Fitzcarraldo Posted July 18, 2024 Report Posted July 18, 2024 Hello there - I’m a complete novice to Narrowboat life and have an overplating issue. My insurer GJW agreed to insure me on the proviso that I get an out of water survey before they’ll insure me fully comp next year. It turns out the water line is coming in at 3.8mm, while everything else is securely over the 4mm threshold. I was wondering: is it possible to just overplate the waterline with a strip of steel to save costs? Any advice welcome. Thank you!
Alan de Enfield Posted July 18, 2024 Report Posted July 18, 2024 6 minutes ago, Fitzcarraldo said: I was wondering: is it possible to just overplate the waterline with a strip of steel to save costs? Any advice welcome. Thank you! Yes, but I'd suggest you dont just 'do the waterline' with a narrow strip of steel, you should do several inches both above and below the waterline - it won't cost much more as the labour cost will be pretty much the same -, just a small oncost for extra steel. Just be careful that you do not add too much weight to a small boat, or a boat with engine room vents as it can affect your safety. Bosts have sunk becuse of overplating weight. What sort / size / age of boat is it ?
Fitzcarraldo Posted July 18, 2024 Author Report Posted July 18, 2024 Thanks for your reply. It’s a small boat - 38 ft and built in 1982.
Arthur Marshall Posted July 18, 2024 Report Posted July 18, 2024 36 minutes ago, Alan de Enfield said: Yes, but I'd suggest you dont just 'do the waterline' with a narrow strip of steel, you should do several inches both above and below the waterline - it won't cost much more as the labour cost will be pretty much the same -, just a small oncost for extra steel. Just be careful that you do not add too much weight to a small boat, or a boat with engine room vents as it can affect your safety. Bosts have sunk becuse of overplating weight. What sort / size / age of boat is it ? Mines a small boat, 40ft, air cooled engine so big holes for ventilation, been overplated twice, now has three bottoms and two sides (well, four, I suppose, really) and shows no signs of sinking! I just took the ballast out. 1
Fitzcarraldo Posted July 18, 2024 Author Report Posted July 18, 2024 Thanks Arthur. My boat’s in the West Midlands - Wolverhampton way. Know of any reputable welders round this way?
BEngo Posted July 18, 2024 Report Posted July 18, 2024 Ask around at Wolverhampton Boat Club and the Hawne Basin moorers. There are possibilities at Autherley, Teddesley and Otherton but I don't know anything about them. There are yards on the Shroppie at the A5 bridge and Norbury too. N 1
Stroudwater1 Posted July 18, 2024 Report Posted July 18, 2024 It sounds like you’ve been very unfortunate to be .2mm out. An alternative could be to pit/ puddle weld where the losses are greatest. That will take it back to 4mm. Is the whole length 3.8mm or is it just in places? Pit welding lets metal back in then grind flat. Quite a few welders will do that for you. It could be worth asking Stretton boatyard on the Shropshire Union or Streethay boatyard on The Coventry who maybe well placed to advise. It seems to be the surveyors answer usually to over plate. It’s not always the best option. 2
Fitzcarraldo Posted July 18, 2024 Author Report Posted July 18, 2024 Great - thank you for that. I was hoping to avoid the huge outlay of a complete overplate - the engine went kaput on its first journey too, and I’m not holding out too much hope of a big payout, so another added expense. I don’t know about these things, so was hoping that an overplating of the waterline by itself would come in much cheaper than a complete overhaul.
Tonka Posted July 18, 2024 Report Posted July 18, 2024 What about Caggys Yard at Tipton Or Phil Jones at Hatherton 1
hider Posted July 18, 2024 Report Posted July 18, 2024 Overplating or even patching the waterline with a strip 6" wide will reduce the sale value of the boat a bit. Pit filling with weld won't but will get you insured. The alternative is to have 3rd party only insurance. Cheaper but be sure it covers recovery from sinking.
Fitzcarraldo Posted July 18, 2024 Author Report Posted July 18, 2024 Thank you - that sounds like the way to go. 16 minutes ago, Tonka said: What about Caggys Yard at Tipton Or Phil Jones at Hatherton Phil and Orph at Oxley on the case about the engine as it happens - they’ve been really helpful and kind.
