Hi all,
I'm looking for advice on some high efficiency (so would ideally be lower power) 12V work lights to put up temporarily, and to be run from a portable battery, as you might in a boat you were refurbishing or in a (roughly car garage sized) outbuilding that didn't have mains or generator power. The light would have to be good enough for doing some light maintenance work, sorting though things etc.
I don't mind paying a bit for something that was 'good', especially on the energy use and so potential battery life (be it LA or Li etc). I think something that could be connected to an external battery might be preferred over something stand-alone, unless it had a really good battery (at least 8 hours runtime and rechargeable etc).
I know you guys can be imaginative re finding something designed for another purpose but that turns out to be really effective whilst being cheaper than more typical / focussed solutions etc. 😉
I just use  mains 24W batten LED 5ft 'flourescent' fittings, small sine wave inverter (300W) and an old leisure battery.  Think the LED battens were £15 quid or something from CPC or screwfix , had the little inverter and LA battery, which i either take home to charge or charge when i'm running the gennie, haven't got around to solar  for the shed yet. A small lithium battery would be even better but my old but in reasonable state 85AH leisure battery runs my lights and radio/charges my radio battery for ages ...
Thanks for the prompt reply.
Whilst I get that your solution probably works well enough, would it likely to be as efficient as say it all; being just 12V and LED? I mean, there would be losses in the inverter but they could well be offset by any electronic shenanigans there might be in say a 5' LED strip lamp? If we end up with say 4 x strop lamp, the single inverter could win? <shrug>
26 minutes ago, T_i_m said:
Hi all,
Have you considered an LED head torch? The light is always on the thing you are looking at, and some have variable brightness and zoom, and multi hour lifetimes from a rechargeable battery.  I have been impressed by the LED Lenser one that I've had for over ten years.
well it draws a little over 4A maybe 4.5A running two batten fittings so i reckon thats pretty damn efficient and more importantly they are just like proper mains lights... because well thats what they are...
The other advantage (for me) is that if i'm running my generator i just plug them into that and charge the battery for when i switch the noisy beast off
Edited by jonathanA
add a bit
6 minutes ago, Ex Brummie said:
All your rechargeable lamps can be run off a power pack to supplement the internal batteries. I have a Parkside from Lidl that is similar to <trim link>
Mine has two lights on it, one each side so it works as a hanging lamp, or a full floodlight using the tripod it came with. It charges from a USB socket and will run plugged in. Also it was only £20 or so.
Assuming the Lidl and Amazon versions share the same internals the Amazon one says "Full charge for 4.5Hrs then lasts for 2.2Hrs at high mode and 5.5Hrs at low mode." so I think something like that would have a place, especially as it would be light enough to carry home between uses for recharging but not sure if it would tick all the boxes completely.
How usable is the lower light mode and on yours, can you have only one light on, if say you were to magnet it onto a roof beam horizontally? Or would you set it so the lights were illuminating horizontally, even if much of each beam was lighting up the ceiling (that's sometimes good if the ceiling was reflective etc)?
Yes, I was using one the other day in fact when working on the oven and they are very good for the reasons you say.
However, I think it would still be good to not be working in the space not illuminated in general, all be it only a lower level where the head torch could add more focused light.
The one I used has a flexible LED strip that covers a good width of your forehead and so helps spread the light in all directions. I've has a couple of Petzel head torches for many years now, the ones with the retractable and self tensioning headband.
On mine, the lamps are either side of the tube, and both are very bright. In a confined space, you only use 1 lamp, but both if you want to light a room .
An alternative would be one of the screwfix mains lamps run off an inverter. You would probably get away with just a 75watt inverter.
LAP KF440 from Screwfix is only a tenner .
Edited by Ex Brummie
Thanks for that.
So if I was to use one of the 3Ah sealed LA (mobility / semi-traction) batteries I have, that would be roughly 5Ah down to 50% capacity and so around 3 hours runtime?
I get the flexibility and the use of the genny but that wouldn't be the case here (too residential).
I do have a 5' flouro I was about to dump but I wonder how the energy use compares / lumen between that with an inverter or an LED conversion?
Is there a digit missing off the 3Ah ?
If you are suggesting a lamp drawing 5A for 3 hours that would be 15Ah  and if that is taking the battery down to 50% SoC then presumambly it is a 30Ah battery ?
