Skip to content
Bow Thruster "brush" replacement?
Featured Replies
#1
Hi all,
I have been ringing around some boatyards as apparently our Bow thruster likely needs the brushes replacing as it's not working correctly.
We changed the battery which was dead and now found this new potential fault.
Does anyone have any rough ideas on how much it would cost to have the bow thruster brushes replaced or how much a new bow thruster would cost to install at a boatyard?
Many thanks )
#2
Make, model, size, location, age?
You say not working correctly, I would of thought if brushes it would not work at all.
The motors are fairly reliable, have you checked the contactors and all electrical connections? This is where most problems arise after knackered batteries have been replaced. Running motors on failing batteries actually causes increased current as the motor doesn't get up to speed to generate back EMF.
  • Author
#3
Annoyingly I don't have the specifics but it's on a 57ft Aqualine Narrow, built in 2006 and awkwardly the boat is in London at the moment and we are in the Midlands, we are just about to finalise the purchase and this is the last stumbling block.
Apparently when the battery was changed it worked briefly and inconsistently and that's about the only thing we've been told...
  • Site Owner
#4
Is it a Vetus system, or another brand, can you find an image of what the control panel looks like online?
Either than, or take the whole motor to an automotive electrical outfit. They can probably get suitable brushes as they wont be wildly different to truck starter motor brushes.
  • Author
#5
It's a Vetus system and the tubes are 150mm in diameter, annoyingly that's the only info we can get hold of and no pictures of the control panel 😑
It shouldn't be a really expensive job should it? How much does it cost to replace an entire bow thruster worst case?
#7
Vetus branded ones are an arm and a leg.
#8
Unbranded replacement motor brushes are available in a variety of sizes, so it shouldn't be a big problem. And I have heard of people shaving down the sides of the carbon blocks where they couldn't get an exact match.
So it shouldn't be a big deal, and if it is just the brushes, it shouldn't cost a lot. But if the motor itself has failed, then you are looking at a bigger bill.
Can you not get the vendor to fix it, or knock the price down a bit?
(And not having a working bow thruster is not the end of the world. While they have their uses, most boaters manage perfectly well without).
#9
I have cut large brushes down to size where exact replacements were unavailable. Carbon brushes can easily be rough cut to slightly oversize with a junior hacksaw, and then rubbed to size on abrasive paper laid on a suitable flat surface: I use a glazed tile.
  • Author
#10
Thanks for the insight all, we've had a little knocked off the price and will see where we go!
#11
Assuming this is a typical size Venus unit, replacing the brushes probably takes 1 hour or less if the bow thruster is reasonably accessible. A set of brushes (non Vetus) costs less than £20.
What is the fault? Is the power fuse from the battery OK (usually a Megafuse)? The contactor on the side is generally robust. If the contactor does not pull in there is a small fuse that sends power to the switch unit at the stern and the signal comes back from there to drive the contactor.
In addition (from an old post of mine on here)
I bought some of the replacement brushes as spares for our boat and used them this year to repair the thruster on a friend's boat. The amazon supplier no longer stocks them. but have found this supplier. https://www.carbon-brushes-gomes.com/carbon-brushes-9x20x28-5-compatible-starter-bosch-bsx33.html
After a little research I have discovered that Vetus have been a little sneaky with the bowthruster contactor. It is an Allbright Ltd unit with part number  (Vetus rather than Allbright) DC182-116. This is a specific part number unique to Vetus. The original Allbright number for the same part is DC182-656 and these are available from Traction Power Ltd on 01618651319. Traction Power will supply a spares kit or a whole contactor, however note that the spares kit costs approx 75% of the whole unit so you may not consider this worthwhile.
Edited by jonesthenuke
#12
I had my Vetus bow thruster motor refurbished by Cox Auto Electrics after condensation the bow thruster compartment had caused it to seize up for less than £400.
Much cheaper than buying a new one, which is over £1,000.
https://www.coxautoelectrics.co.uk/marine-leisure
#13
Before ripping a motor out you need to make sure its not a control problem
  • Author
#14
Thank you very much for all the insight and detailed comments, very technical and helpful!
We are moving it without the thruster at the moment and we will have it looked at to see if it's worth while getting it fixed.
The seller said it worked temporarily when the battery had been replaced and then stopped again so god knows?
#15
This might sound daft, but double check the battery connections for the thruster. If they've replaced the batts and not properly tightened them up it may have worked loose. You never know, could be a cheap fix.
#17
It might not be applicable to the brushes used in bow thrusters, but the brushes used in Bosch angle grinders incorporate sprung-loaded insulated plungers that stop the motor when the brushes wear down enough to release them. You would only see this by removing the brushes.
#18
Switch off commutator saver brushes.
#19
All very well, but I've got a couple of dead angle grinders and a dead jigsaw, and all three have plenty of life left in their first set of brushes. It's the on-off switches that have failed (burnt out contacts) and replacement switches don't seem to be available.
#20
I refurbished my Vetus unit last year.
I thought the brushes would probably be worn but when I got the motor unit out they had plenty of life left in them. They were just sticking in their guides. A good clean and five minutes cleaning up the guides with a Swiss file and it came roaring back to life. It’s like a new bow thruster.
Worth checking first, you can’t tell until you get the motor unit out and diagnose the problem. You could save yourself a lot of money.
  • Author
#21
Thank you so much for the advice everyone, definitely going to be trying all your little hints and tips!
#22
This is a very common fault area, we have a local company, Master Abrasives, which seems to be able to source new switches for just about any power tool and replace for a very competitive price. We usually wait until we have several need repair.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
