RickS Posted September 1, 2024 Report Posted September 1, 2024 Is there a knack to opening lift the dot fasteners please? Trying to unfasten the front of my cratch cover and some are coming off and some aren't. Don't want to get medieval and get a screwdriver/claw hammer behind them so thought I'd ask Ta
Naughty Cal Posted September 1, 2024 Report Posted September 1, 2024 Once you have got them off apply some vaseline. They get stuck if not used for a while.
PeterF Posted September 1, 2024 Report Posted September 1, 2024 I use muc off dry lube on mine, seems to work and unlike grease does not trap dust. However, it does need reapplication from time to time. https://www.halfords.com/cycling/bike-maintenance/bike-lube/muc-off-dry-lube-bike-lubricant---120ml-955310.html
BEngo Posted September 1, 2024 Report Posted September 1, 2024 Give the reluctant ones a tiny squirt of Plus Gas onto each pin and round the hole. Leave for a while then work them gently up and down at the ends. You are trying to free off the hairpin spring inside the moving part. N
nealeST Posted September 2, 2024 Report Posted September 2, 2024 11 hours ago, PeterF said: muc off dry lube on mine Great tip. I have these fasteners on my ‘59 Triumph TR…wasn’t aware of this product..lift the dot are fiddly.
carlt Posted September 2, 2024 Report Posted September 2, 2024 After lack of use the springs inside the female half often seize, dislodge or snap. You can buy new ones from J Clarke Marine.
RickS Posted September 5, 2024 Author Report Posted September 5, 2024 Thanks all. I used a screwdriver in the end to get a better angle and gently pried off the stubborn ones. Good tip about Vaseline, ta
Mad Harold Posted September 5, 2024 Report Posted September 5, 2024 They can be fitted upside down, as I found on a recently purchased boat. Instead of lifting the dot, it was necessary to "pull the dot" from above.
