Cheshire cat Posted April 3 Report Posted April 3 I'm exploring the idea of a macerator toilet. Looking at the Leesan site they sell standard height toilets and lower height ones. Is it simply a case of the lower height ones being meant to be positioned on a plinth/step or am I missing something?
matty40s Posted April 3 Report Posted April 3 If you've missed it, it doesnt matter whether it's on a plinth or not. 1 1
pearley Posted April 4 Report Posted April 4 As you get older you'll wish you bought the higher one. 2
Tonka Posted April 4 Report Posted April 4 Are you looking forward to working in the S??t when something blocks the blades 1
jonathanA Posted April 4 Report Posted April 4 4 hours ago, Tonka said: Are you looking forward to working in the S??t when something blocks the blades As opposed to talking it....😁
MtB Posted April 4 Report Posted April 4 I suspect the 'low' option is to account for mounting of the contraption on top of the holding tank. But I know nothing about them really. Maybe you can tell!
David Mack Posted April 4 Report Posted April 4 22 minutes ago, MtB said: I suspect the 'low' option is to account for mounting of the contraption on top of the holding tank. Or in small boat-shaped boats where the hull sides curve in above internal floor level.
Cheshire cat Posted April 4 Author Report Posted April 4 Sensible suggestion from David but seems like no one really knows. I was wondering if the lower height ones allow for the use of a plinth which could house the plumbing. I shall have to talk to Leesan. I'm not worried about dealing with blockages. It's only processed food.
magnetman Posted April 4 Report Posted April 4 I feel that Lee Sanitation became too successful and degraded the quality of their products for financial advantage. Not sure how many competitors there are but its a crap situation if nobody else is dealing with this sort of shit.
jonathanA Posted April 4 Report Posted April 4 2 hours ago, Cheshire cat said: Sensible suggestion from David but seems like no one really knows. I was wondering if the lower height ones allow for the use of a plinth which could house the plumbing. I shall have to talk to Leesan. I'm not worried about dealing with blockages. It's only processed food. I'd speak to Leesan, they are usually very helpful. Plumbing tends to be round the back rather than underneath so doubt you will need a plinth for the plumbing etc.
ditchcrawler Posted April 4 Report Posted April 4 19 minutes ago, jonathanA said: I'd speak to Leesan, they are usually very helpful. Plumbing tends to be round the back rather than underneath so doubt you will need a plinth for the plumbing etc. I think the comment about boat shaped boats was correct for the heads .
pearley Posted April 4 Report Posted April 4 When we had our first narrowboat built I measured the height of our WC at home and asked for to be the same on the boat. This meant a 40mm high plinth was needed under the bowl (Domestic Vacuflush) This made the seat about 18 inches above the floor. When your knees start giving up you will appreciate the extra. However, if you have a shorter partner then you may have to compromise.
cuthound Posted April 4 Report Posted April 4 9 hours ago, Tonka said: Are you looking forward to working in the S??t when something blocks the blades I've had one for 11 years now and never had a blockage. I do however instruct the crew not to put anything down it that they haven't previously eaten unless it is toilet paper. Let's hope I'm not tempting fate with this post... 🤣
ditchcrawler Posted April 4 Report Posted April 4 (edited) 4 hours ago, cuthound said: I've had one for 11 years now and never had a blockage. I do however instruct the crew not to put anything down it that they haven't previously eaten unless it is toilet paper. Let's hope I'm not tempting fate with this post... 🤣 I spent half the morning with drain rods, plunger, hose because the upstairs loo here in the house blocked up this morning Edited April 4 by ditchcrawler Spilling
