Hi,
 I’m about to put in the connections on a solid fuel back boiler. It’s a few years since I did much plumbing so I’m wondering what the best threaded joint sealer is. I always used Boss White or PTFE tape, but I see there is now liquid PTFE and several silicone concoctions available.  Has anyone any recommendations?
cheers!
PTFE would be up to the job, but if you do decide on any of the 'plastic' solution sealants, be sure to check the temperature ratings. Those fittings on a stove boiler can get very hot.
Tru Blu works well, but requires 24 h to set before it can be used. Heldite is also good, but, like Boss White and hemp sets very hard.
I would stick to ptfe tape, in the interests of dismantlability.  The gas rated stuff is a bit thicker which can be handy if both the threads are parallel.
15 hours ago, jonesthenuke said:
PTFE tape is awful stuff. I would use boss white and hemp.
Until it gets baked on this type of joint, and the potential for vibration causes cracks and the hemp fibres actas wicks.
I would also use more wraps of standard PTFE rather than the gas type .
Hawk Red type A or B are good for high temperatures (600°C ), but are not cheap, and are not suitable for potable water pipework.  It pays to shop around: my 60-year-old tin of type B has gone hard, and I was  searching on line for some a few minutes ago. Prices asked varied from around £25 to more than £120 for the same size of tin.
If his boiler gets to 600° he will be in trouble. All this high performance are we talking about a super heated steam system  or a didely back boiler and a couple of rads at atmospheric pressure
Gas PTFE tape in the yellow rolls is good stuff. Never had a problem with it. You just have to remember to wind it in the male thread direction so the female doesn't take it off.
Edited by blackrose
