The bathroom mirror on my Aqualine narrowboat is cracked and I want to replace it. However, I can't fathom out how to access it, it's in a wood surround and there's no sign of screw covers or clips. Being Aqualine, I'm sure there some smart way of concealing everything.
Drilled and plugged? Look for slightly fainter circular areas or circles of grain that don't marry up.
Or, it could be hung on concealed keyhole brackets, try pushing the entire thing upwards.
Or, worst case, it's just glued to the bulkhead :(
If it's held on with double-sided sticky foam tape -- which works surprisingly well, especially where there's vibration around like on a boat -- it shouldn't be too difficult to remove and replace after repairing it.
The lower surround appears to be sat on the granite top, the upper surround against the strip light ceiling, the left surround butt's against the side panel and the right surround butt's against the wall panel.
If I was being cynical - I'd say keyhole brackets and the strip light added later! (First rule of DIY, never consider those who come after...)
Sounds very plausible. Or even installed at the same time, but in the "correct" order.
Edit: One of my go-to techniques in situations like this is to start dismantling any adjacent fittings that can be dismantled and might conceal a fixing.
Edited by Wafi
If I was being cynical -- I'd say double-side sticky is quicker and easier and cheaper than keyhole brackets... (same rule!)
If i was being extra cynical -- I'd say why source some double-sided sticky tape when you've got a tube of Sikaflex/Gripfill/NoMoreNails etc. sat right there from some other part of the fitout... (same rule with bells on!) :D
However you then need to find a way of holding the mirror in place until the goo dries... 😉
24 minutes ago, MrsM said:
And when you get it off you still have to deal with the seven years of bad luck! 🤞🍀😄
Its just started with him trying to fix it
1 minute ago, Jen-in-Wellies said:
If he has gaffer tape, why need anything else? 😀
Well leaves a big black streak across his mirror some wide sellotape or greenhouse glass tape would cover the crack ...
Coat if I've misread...
You could try phoning The New & Used Boat Co [ Aqualine] and ask them how its been fitted.
Other colours of gaffer tape are available. Colour coordination wirh the bathroom decor theme is possible. Not just black. Apologies, just my sense of himour.
Why not just cover the mirror with a picture of yourself with a clean shaven face and perfect completion. Hair neatly groomed. Big smile showing you lovely white teeth. It would save you a lot of time on a morning and start your day of on a high. 😁
  • Haha 2
Or the face of someone better looking entirely. There is only so much that can be done to gild the lily. 😁
Just pinch a photo from the local barbers shop. I never come out looking like the one I told the barber I what that style. 😁
31 minutes ago, Peanut said:
Or.... Just stick another mirror, the same size, over the top. 😀
Good idea.
But make it slightly smaller, given the old, close-fitting one cracked!
Edited by MtB
sp
1 hour ago, system 4-50 said:
or your avatar?
I am considered by other Morlocks to be very pretty, I'll have you know. The pointiness of my teeth, the blueness of my skin. All are features other, less lucky Morlocks envy.
Don't you also need a hammer to fix the faults that gaffer tape can't? :)
