Skip to content
2 Pack Epoxy
Featured Replies
#1
We’re looking at a boat that was grit blasted, zinc coated and 2 pack epoxied in 2022. Assuming (I know what you get from assuming but the survey will tell), that this was done properly, should we still be ok 4 years later? The blacking above the water line has not been cared for, that’s clear, and needs attention. If it all needs to be redone, what kind of bill should we expect, assuming again that it won’t need grit blasting a 2nd time? It’s a 60 foot narrowboat
Edited by Dunworkin
#2
Do you know where the zinc coating was done? If it was Debdale they recommend that after 5 years the boat should be lifted for an inspection. The zinc should be fine and the blackening is really only so your not cruising about in a zinc coloured boat.
(that’s assuming it was sprayed hot zinc)
#3
Can you explain what you mean by that? If it is battle (impact) damage and scrapes then that is to be expected, but if the blacking is falling off it calls the quality of the original job into question. As long as it is normal scapes and impact damage then we are told 2 pack epoxy can be rubbed down and touched up using the same make and brand as the original. If it is above the waterline it could be a bank side DIY job, but the paint will cost a bit.
Edited by Tony Brooks
  • Author
#4
We may find out soon, but not sure where it was done at this stage 🍷🍷
It seems just to be battle scars, no indication, at least to my novice eye, of blacking failing, peeling off etc🍷🍷
  • Administrator
#5
After 4 years it should be fine, except for mechanical damage caused by things like shopping trolleys.
Ours was initially done in 2010, (grit blast and Epidac coal tar epoxy, no Zn), checked  and repaired then overcoated in 2014, 2020 and 2025 (SML epoxy).  It is still in good order despite having done a lot of miles between 2010 and 2021.
  • Author
#6
Much appreciated. Cheers 🍷🍷
#7
Newly painted 2 pack epoxy blacking is shiny gloss black, but it does weather to a matt grey finish. This may look like neglect, especially if there are some battle scars, but the paint coating itself will be fine.
  • Author
#8
Many thanks….🍷🍷
  • 5 months later...
#9
Hi Dunworkin,
I am unsure if you brought the boat in the end but I work at Debdale Wharf Marina. If you are unsure if it was done with us, I would be more than happy to check. Please let me know the name of the boat, either via email or phone call and I will have a look if we have any records.
Our email is [email protected] or 0116 279 3034
I would be more than happy to answer any other quires or question you may have about the process )
I think the email address should be [email protected] (Adrian, on behalf of "The Mods")
Edited by Debdale
Correction to email address
#10
Not if its been protected by Dacrylate SBA
#11
Its five years since I coated my boat with two pack, it could do with coming out to get it back to a perfect finish, but its only the edge of the baseplate that actually needs sorting. The boat won't sink. I did make the mistake of touching up the scrapes in year1 before I realised the epoxy was going to fade, I now use red oxide.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
