Skip to content
Bilge pump
Featured Replies
  • Author
#126
27 minutes ago, wakey_wake said:
Yes that's another way.
I'm trying to encourage some measuring to support the extended supposing...  by itself, supposing will often mislead.
100ml is the amount that comes out before the pump kicks in.
Sounds like nothing but 100ml every 27 minutes over a 24hr period 10.67ltr in total, that quite a bit
  • Author
#127
17 minutes ago, David Mack said:
It looks like there is a bulkhead between the engine space and the accommodation to the left of the calorifier in that photo. Do you have access to the bilge space the other side of that bulkhead? There may be an access hatch in the floor, possibly in the bottom of a cupboard or locker. If so is the cabin bilge dry? Or is the water level water there much the same as on the engine side? If the latter, then all you are seeing is water in the cabin bilge taking its time to flow through to the engine space bilge after you have pumped out the latter. You may need to do that several times to get rid of all the water.
The presence of such water does not necessarily indicate a current plumbing leak. It could be a past leak now repaired, or condensation which has built up over years. Or it could be stern tube leakage - the gland having been tightened since but the water not removed.
Note also that you can get water leakage into the bilges from drain pipework. Check any sink, washbasin and shower drains. Your shower drain may be fitted with a pump-in-a-box arrangement. These are notoriously unreliable and prone to leaking. A gulper type pump pumping directly from the shower tray to a skin fitting is much preferred.
Below is the bathroom set up, pump and pipework
  • Author
#128
I can't locate any access hatches in a cupboard or anywhere else to access the cabin bilge
  • Moderator
#129
The pump is a Whale Gulper. Used to empty the shower tray and chuck the used shower water overboard. Unrelated to the water supply plumbing.
The pipe and fittings are JG Guest Speedfit plastic ones. Usually very reliable for not leaking. Looks like you have a hot and a cold pipe there, with a T junction in each to send water to a sink, or shower.
#130
44 minutes ago, Memories said:
Solid wood floor no access point or inspection hatch.
I am thinking about adding some food colouring to the water tank to see if the water in the engine room under the calorifier tank changes colour
Food colouring is a good idea. It probably won't show as well as a fluorescent dye, but at least it's supposed to be safe to eat... 🙄
The pump should have a strainer before it, so maybe you can add the colour there? Better it's concentrated, because it will get diluted on the way to any leak.
Strainer is a coarse filter to keep muck out of the pump. Like these https://www.midlandchandlers.co.uk/search?query=pump+strainer
However if you've had no luck spotting leaks with white kitchen paper or similar, then you're at a disadvantage for spotting a coloured leak in a mucky bilge. It also points to the water being not from the domestic water supply, so colouring may be a waste of time especially if the test leaves you in some doubt.
As David suggests, it's normal to need an access hatch.
Unfortunately this can mean cutting a new one, if there really isn't one.
Is it less normal to have a cabin bilge access hatch on an all-in-one-bilge boat?
  • Author
#131
But no leak. You're knowledgeable Jen.
 I did check to see if the water from the shower try was actually being pumped off boat or into the cabin bilge but it does get pumped off boat.
  • Author
#132
My pump doesn't have one of those filters on it, unless I am missing it, layout pictured below
  • Author
#134
4 minutes ago, Jen-in-Wellies said:
You are right. No prestrainer. Straight from the tank, with a stop valve.
Yep. The main plumbing line feeds into a filter on the the bulkhead of the cabin.
That is where one of the leaks was in the bow, it's fixed now.
#135
Yes, except in the case of central heating radiators being present.
Mine has four pipes in parallel along the floorboard, in places. Two for radiator flow and return (not insulated) and two for domestic cold and hot (both with foam insulation).
All have isolators at useful intervals, and two or three of those (1990s Acorn plumbing, an early Speedifit) have turned out to have through-leaks.
Any fitting that carries water can leak. As an alternative to kitchen paper around joints (as above), laying some "blue roll" under it can help. Any water will leave telltale marks.
I see you've used puppy pads. I know they'll hold water off the surface below, at least for a while. I don't know if they work well as a telltale for ever becoming wet.
Unfortunately looks like you are correct. I am assuming the steel panel behind the jerry can is your water tank.
Consider the rust which is most likely in the bottom of the water tank. Sooner or later it will kill the pump.
When you fit those flexible hoses would be a good time to add the strainer. You might also want a filter such as https://www.midlandchandlers.co.uk/products/jabsco-filter-aquafilter-complete-508760 but they're not essential.
  • Author
#136
There is a filter after but not before, so yes the rust from the tank will sooner or later get into the pump, but I HAVE A SPARE!
