Skip to content
Gas fittings for new bubble tester
Featured Replies
#1
Hello
I thought it was going to be a simple process but found it to be anything but - a nightmare of conflicting advice - so thought I'd ask here as Im sure people have done this.
I need to fit a bubble tester for an upcoming BSS (don't need to but finding a gas safe engineer to coincide with the BSS examiner is proving problematic)
I will be checking, but for the moment I assume I have 3/8" gas pipe fitted. I thought it would be a relatively simple process to fit a reducing compression coupler to go from 3/8" to 10mm on both the inlet and outlet pipes and fit a 10mm bubble tester.
The 10mm bubble tester is no problem but I cannot find a coupler to do the job for love nor money. I'm hoping that within a matter of seconds, someone will post a link to one 😊
I can find every flavour of coupler but the one I want. Is it so unusual a fitting? Am I missing the obvious?
I have been to various gas specialist sites and the usual Screwfix-type ones as well and cannot find what I want . Any/all help gratefully received.
Thanks
Rick
#2
This is one reason why I refuse to fit a bubble tester. They are only made with metric connections and most boats are plumbed with imperial copper pipe.
I have seen 10mm compression fittings used with 3/8" olives on 3/8" pipe, a dangerous bodge.
Edited by Kingdom Isambard Brunel
#4
Rather than send members here on a possible wild goose chase, how about actually checking first?
#6
2 hours ago, RickS said:
Hello
Thanks
Rick
i'm not advocating it, but its perfectly acceptable (to the BSS) to connect the bubble tester using 'rubber' flexible gas pipes, providing they are short (can't remember the length , 0.5M i think - check on BSS website) and the conections to the copper pipe are made with suitable connectors and not just shoved onto the end of the 3/8 or 10mm copper. (e.g a barbed hose connector like a fulham hose connector). you can get bubble testers with hose fittings already attached easily enough. Theres some other things ot check - think its all got to be in the gas locker or something, all on the BSS website so go and look it up.
#7
And how would a collection of many fittings hose clips and rubber pipes be a safer installation than no bubble tester at all?
The regulations are crazy. Thank you Jonathan for not advocating such crazyness.
#8
Because the bubble tester and rubber tubing are all in the gas locker, which is the one place onboard where gas leaks are "safe", but it's there to detect leaks elsewhere in the boat which are definitely not "safe"?
#9
Southamton Calor (SoCal) used to supply the Alde tester with imperial fittings replacing the metric originals.
Unfortunately this now comes up as discontinued...
https://www.socal.co.uk/p/_4071-3838/marine-leak-detectors/alde/alde-gas-leak-detector-38
So you would now need to source your own replacement fittings, and change them over.
I have not revisited the past threads on this topic, but I do recall people reporting that a great deal of brute force can be required to remove the metric couplings.
#10
I fitted a bubble tester on one of my boats earlier this year. I unscrewed the metric adaptors from the bubble tester and fitted Fulham nozzles to the inlet and outlet. (The adaptors I removed weren't particularly tight to get out.)
I cut the regulator off the orange flexible hose tail, fitted the hose tail onto the bubble tester outlet nozzle and fitted another orange flexi hose from the regulator to the bubble tester inlet nozzle, and job done. Passed its BSS shortly after.
#11
Think you will find he has already asked the same question on Facebook.
Obviously didn't like the answers there so he is hoping to get an answer he likes here
  • Author
#12
Hardly a wild goose chase, but I take your point. Shame you had to make it in such an aggressive way but I suppose that's what happens when people are behind a keyboard. Thanks for your input.
Dear oh dear. I think you will find, Tonka, that I have not asked a similar question on Facebook, or, indeed, anywhere else. So your 'obviously' is more of an assumption than anything else. If you have something to say to me regarding my posts here, just reply and address me personally, rather than offer up snide, inaccurate asides. I'm not hoping for an answer that I like, I'm hoping for information on compression fittings.
  • Author
#14
3 minutes ago, Tonka said:
No. The clue was in the name 'Martin Preston' at the top of the post. I suppose you might have thought RickS was a cunning alias, but all you had to do was ask.
#15
Well I am sorry then
#16
Must admit I thought the same thing, but you often get more reliable help here than FB so wouldn't decry anyone doing it
#17
Responding with passive/aggression to my post containing none says more about you than about me.
  • Site Owner
#18
2 hours ago, MtB said:
I fitted a bubble tester on one of my boats earlier this year. I unscrewed the metric adaptors from the bubble tester and fitted Fulham nozzles to the inlet and outlet. ...
Equally, I am sure you could have fitted 3/8" compression fittings. What thread was in the bubble tester itself?
Yeah, this would appear the logical option, assuming the fittings can removed from the bubble tester. Depends what they are sealed in with I guess.
#19
As an aside, if the bubble testers come with 8 mm and 10 mm fittings, why are boats plumbed in 3/8" pipe? Alde are presumably assuming use of metric pipe.
Edited by David Mack
  • Author
#20
I agree that there was an element of passive aggression in my reply but more of a response to your rather than an initial position.
Let's not get into a cycle of stupidity as it solves nothing and is a bit of a waste of time - just move on and let others contribute if they want to.
#21
Someone may have already said this, I don't have time to read every post:
If you put the bubble tester in a vice it's fairly straightforward to crack off the metric fittings (I think they use some sort of thread locking compound) and then fit whatever imperial fittings you need. That's what I did and surely it's the simplest method?
From memory the threads are tapered so you shouldn't need any thread sealant. But I might be wrong about that bit as I did it over 20 years ago.
That doesn't seem a valid reason not to fit a bubble tester, since it's very easy to change the fittings to imperial ones. No need for any bodges.
Ok you have to buy additional fittings so it's a bit more expense, but that's boats for you.
  • Author
#22
Accepted and thank you.
I must also apologise for my use of the word snide. I'm afraid I was a bit miffed and that was not really appropriate of me.
#23
No worries,
I have been called a lot worse on here
#24
IIRC 3/8" tubing has a thicker wall and is BSS approved, 10mm does not have the required approvals.
springy
#25
0.5M is about 19. 5 inches.
Im not convinced you should be fitting your own gas installation.
Edited by LadyG
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
