PCSB Posted April 19 Report Posted April 19 Are there any specific "narrowboat" suppliers of anti fatigue mats. Or anyone know of a company that can provide custom sizes? None of the standard sizes are really suitable for what I want - I accept I may be being picky! TIA, Paul.
Jen-in-Wellies Posted April 19 Report Posted April 19 36 minutes ago, PCSB said: Are there any specific "narrowboat" suppliers of anti fatigue mats. Or anyone know of a company that can provide custom sizes? None of the standard sizes are really suitable for what I want - I accept I may be being picky! TIA, Paul. So what size mat do you want?
PCSB Posted April 19 Author Report Posted April 19 1 minute ago, Jen-in-Wellies said: So what size mat do you want? 130cm x 80cm and a sort of semi circle, long side appx 140cm max depth appx 50cm. If needed I'll buy bigger and cut to size, but would prefer it with neat edges! 🤣
tree monkey Posted April 19 Report Posted April 19 Learn something new everyday, I know know there's something called anti fatigue mats Handy for a long day's boating i guess 2 1
IanD Posted April 19 Report Posted April 19 1 minute ago, tree monkey said: Learn something new everyday, I know know there's something called anti fatigue mats Handy for a long day's boating i guess I've got those interlocking plastic ones (cut to fit exactly), and they are more comfortable underfoot when standing all day than a steel deck... 🙂 1
PCSB Posted April 19 Author Report Posted April 19 2 minutes ago, tree monkey said: Learn something new everyday, I know know there's something called anti fatigue mats Handy for a long day's boating i guess 🤣 they have been available for quite some time. At my old place of work in the warehouse there, all the PAT testers had them at their work stations. It will just make cruising that bit nicer! (it already is very nice tbf ... )
plato Posted April 19 Report Posted April 19 I can recommend Rubber Matting online. They have every type of rubber matting you could desire. Proper well made kit. unlike a lot of cheap knock off stuff on eBay / amazon.
cuthound Posted April 19 Report Posted April 19 1 hour ago, PCSB said: 130cm x 80cm and a sort of semi circle, long side appx 140cm max depth appx 50cm. If needed I'll buy bigger and cut to size, but would prefer it with neat edges! 🤣 Our last shareboat had a cut down section of rubber, apparently from a conveyor belt. It caused significant rusting of the stern deck because it trapped water which then couldn't dry out and eventually the mat got thrown away. By the way, it is not recommended to stand on the stern deck whilst steering (particularly when in reverse) when steering to avoid being swept into the canal right by the propellor should the rudder hit an underwater obstruction or the bank. Better to steer from inside the hatches on a trad or semi-trad boat and stand outside of the arc of the tiller on a cruiser stern. 2
PCSB Posted April 19 Author Report Posted April 19 4 minutes ago, cuthound said: Our last shareboat had a cut down section of rubber, apparently from a conveyor belt. It caused significant rusting of the stern deck because it trapped water which then couldn't dry out and eventually the mat got thrown away. By the way, it is not recommended to stand on the stern deck whilst steering (particularly when in reverse) when steering to avoid being swept into the canal right by the propellor should the rudder hit an underwater obstruction or the bank. Better to steer from inside the hatches on a trad or semi-trad boat and stand outside of the arc of the tiller on a cruiser stern. The main area is in the semi trad back as that is where I stand when steering.
cuthound Posted April 19 Report Posted April 19 (edited) 19 minutes ago, PCSB said: The main area is in the semi trad back as that is where I stand when steering. In which case a rubber mat won't cause rusting, but may rot the deckboards quicker by trapping moisture. Edited April 19 by cuthound Spillung
PCSB Posted April 19 Author Report Posted April 19 5 minutes ago, cuthound said: In which case a rubber mat won't cause rusting, but mat rot the deckboards quicker by trapping moisture. Its worth the risk for a comfier stance. Always upsides and downsides 🙂 1
Ex Brummie Posted April 19 Report Posted April 19 (edited) All the anti fatigue matting I've seen is not a solid rubber, but more of a lattice pattern. I suppose that as its primary use is in an industrial environment, liquids passing through the holes keeps it anti slip. It also allows water to escape so the rust problem is avoided. A good friend once gave me a 4 mt roll of 2 mt width. I didn't realise how good a friend he was till I checked the price on line! Edited April 19 by Ex Brummie 1
DHutch Posted April 19 Report Posted April 19 2 hours ago, tree monkey said: Learn something new everyday, I know know there's something called anti fatigue mats. Same. Aware of the concept, and have seen them in workplaces and on the back of boats, but the term is new to me. Helps particularly when the floor is cold, such a concrete warehouse floor, or in winter a steel deck. 1
CIEL Posted April 20 Report Posted April 20 These work for me cut to shape in front well deck and outside rear deck on semi-trad. However I spend most of the time when cruising sat up on the side on a cushion just inside the rear doors. Throttle between my knees and tiller nicely to hand as it just overlaps the doors. https://www.diy.com/departments/non-slip-outdoor-rubber-door-mat-door-mats-outdoor-40-x-60cm-home-entrance-mat-for-outside-porch-entrance-black/5056316705424_BQ.prd Off cuts go under the gas cylinders in the front locker and either side of the engine.
