Skip to content
Diesel problem.
Featured Replies
#1
My new beta 50 wouldn’t start. I checked the filter and found that I had water in it. The fuel had separated and floated on top and it was clear of anything abnormal. I pumped some out from the bottom of the tank and got this out. It’s been settling for 3 days but won’t separate. New tank, mild steel and filled from empty with fresh diesel. Any help appreciated.
Regards Steve P.
#2
When you get water in your diesel it looks like this ;
Diesel floats on the top of the water - you may have water in your fuel but that sample suggests you did not get your pick-up pipe down to the bottom of the tank
That does not suggest water in the diesel
  • Author
#3
Any idea what it could be.
#4
If you are sure you got water out of the filter drain, then you have water in the fuel.
In the sample in the bottle there does not appear to be any water - therefore when you pumped some out of the tank, the end of the hose was not below the water/fuel interface and you just got fuel.
Push you pipe in until you feel it hit bottom, then remove some "fuel" and see if that settles out.
You may only have a couple of inches of water - I had over 200 litres of water in my tank.
When you say you refiled your tank from empty - do you really mean the tank was empty, or there was no fuel ciming from the tank to the filter - the fuel to filter pick up pipe (inside the tank) is normally several inches off the bottom of the tank so as to avoid picking up muck, rust, rubbish and water.
If you drained the tank until no fuel got to the filter, you probably have left 'inches' of water in the bottom of the tank.
Ideally you should (properly) de-water your tank annually.
Edited by Alan de Enfield
  • Author
#5
That sample was from the bottom of the tank.
I was hoping it was water. At least I could have sucked it out.
#6
Are you by any chance adding one of those weird water emulsifiers into your fuel (not biocide bug killer) ?
#7
My only comment is that looks a very funny colour for red diesel. It almost looks like a red sleeve on a clear(ish) plastic bottle. I don't htink it is a camera thing because the red of the boat paint looks typically correct.
  • Author
#8
I put two bottles of marine 16 additive in when I filled it up.
  • Moderator
#9
I thought so too. Was the tank filled from the ketchup nozzle, instead of the diesel nozzle?
#10
Unless the tank was totally empty when you 'filled up' whatever was in the bottom few inches will still be there.
Marine 16 is the companies 'trade name' and all their products are 'labelled Marine 16'
What was the actual product you used - there are several "additives" listed on their website
#11
That bottle of fuel is SUCH a weird colour I think it warrants further investigation.
It simply doesn't look like diesel to me. I'm wondering if its been filled up with something else although I've no idea what.
  • Author
#12
I cut a piece of hep2o pipe to length and pushed it right to the bottom of the tank, so I know I’ve got to the bottom of it, so to speak.
#13
If its not diesel, it would certainly explain the engine refusing to start.
  • Author
#14
I got it from the chandlery at our marine. Definitely the right stuff for diesel bug
Just now, MtB said:
If it’s not diesel, it would certainly explain the engine refusing to start.
I filled it up at our marina.
#16
Neither of these responses actually answers the questions raised. If it isn't diesel, where you got it from isn't relevant. Similarly if you put the wrong Marine 16 in.
Thing is, we here don't need to know but you do. And your engine won't start, you say. So checking out suggestions rather than dismissing them without investigation is not going to fix it for you.
  • Author
#17
I think it’s because it’s out in the sunlight. It definitely looks like it’s emulsified.
#18
OK, but all the labels are pretty much identical except for a single line of small print.
The liquid in the 'bug killer' bottle is clear (like water)
The liquid in the "Complete" (removes lacquer and gum deposits but not 'Bug') is 'Rose' coloured
The liquid in the "Injector Cleaner"  is Very dark (black ?)
Anyway If you got to the bottom of the tank - I don't think you have water in your fuel.
#19
Water emulsified in diesel separates out after ten or 20 mins in my limited experience.
Does that bottle still look the same now? If it does then I'd suggest is not an emulsion!
Does it smell like diesel? Does a sample of it soaked into a rag ignite and burn?
#20
Which is why I asked which Marine 16 product you had used.
If you had used the emuslified additive it makes the water molecules 'stick' to the fuel so they travel thru the injectors and engine and out the exhaust.
I think it may be possible that the water in your filter could have de-emulsified / separated if it had been standing for a while.
Grasping at straws.
Does the diesel smell and feel like diesel ?
  • Author
#21
The stuff I put in was clear.
It definitely smells of diesel.
That bottle has been sitting for 3 days. I would have thought it would have separated by now. This is what came out of the primary filter. It looks pretty clear.
#22
That lurid colour puts me in mind of the social media comparisons between US and UK Fanta.
#23
YES! That's exactly what it reminds me of. They do a red one too, the exact same colour IIRC.
  • Author
#24
When I said “I got it from the marina” I thought it would be clear that I didn’t buy it from Joe blogs on the towpath. I’ve not heard of anyone else at the marina having the same problem, but most boats on here don’t move anywhere. The Webasto works fine. I would have thought, if anything, that would be the first thing to fail.
#25
When I was using an emulsifier I found that when I drained the bottom of the tank I got water, ordinary coloured diesel and some pink emulsion, nowhere near that lurid red.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
