Skip to content
Replacement light fitting
Featured Replies
#1
My sister has a Les Allen narrowboat and needs to replace a broken light fitting. Does anyone recognise the original? Or have any idea where she might be able to get a replacement?IMG_0199.thumb.jpeg.ce375f4f422f49963cbf80c8339d00aa.jpeg
#2
All I see is a rusty flange, could be anything, it might be better to look for replacements for them all.
#3
This ^^^^^^
More photos looking from top and bottom, and also of where it fits on/into the boat. Then we might be able to identify it and make suggestions.
#4
It looks almost as if it could be some kind of inset ring type pull up for an external deck board rather than a lamp. This makes me wonder about the OP. Still we will have a better idea about it when/if we get more photos. It looks very small compared to the hand, but could be an inset halogen capsule light but then why steel, why so rusty, and why such a large flange.
#5
Adjusting the contrast/brightness shows more detail. Could be a recessed downlight, usually have oblong sprung clamps on the sides though, that ring shape is really throwing me off. More and better pics needed.
#6
If the ring retained a lens r is a decorative bezel then it has to be fitted from the back of whatever it is recessed into, which seams unlikely for a lamp or that rectangular flange would be an eyesore if surface mounted.
#7
Was it the fitting above the shower by any chance? 😂
#8
Is it the only light fitting or are there others, not so rusty? Can we have a photo of one of the others please, it better condition?
And ideally a photo of the lamp that fits into it too, please.
#9
I don't want to be rude to a newbie, but how on earth do you expect us to identify anything from a single photo like that? We need several photos from different angles, both of the broken fitting and of the similar undamaged lights.
Also, if this is a Les Allen boat it must be at least 30 years old, so there is a very good chance the original light fittings are now unavailable, and you will be looking at replacing with something else anyway.
  • Moderator
#10
The LED revolution will have put many older lamp designs out of production. Even if whatever this is turns out to be has survived, there is probably something cheaper, brighter and lower power draw available now that will fit reasonably easily.
#11
hello.  I'm the 'newbie' sister in question.  I've owned the Les Allen for ...um...about 15 years now.  A combination of illness, surgery and canal closures has kept me away from the boat for the best part of a year.  When i returned, I found the internal back cabin metal surround of the recessed light fitting had corroded and fallen away.   So yes, internal; No, not near a shower: yes, ring-shaped metal clamps not oblong and yes, original, not LED fittings.  I could include more photos, but the website doesn't seem to want to me upload them as I keep getting an error message.  And yes, the photos are below the 4mb limit....
but it sounds as if everyone is as mystified as me as to how to replace this original fitting.  And yes, of course, I could have chosen to replace with more modern fittings, but I'd rather not, hence my lovely brother's enquiry.  I'll just keep looking.  thanks
Edited by helenc
  • Moderator
#12
Welcome to the forum. The posting pictures problem is probably easiest solved by taking a screenshot of the displayed pic and posting the screenshot. There are also apps for downsizing the ridiculously high resolution and file size default phone camera files.
See this thread.
#13
Try uploading another image with another posting. There are some knowledgeable people on here but really it’s impossible to say anything from the one picture that’s posted. Sounds like a lovely boat. There is a limit on image size per posting.
Somewhere like Glascote Basin, Tamworth, Rose narrowboats or Union canal cruisers Braunston may suggest solutions if you can’t do any more pictures
#14
thanks for the advice re: pictures.  I've now uploaded another one which gives a clearer picture of the fitting
#16
new picture edited into the original post
  • Moderator
#18
Is the aperture in the ceiling that this fitted in 2" / 52mm diameter? If so, it looks like a pretty standard downlighter.
Edit to add: post clash with @Jonah
Downlighters come in different sizes. Measure the hole to find a replacement, eg https://www.mygreenlighting.co.uk/downlights/downlights-by-cutout-diameter.html
#19
I think that is a cheap and nasty domestic halogen light fitting. Made from very light, coloured/plated steel.  As I think was said far earlier, these normally have springy clips fitted to the so you set the clips upright and pushing the assembly inot the hole in the ceiling causes hem to snap down and secure the lamp.
Nowadays it would use an LED. This Amazon add gives you an idea and one of the images shows the springs I was on about. I am sure you can get different coloured bezels as well.
https://www.amazon.co.uk/gp/aw/d/B0C3H3BYRY/?_encoding=UTF8&pd_rd_plhdr=t&aaxitk=388e387f15b679d5659d99c136213d0a&hsa_cr_id=0&qid=1786203955&sr=1-2-e0fa1fdd-d857-4087-adda-5bd576b25987&i=aps&aref=uF8zLT2tch&ref_=sbx__sbtcd_asin_1_img&pd_rd_w=ALVjI&content-id=amzn1.sym.09d6149b-953c-4f4d-87fd-7e954d905289%3Aamzn1.sym.09d6149b-953c-4f4d-87fd-7e954d905289&pf_rd_p=09d6149b-953c-4f4d-87fd-7e954d905289&pf_rd_r=N51Z89CXMJBSA4GTY9GW&pd_rd_wg=iM4wY&pd_rd_r=68eaf601-a371-4a7e-9bab-927f2440c379&th=1
This link sends you to a site that MIGHT supply stuff that is a bit more voltage tolerant than Amazon vendors.
https://www.atenlighting.co.uk/product-category/boat-and-leisure-vehicle-lighting/boat-leds/?gad_source=1&gad_campaignid=24046983499&gclid=EAIaIQobChMI3-2lzK-RlgMVX6VQBh17zxJaEAAYASACEgLBRPD_BwE
You need to take care that the existing wirirng is, in fact, connected to a 12VDC supply and not mains via a shoreline or inverter.
Edited by Tony Brooks
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