plato Posted April 20 Report Posted April 20 On 19/04/2026 at 19:34, cuthound said: Our last shareboat had a cut down section of rubber, apparently from a conveyor belt. It caused significant rusting of the stern deck because it trapped water which then couldn't dry out and eventually the mat got thrown away. By the way, it is not recommended to stand on the stern deck whilst steering (particularly when in reverse) when steering to avoid being swept into the canal right by the propellor should the rudder hit an underwater obstruction or the bank. Better to steer from inside the hatches on a trad or semi-trad boat and stand outside of the arc of the tiller on a cruiser stern. This the matting I use , it’s got small nibs on the underside. So no chance of water getting trapped and causing rust. The reason I got it was to stop the dog skidding about when he jumps on and off the boat. I would say it’s a bit comfier under foot and also safer on those frosty mornings 2
Chagall Posted April 20 Report Posted April 20 1 hour ago, plato said: This the matting I use , it’s got small nibs on the underside. So no chance of water getting trapped and causing rust. The reason I got it was to stop the dog skidding about when he jumps on and off the boat. I would say it’s a bit comfier under foot and also safer on those frosty mornings Where did you get this from please? Ive been looking for something similar. It looks like one piece so Im assuming you can cut it to size?
Jon57 Posted April 20 Report Posted April 20 41 minutes ago, Chagall said: Where did you get this from please? Ive been looking for something similar. It looks like one piece so Im assuming you can cut it to size? https://ebay.us/m/Usljuv
Cheese Posted April 20 Report Posted April 20 Look for "non-slip drainage mats" or similar. Mats with holes in are better for both the deck (by reducing / removing trapping water underneath) and for standing on (by not pooling water on top)
IanD Posted April 21 Report Posted April 21 (edited) This is the type I got which is soft underfoot and sits up from the deck in little pillars so no chance of water collection, it came direct from the manufacturer at a fraction of the cost of a chandler. They'll even send you free samples of the different colours if you can't decide which you want -- mine are light grey. https://www.versatile-flooring.co.uk/shop Edited April 21 by IanD
plato Posted April 21 Report Posted April 21 13 hours ago, Jon57 said: https://ebay.us/m/Usljuv I got it from rubber Matting online. yrs I cut it to fit and used the offcuts in the engine bay
cuthound Posted April 21 Report Posted April 21 17 hours ago, plato said: This the matting I use , it’s got small nibs on the underside. So no chance of water getting trapped and causing rust. The reason I got it was to stop the dog skidding about when he jumps on and off the boat. I would say it’s a bit comfier under foot and also safer on those frosty mornings My boat has something like that fitted to the bottom of the gas locker. It was already there when I bought it and prevents the paint on the floor being damaged when changing gas bottles. Worth it's weight in gold.
Chagall Posted April 21 Report Posted April 21 I went for one of these... https://www.amazon.co.uk/dp/B0D6FZXJKZ? . Thanks for the help.
ditchcrawler Posted April 22 Report Posted April 22 On 19/04/2026 at 19:34, cuthound said: Our last shareboat had a cut down section of rubber, apparently from a conveyor belt. It caused significant rusting of the stern deck because it trapped water which then couldn't dry out and eventually the mat got thrown away. By the way, it is not recommended to stand on the stern deck whilst steering (particularly when in reverse) when steering to avoid being swept into the canal right by the propellor should the rudder hit an underwater obstruction or the bank. Better to steer from inside the hatches on a trad or semi-trad boat and stand outside of the arc of the tiller on a cruiser stern. We had matting on the tug deck as well as the stern and found the same thing with rust under it, that was open rubber matting. It was like this
IanD Posted April 22 Report Posted April 22 The type of mat I posted doesn't seem to have any water retention/rust problems. And as well as being more comfortable underfoot with thin soles, a bonus if you're wearing boots with a chunky tread is that the nubs don't get stuck down the holes like the mats with the much bigger circular holes... 😉
