Bullet points showing new posts are variable in size, some normal sized, others, incy wincy, like a full stop.
  • 2 weeks later...
Thanks for the great help, my android tablet is unaffected.
It is all my fault for running Linux, on a ThinkPad, clearly I should be using Windows or use a machine running BSD with a fruit skin.
After about 25 years of using Linux, I'm unlikely to change, and will put up with the inconsistent behaviour. Maybe something to do with circle or star.
FWIW, I run Linux (Mint) and it rarely does what you describe. Very occasionally I do get an odd text size in posts, but I think that may be to do with how the sender composed the text. I think that if they composed it in (say) a word processor and copies and pasts it into the forum, it might also import the font and size. Been using a variety of Thinkpads for years, in fact, I think I am right in saying that Lenovo are one of the few who are willing to supply computers with Linux pre-installed.
Edited by Tony Brooks
Yes, it used to be common, but now you rarely get problems. I find that eventually the glitch goes away, as iterative updates are made, without even noticing what did it.
Lenovo and others, have produced laptops with Linux pre-installed, but they are usually poor value, as opposed to installing your own distribution. It gives you the option to dual boot, or as I do, wipe the disk for a clean instal. Most problems will show up on initial instal, and are often hardware, or networking related. All usually fixed easily, or unsupported hardware.
The main distributions are now easier to install than Windows, and are well-supported, but still bloated, to cover all types of user.
I also let the Linux install wipe the disc so no MS stuff is around to cause problems, I can't be doing with dual boot and find Wine runs those MS programs, all old now, that I need to run to access older files.
I couldn't agree more, I make clean instal on a formatted disk. You had to use fdisk and manually petition the drive, but the installer will do it all for you now.
