Maudesmaster Posted July 30, 2024 Report Posted July 30, 2024 Looking for a banjo 5/8” bolt size 1/4” pipe hole looking to purchase new or used cannot find in www Making new pipe up as original when bought engine had a soldered sleeve which j have re soldered twice I have the pipe and have flared end I don’t want to take original off and reuse until new pipe stood the test of time thank you in advance
Split Pin Posted July 30, 2024 Report Posted July 30, 2024 Search Stafford Vehicle components Fuel pump supplies you will find a variety of sizes Steven
David Mack Posted July 30, 2024 Report Posted July 30, 2024 Not sure I quite understand what you are after. Are you looking for a banjo which you can screw that pipe into the end of, and which will then be bolted down to the engine with a 5/8" banjo bolt (and copper/dowty washers) you already have? If so you will need to identify what type of thread you have on the nut on that pipe. If this is a British engine with imperial threads it could be 1/4" UNF, or 1/8" bsp.
Split Pin Posted July 30, 2024 Report Posted July 30, 2024 There is a banjo on the other end of the pipe. That is what he is looking for so that he can make up a new pipe
dmr Posted July 30, 2024 Report Posted July 30, 2024 I needed a banjo a couple of years ago and they are not that easy to find. There are a few on eBay and these mostly have a BSP thread so there is no need to solder, just make up a pipe with suitable unions at both ends.
stablemabel Posted July 31, 2024 Report Posted July 31, 2024 Have you tried Walsh Engineering theyre in Irlam near Manchester.They do a lot of Gardener stuff
