Skip to content
Bilge pump
Featured Replies
#76
1 minute ago, Tony Brooks said:
If you have no calorifier then you won't have a PRV.
I thought the photo was of a grey accumulator.
You have told the op about your wonderful website with loads of good info
  • Author
#77
I do have a calorifier, the tank in the engine bay tells me that, the grey bell housing is part of that I am told, so I will have a PRV, however, just because I have one does not necessarily follow that it is working or even connected up correctly
Investigation ongoing..,...
  • Author
#78
Tonka wrote something about an accumulator, I can't read his full post for some reason, can't even see it when he click to go to the post.
Anyway, yes, someone else said the grey bell looking think in the bow is an accumulator, which is part of the calorifier system.
If that isn't right then I would like to know what it is
14 hours ago, David Mack said:
But you can't sink it since the water is already in the boat.
#81
1 hour ago, Memories said:
With land based property the seller by law must provide a survey, and give full disclosure, that's not the case with boats Alan
I think you may have been listening to the wrong people again.
In Scotland sellers have to provide a 'Home Report'
Not in England (according to many sites on the interweb) : example
Not a legal requirement
Edited by Alan de Enfield
  • Author
#82
Ok maybe not a survey but....
Seller's Role: While sellers do not provide surveys, they are legally obliged to disclose known defects and "material facts" through the TA6 Property Information Form. This form covers details like:
  • Structural movement or past repairs for subsidence.
  • Issues with damp, rot, or woodworm.
  • Information on boundaries, shared areas, and disputes.
  • Planning permissions and building control certificates for any alterations.
#83
Which is not what you said ! You specifically said a survey is legally required.
And the answers to the TA6 are :
Non known
Non known
Not known
Non known
which is exactly what you will get on your boat buyers details form.
Brokers are very careful in their advertising so they do not have to admit to any known problems and will typically say :
Boatshed
The particulars detailed herein are intended to give a fair description of the vessel but their accuracy cannot be guaranteed, these particulars are not a part of any contract or offer and are supplied on the understanding that all negotiations shall be through Boatshed Brokerages, who are acting as brokers for the vendor. The vendor is not selling in the course of a business unless otherwise stated. The prospective purchaser is strongly recommended to check the particulars and where appropriate, at his own expense, to employ qualified agents to carry out surveys, structural and/or mechanical & electrical.
ABNB
PLEASE NOTE: This is sales information and not a survey report; providing content details only. The specification in these pages is based on ABNB's visit to the boat and on information given by the owner. This is to help you decide whether to investigate the boat further, be it by surveyor or otherwise. The information here is given in good faith but no description, statement, promise of work to be done, or suggestion for future use, constitutes an offer. If the craft leaves the UK, any necessary VAT paid status may not be available.
If you are not happy with this, then only buy from a dealer, or broker who owns the boat and is not acting on behalf of the owner.
You will then get the full might of the law on your side - including a full money back guarantee.
#84
Clearly you know nothing about houses when you put a statement about damp, rot or woodworm
  • Author
#85
Non known
Non known
Not known
Non known
Boatshed
ABNB
My basic point was that boat buyers have no protection whereas land based property buyers do. Which means they have a way of bringing the rip off merchants to book, whereas boat buyers seemingly do not.
Anyway.
It was just a frustrated observation.
Not getting bogged down with it.
My current issues are mine to deal with, I just hope the seller drops dead, not that I'm in anyway vindictive.👿
  • Author
#86
That has to be proved that the seller knew about it and didn't disclose it, I get that, it is all about honesty isn't it, but unfortunately not many people are honest when selling things on.
#87
The tank, pump and accumulator that you have at the bow would be needed to give a cold water supply even if you did not have a calorifier.  It would be used to supply cold water and water to be heated either in a calorifier tank, or a water heater as Tony mentioned.
I think you mentioned before Christmas that while you had a calorifier tank at the back of the boat it was disconnected:
If that is still disconnected then it won't be the source of the leak you are looking for as it won't be pressurised.  Perhaps you will find there is pipework that previously served a calorifier that is closed off by a leaky end stop or valve, but if the hot water tank isn't pressurised then the problem cannot be a PRV leaking.
#88
No it's all a con by the damp wally brigade. Surveyors using meters designed to measure logs is a con. Con men telling you you need a damp course and using the wrong materials. Spraying chemicals in your house you don't need. Mortgage people insisting you need it  which you don't. All a con..
And you believe this is OK and want something similar in the boat buying process.
#89
If you are buying a new boat, you have the same protection under consumer laws as when buying any new product. If you are buying a second hand boat, you have the same protection as when buying any other second hand product. Why should boats be a special case?
#90
Though that doesn't seem to be helping some recent buyers of new O***ums electric narrowboats... 😞
#91
There are also loads of new house buyers would like help with their claims as well
  • Author
#92
I will find out properly in about two hours, never used the calorifier for hot water always used my boiler.
I have attached a picture of the set up in the bow.
Now, the white plastic T connector from left to right is as follows furthest left is the connection to the water pump, coming in from the top is the accumulator or as I described it a grey thing that looks like a bell housing, then the last connection is the main line into the boat that feeds the plumbing in the boat.
Now as for correct terminology, I most probably have that wrong as I have no clue, but that is the set up in the bow. I know that is the case, because I ripped it out and replaced it as there was no other way to do it, the speedfit connectors wouldn't release, so I took it all out and started again.
The white puppy pad is there to check my work and catch any drips.
That all seems ok now.
But, there is still a leak from the calorifier pipes, tank, connections or Pressure Release Valve, that's where my investigations will be focused this afternoon.
I don't profess to know what I am doing, because I don't, I am winging it because I have no option.
  • Author
#93
Some protection is better than non though surely.
Yes, I agree it's all a rip off and the buyer is always the one who is left holding the bills and headaches.
#94
If buying a secondhand boat owned by a business (rather than a private sale) then you have full legal protection, with all the comsumer rights and legislation.
  • Author
#95
Because they are homes.
  • Author
#96
But not if you purchase a boat through a broker?
Anyway this is a distraction from what I am doing. Not dismissing you or anyone else but this isn't going to help me resolve my leak.
#97
A RICS approved survey is the biggest con of all and offers no protection. Good luck with finding the leak
#98
Exactly, if you are buying from a broker representing a private seller you have no protection at all - just as If I just answer a "House for sale" postcard stuck in the newsagents window, walk up to the house, hand over the money and take possession. No lawyers, no surveys, no guarantees.
If the broker is selling a boat owned by the broker (which few admit to ) then you have legal pretection.
If you are so risk averse that you will only buy a boat with a guarantee then buy it from a business that owns boats.
#99
No they are not!
SOME boats are homes, but they were never intended to be so.
The vast majority of boats are NOT homes. More are used as homes on inland waterways than on the ocean. A quick visit to the several Marina's up the Hamble river will soon show how few are homes.
  • Author
#100
Ok guys and gals, pictured is my calorifier tank? In the engine bay so where do I start looking for this pesky leak?
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