Taking the T off again is not something I want to be doing again in a rush, it resulted in me having to replumb the lot because the speedfits just would not release so I had to resort to cutting it out, so had to re-do the lot.
Puppy pad.
That is simply there to catch any water just incase my repair wasn't good, but that and initially tissue paper on the connectors showed no further leak from there, I left the pad there as a just in case thing, they are absorbent and hold quite a bit of liquid before they start breaking down.
I am pretty confident that the leak in the bow area is sorted.
Just the rest.
Someone threw another spanner in the works, just to befuddle me even more by saying it could be that the diaphragm on the pump may be shot, that along with my leaky taps could well be the problem. Just to confuse me further.
#137
Don't assume because your pump runs occasionally you have an external leak... If the NRV in the pump head weeps you will loose pressure back to the water tank...
#138
2 hours ago, Memories said:
The pump kicks in and immediately stops, kicks in every 27 minutes.
That suggests the accumulator air pressure may be low, but you need to cure the tap drips first.
Also note that the valves in the water pump may well not make a 100% seal, so some loss of pressure may be caused by this.
Window are ok,
Oh boy, how many times have we heard that. Windows and vents are prone to develop leaks between the frames and cabin side/roof. I have no idea how you can know they are OK unless you have stripped a lot of cabin lining out. I am not suggesting that you do that, just trying to get you to grasp that the windows might well be leaking.
#139
An excellent way to ensure that whatever breaks will be .. something else. 😉
Yes I had not thought of the pump diaphragm or NRV leaking backwards. You can rule these out by waiting the 27 minute cycle for a run, then turning off the stop tap before the pump.
May be best to stand by to open it. I'm not sure what the pump will make of a vacuum?
Where are the next stop taps / isolators downstream of the pump? And in relation to that, the next tee off?
  • Author
#140
Accepted
#141
I thought it looked as if it might be a timber bulkhead and if so it may well have limber holes in it to let water find its way to the back. We really need the OP to investigate and confirm if it is totally sealed to the hull or if it has limber holes/does not reach the baseplate.
Are you aware that Speedfit sell a tool to help get them to release. You half turn what looks like a compression nut and the push the protruding "ring" around the pipe into the fitting. The tool helps you do that. This releases the grab ring (in theory!)
The outlet for hot water IS in the off position, the lever at the top up for on down for off.
Does that make a difference?
IF (note it is a big if), the calorifier is leaking simply turning the outlet off will NOT help. The inlet to the calorifier needs turning off so it is not pressurised by the pump.
#142
One drip every 4 seconds, how fast are your two taps dripping
#143
Too much assumption and lack of inspection to confirm or deny those assumptions in my view.
  • Author
#144
The fact that the calorifier tank is off, I am right in saying this rules out a leak from the tank?
If that is the case, then it has to be from the inlet pipe to it doesn't it, excluding window leaks and vent leaks, the vents did leak a while ago but I sorted that and it was well before we had the recent rain and storms.
The shower room is dry as seen in the picture uploaded, the bow is dry, at least now it is, so the only other leak has to be the pipework connected to the calorifier.
That is my view, I do accept it maybe a window or a vent, the water that accumulates under the tank is clear too, at least when I look at it before sucking it up with the vac, so canal water is, for the moment, ruled out.
Time to vac it out again and see how much I get today compared with yesterday.
  • Author
#145
The bulkhead between the engine room and the cabin is metal, it has just had wood trim put on it. I only know that because I tried drilling a hole to add an electric socket in the bedroom but it is metal so didn't proceed. By the way, I wasn't fitting the socket.
  • Moderator
#146
It does not. The calorifier will still likely have pressurised water in it from the cold water inlet near the base. There may be another valve to isolate the cold inlet from the calorifier. The only valve in the photo is on the hot water outlet.
  • Author
#147
There are no stop taps on the boat that I have located, I put one in when I plumbed everything back in but honestly can't say I have seen any others, so that means the washing machine would be the first thing to have water input, after that would be the kitchen taps.
I copied the connections that were already there, I didn't know any other way to do it but was surprised that there was no shut off valve for the water after the pump, that's why I added one.
#148
The other possibility is that the pipes/hoses which carry cooling water from the engine to the calorifier coil are leaking. Should be easy to check as they are fairly accessible, and if they are leaking the water level in the engine header tank will be dropping.
  • Author
#149
The bulkhead is definitely steel, I will go find an input shut off valve then for the calorifier.
I got some of those plastic tools to remove speedfit connectors from Screwfix they wouldn't fit, yes I did use the correct 15mm one it is blue the two arms wouldn't go over the twist part of the speedfits, I then went to Toolstation and theirs are a bit better but couldn't get it off.
  • Author
#150
Not that fast
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
