Lots of railway lines run near the canals as they shared a common problem, Canal don't like hills and neither did early Railways trains, so there is a tendency to find them following similar routes.
In one of the groups on Facebook it was suggested that we should includes railway stations that are near the canals on our maps. We had used railway stations in the past as good places to meet up with people coming onboard for this very reason, so this started a new set of locations to add to the maps.
So far we have added 290 railway stations that are near enough to the canals to be useful, they have been added to the Everything Map and any other maps of individual canals, I will update the canal rings maps as I get time.
You've missed all the stations on the Upper Gr Ouse, Bedford, St Neots, Huntingdon etc
Aylesbury on the GU
Wellingborough and Wansford 🫣 on the Nene
Aylesbury on the GU
Thank you, working on it...
D
Of course just being close to a railway station doesn't necessarily mean one can get a train to where one needs to go!
This may improve with HS2 - if boaters stuck in Birmingham need to get to Old Oak Common?
Thank you this really is helpful. It maybe a lot to ask. How difficult would it be to add bus routes/stops.
Edited by Naartjie AKA Duck Hatch
I will take a look to see what I can find, I may be able to add major bus stations?
D
18 hours ago, hider said:
Cheddleton?
Fine, except for the fact its on an isolated heritage railway with no connection to the national network.
Still a nice day out though.
D
If you zoom in far enough the bus stops are visible on the base map that you are using, e.g. at Braunston:
An alternative that Naartjie might find useful is a separate Bus Checker app that can also give route information, and real time information on when the next bus will arrive (always reassuring in remote rural locations). An example is: http://buschecker.co.uk/#download
That is I made it green.. it is also on the things to see map
If you're going to put Cheddleton on, surely you also need Froghall, which is only a short walk from the moorings before the tunnel.
Excellent idea, done 🙂
Bus routes and times change too often for the information to be usefully added to a site like the OP's. Far better to use a public transport route finder like https://www.traveline.info/ or Google Maps to plan a particular journey. Both have rail and bus services so will find bus, train (including underground and tram services) and mixed mode journey options.
Not sure anything has changed with respect to gradients on railways.
Please consider adding  Brigg, Hull and Beverley and Driffield
Long Eaton is not far from the Erewash. Likewise Ilkeston. What about Beeston? Wilncote is the nearest station to Fazeley junction. There are two stations in Rugeley Trent Valley and Town. Also Lichfield. You've missed Coventry. Don't be tempted to add Polesworth - it may have a station but only one train a week stops there!! Also the three main stations in Birmingham plus others in the surrounding area.
For Heritage railways there is Loughborough Central, and Shenton Market Bosworth and Shackerstone on the Battlefield line.
Radcliffe on Trent may be near the river Trent but access to it from the river is not possible.
Edited by Richard T
Thanks, very useful
D
Many former London & North Railway routes have ruling gradients of 1:330 (16 ft per mile) but a new high speed line is akin to a motorway and will have gradients as steep as 1:40.
The momentum of a train travelling at 300kph makes this tolerable for quite long distances.
Edited by BCN Challenge
13 minutes ago, BCN Challenge said:
Many former London & North Railway routes have ruling gradients of 1:330 (16 ft per mile) but a new high speed line is akin to a motorway and will have gradients maybe as severe as 1:20.
Must be a bugger if the train has to slow down stop or the wrong sort of leaves fall off the trees.
And Consall can't get one any closer !
I see bus stops and railway stations on my map, canalplan ac
Edited by LadyG
You show only Worcester Shrub Hill, but it might also be worth showing Worcester Foregate St, as they don;t always share services.
(There is now also Worcester Parkway, but it it is well out of town!)
