6 minutes ago, PeterScott said:
Was asked how to do this...
  and the original post looked like this:
This is how to do it on a PC-browser. Someone else can explain what happens on a phone 🙂
First, Insert the picture into the new-post screen as ususal:
Then double-click on the picture to bring up the amendment menu:
Two things to do here: Press the 'Left' or 'Right' on the Alignment option line. Then choose a new, smaller '(width)' under Size, having checked that the  'Keep original aspect ratio' is still ticked.  Note that only the '(width)' field is amendable and that after clicking in the blank-space the new '(height)'  will be calculated by the system - to give this screen ...
... and press the Update button, to give
continue as a normal post.
Brilliant, I never knew that menu was there or available!
Thank you!!
IMG_20240718_180436216.thumb.jpg.cad7ab70c9300e9e906c1c6f2fd4c22a.jpgon mobile double table the image after inserting it and the properties display then follow Peter's instructions above.
