as the OP had said 3 months not years.
#25
Sorry I read it as 2 to 3 summers and missed the moths bit.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
