I'm looking to draw up a list of all the different online canal map systems there are.
So far I have got...
Canal Plan
Water Nav
Open Canal Map
CRT Official Map
Waterway Routes
Open Canal Map
Canalmaps .co. uk
Canal Traders Map
Watermap
Any I've missed?
Thanks
Andrew
11 minutes ago, Andrew Denny said:
Tony, ooh thank you, I hadn't heard of Lockmasterai.co.uk
A long topic on here about it here:
A number of us feel that some of the data that gets presented as accurate may be rather misleading. The developer seeks to pass the responsibility for using the information it gives to the skipper. Good luck if you decide to read it.
14 minutes ago, Jen-in-Wellies said:
Everyone who suddenly thinks "satnav, but for canal boats", assumes they are the very first to have ever had this idea. Hence the number of apps.
https://xkcd.com/927/
@IanD if you copy and paste the url below the image on xkcd page it embeds it.
If you take a look at the topic on here about it you probably wish you still hadn't 🤣
Edited by IanM
@IanM Thanks, I'd missed that -- even though I suspect I've done it before... 😉
Edited by IanD
I am a tad sceptical about online maps for actual navigation. For me, almost constant access to detail is both desirable and essential. However, despite having two phones on different networks, we find that too often we do not have a proper internet connection - it says it has but just sits there having a sulk.
But then I have a mature home built system that works offline with a plugin GPS. Lack of internet only means I cannot see fancy maps such as NLS maps from 120 years ago! It also means I have a hefty overhead of photos stored locally.
Do you try and access the internet directly via cellular from your phone?
I've found it's more reliable to use Wi-Fi to the router and then cellular from that, it can pick up signals when the phone can't (or give >2x higher data rate for the same reason).
7 hours ago, Mike Todd said:
O am a tad sceptical about online maps for actual navigation. For me, almost constant access to detail is both desirable and essential. However, despite having two phones on different networks, we find that too often we do not have a proper internet connection - it says it has but just sits there having a sulk.
I produce an itinerary in canalplan, create a pdf file of it and download that to my phone. Then I have the info while boating whether or not I have a data connection.
Edited by David Mack
Syd Arkless (rip)  Canal Planner was the first and way ahead of the competition.
  • Greenie 4
I've still got it, but I can't get it working properly on Windows 11, though at least one person has.
The best solution would be an equivalent of Google offline maps. Where you download the map to your phone once, and then you only need GPS functionality working, not internet, to show you exactly where you are and what's ahead. And it saves massively on battery life.
But I'm not sure that any of the canal maps offer it. 😕
Edited by Cheese
rubbish typing
The old eCanal maps worked like that before RCR got hold of them. WaterNav is supposed to, but as it's missing half the system's locks and tunnels it's not a lot of use, and they don't seem very interested in putting them back.
His wife passed away last year in Australia
  • Sad 1
Canal Plan
Water Nav
Open Canal Map
CRT Official Map
Waterway Routes
Open Canal Map
Canalmaps .co. uk
Canal Traders Map
Watermap
Any I've missed?
Thanks
Andrew
Open Canal Map is in there twice
Waterway Routes is stored on the device so works offline. It's about a gigabyte download for all of England and Wales.
Thanks! Oops.  I started to list these thinking it would be a 5-min job, but I'll have my work cut out now 🙂
I also use Canal Planner by Syd Arkless (RIP) and have managed to get it working on
Windows 11. It is a bit dated now but IMHO has never been bettered!
Is that the version with the proxied Google Maps?
The actual final version became unavailable as it needed a web generated password if yiu changed computer, and sfter the original programmer died, hus son emigrated and dumped the website without making the prog usable, which was annoying for those of us who had paid for it. The previous version didn't need that and still worked on W10. I've not bothered very hard to try to get it working sgain, but it's advantage was that you could save your own photos to the localities, which was rather a nice touch.