12 minutes ago, T_i_m said:
Thanks for that.
good question... Seem to think 5ft flouros where about 35 or 40 w ? not sure.  when i replaced my 5ft florescents in the garage at home with LED versions i didn't notice any difference, other than instant start up and never having to change those blasted starters when they starting flickering/not starting...
i have a feeling LEDs are still trying to catch up in terms of light output per watt in, compared to fluorescents but i could be completely wrong on that and suspect if you pay more you get more efficient LEDS. if you have the bits i'd try the old fittings and see how they do. i'm just thinking about all the waste in the ballast of an old fashioned fitting. would it matter ?
Edited by jonathanA
tidy up
Good catch. 😉
I also noticed the near instant start-up of LED strip lights as most of my lights are enabled by my Home Automation system via PIRs. Previously you would be halfway across the kitchen before the flouros had started up, with the LED conversions they are on as you step into the room. 😉
I think when I did the LED conversions I bypassed both the starter and ballast so basically just using the hardware to support the LED tube.
OK I might have misunderstood and thought you meant you were going to use traditional (non led) fluorescent fittings. If they have led tubes already, it would be a nobrainer to use them to me.
  • 3 weeks later...
Just as a bit of an update, I bought a couple of 4' LED strip-lights from Wickes on a bit of a whim, stuck 5m of Arctic flex and plug on them and initially hung one under the ceiling joist of the garage and am very impressed with the light output.
They have a 2 way DIP switch inside that gives you 37, 32, 27 and 21W input options (along with another switch for 3 colour temperatures) and a quick test of one set at 37W versus the other set at 21 suggests that but for the most detailed work, the energy saving is likely to be worth it for the increased (nearly doubled) run-time, especially when running from a tiny (128Wh) portable power solution (Bluetti Elite 10).
From further investigation it seems I could save 10-20% on the energy used if I could stay with 12V DC (no inverter / 230V to low(er) voltage loss etc), if I can find a longish 12V ~2000 lumen strip-lamp but I might be able to offset the need by the use of a (60W) solar panel, if there on a sunny morning through to the evening.
Edited by T_i_m
Head torches, excellent, I have just bought an Aldi worklight, LED, about 2.5 hours battery life on high output, less on 2 other modes, 2 sorts excellent, Faced with the same problem on providing mains leccy to a remote shed I bought an Aferity? power station, 2.4Kw, really good supply for lights, power tools, recharged via mains or in my case solar panels, excellent solution, it's heavy though, several variations in power output and makers, prices variable. Highly recommended.
I got a battery operated headlight  from the market, a little stall with high quality camping goods, I think it was about £8.00. branded but no box. It has several modes including red, which I could use when walking home in the dark.
I have two big battery operated PIR lights, one is sittinng outdoors and very bright if anyone tried to board. They are in year2 , batteries are expensive but long lasting.
I'm going to buy a nice camping lantern, dimmable which will just provide a background light overnight, also has very bright and a warm white option. Same size batteries as the pir.. I try to keep my boat batteries well charged, its a lot cheaper than replacing them every two or three years.
I have thought about the magnetic LED worklights, handy on a steel boat.
Edited by LadyG
If you walk along with a headlight on keep it tilted down. Nothing worse than some pillock come towards looking at you and dazzling you. Vehicle headlights are bad enough in broad daylight as well now. :banghead:
We have used head torches when doing quick jobs in there and whilst they work, they can be a pain if there are more than one of you re shining in each others eyes and missing stuff on the floor when not looking down when moving, especially when in enclosed spaces between storage racks etc.
I keep getting the Aferity? ads when I try to look at stuff on Youtube and they run for over 3 minutes!
I have ordered one of the baby Bluetti Elite 10 128Wh portable PSUs because we often go to the unit on foot and so can't really carry something too big / heavy (like my Bluetti AC180). I also have an EB3A (600W 268Wh) that was able to run my 200W Multitool round there.
Yeah, and looking at each other (especially to start with) when wearing a head-torch is easy to do, till you get used to it.
And 100% on some of the blinding car headlights. Basically, cars are meant to run humans about and so should do so in a way that is compatible with humans. So the forces, the noises, the temperatures and the lighting should all be set in a range compatible with humans and the headlights often aren't.
Worse when someone has parked up on the wrong side of the road, often in a tall / SUV and leaving the headlights on, even only with dipped beam but they are then dipped into our eyes. ;-(
I have a couple of 'lantern' style lamps, LED and powered by 3 x D cells but they aren't good at being torches as the light is emitted all round and so also in your eyes. They work ok when the light is shielded on one side or hung up high etc.
