Skip to content
Refleks engineer
Featured Replies
#1
Anyone know a reliable engineer in West London that knows Refleks heating systems? I have an existing one that needs a check up and possible upgraded rads.
#2
Have you asked on the London Boaters Facebook page?
#4
8 minutes ago, grantinthecloud said:
No one seems to have any advice on this. Are they uncommon systems in the UK?
Nope. Just not as common as Morso Squirrels.
This may help
https://youtu.be/lE04Xt0t9Qc?is=UngsKcTnZ6zfWVXT
Edited by PaulJ
#5
From the Reflex website, it looks as if the common marine ones are pot burners like Bubble stoves and oil fired Agas. I think many people service it themselves. Basically decarbonise the burner pot, including all the holes, especially the vital air admittance ones hidden under the burner pot rim. You also may have to clean the fuel metering carburettor, and (I think) use the inbuilt prodder to clear the oil inlet to the pot. Adjusting the carburettor is more complex, but I am sure there are posts about all this on the forum.
#6
There is a Refleks Stove Facebook page which has lots of useful information on how to service them (and other manufacturers oil drip stoves using the Toby regulator) yourself.
#8
You would not normally need to adjust anything on the Toby - don't fiddle with adjuster screws as these should all be pre-set.
Refleks are fairly easy to clean. Using cleaning tablets when the stove is on may help to reduce carbon build up.
Lockgate have some tips and videos on their website. Be careful what you see on YouTube.
  • Author
#9
Thanks Joe - its a remarkably simple system on inspection, will give it a good clean and hope for the best )
#10
Put a mirror in the bottom of the burner pot and look under the rim to check where air holes are and if they are clear. I would vacuum any muck that ends up in the burner pot, rather that brushing it, to minimise the chance of forcing muck into the fuel inlet.
#11
I found a jewellers screwdriver was the correct size to poke in all of the air holes - not too large and not too small. I can't remember the size but it was one that you find in an everyday box of six jewellers that you can find in the shops.
/ecomm_images/items/large/1-909-040.jpg
#13
If your fire has the fuel inlet cleaning rod ( most do) push this in before doing any cleaning - this will prevent crap dropping into the inlet pipe as you loosen the slag (DAMHIK!)
#14
I use a small drill bit just smaller than the holes.
The difficult bit is poking the holes in the bottom of the burner rim, it requires great dexterity even when using an LED lit mirror on a stick!
  • Author
#15
sure does - and a blackened interior adds additional strain on the eyes!
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