Slim Posted July 18, 2024 Report Posted July 18, 2024 Pit welding is well within the ability of anyone with moderate DIY skills. All you need is a fairly cheap MIG or stick welder, a stool to sit on, 4.5" grinder, appropriate PPE and time. Prepared to bet you'll do a better job than a professional as you won't be working to a time. It's also incredibly therapeutic. 1
truckcab79 Posted July 18, 2024 Report Posted July 18, 2024 44 minutes ago, Slim said: Pit welding is well within the ability of anyone with moderate DIY skills. All you need is a fairly cheap MIG or stick welder, a stool to sit on, 4.5" grinder, appropriate PPE and time. Prepared to bet you'll do a better job than a professional as you won't be working to a time. It's also incredibly therapeutic. Absolutely this. Stick welding is very easy to learn and the cheap machines are generally brilliant these days. Try Rohr for a decent brand for very little money. I’ve got one that will happily stick and TIG. Worth every penny.
Fitzcarraldo Posted July 18, 2024 Author Report Posted July 18, 2024 Great stuff - thanks for all your help and advice - much appreciated!
David Mack Posted July 18, 2024 Report Posted July 18, 2024 1 hour ago, Slim said: Pit welding is well within the ability of anyone with moderate DIY skills. All you need is a fairly cheap MIG or stick welder, a stool to sit on, 4.5" grinder, appropriate PPE and time. Prepared to bet you'll do a better job than a professional as you won't be working to a time. It's also incredibly therapeutic. Which you will not have if the boat is in dry dock or on a slipway. So you need the boat craned out onto the hard where the liftout cost is more, but the per week cost staying there is less.
ditchcrawler Posted July 18, 2024 Report Posted July 18, 2024 No one has mentioned Martin Kedian who sometimes posts on here
Tonka Posted July 18, 2024 Report Posted July 18, 2024 22 minutes ago, ditchcrawler said: No one has mentioned Martin Kedian who sometimes posts on here He is nearer Napton then Wolverhampton
Redhawk106 Posted July 18, 2024 Report Posted July 18, 2024 (edited) From what I understand, you don't actually need to figure out what needs overplating, sure be informed, but the actual decision is written in your survey report by the surveyor who did the survey and measurements on your boat. The welder then goes by that, and the insurance will sign off as long as it was overplayed to the spec of the surveyor. Correct me if I'm wrong, I'm relatively new to boating too, but that's the process we went through. Our welder thought the size of overplating specified by the surveyor was OTT, but he said that's what he'll do because that's what the survey states. Edited July 18, 2024 by Redhawk106
ditchcrawler Posted July 18, 2024 Report Posted July 18, 2024 9 minutes ago, Tonka said: He is nearer Napton then Wolverhampton OK. I didn't know where he was based
Tonka Posted July 18, 2024 Report Posted July 18, 2024 8 minutes ago, ditchcrawler said: OK. I didn't know where he was based Well I am not 100% sure. I know he has done a lot in the Calcutt area
Bee Posted July 18, 2024 Report Posted July 18, 2024 2 hours ago, truckcab79 said: Absolutely this. Stick welding is very easy to learn and the cheap machines are generally brilliant these days. Try Rohr for a decent brand for very little money. I’ve got one that will happily stick and TIG. Worth every penny. I have an ancient Clarke stick welder, works fine but has virtually no resale value, if someone would like it then collect it from Ironbridge, OK for welding pits. Free but a donation for a charity would be nice. Have recently bought a mig
truckcab79 Posted July 18, 2024 Report Posted July 18, 2024 (edited) Very generous offer I have a Clarke 180amp mig also. Nice kit. Only takes marginally more to learn than stick. Massive in comparison to arc. Only pain is the cost / availability of gas if you’re not using regularly. I tend to use gasless more often than not for convenience though it’s nowhere near as nice to do. Once you can weld there’s no end to the stuff you can make and repair. Recently picked up a cheap plasma cutter for added fun too. 👍 Edited July 18, 2024 by truckcab79
Fitzcarraldo Posted July 19, 2024 Author Report Posted July 19, 2024 17 hours ago, Bee said: I have an ancient Clarke stick welder, works fine but has virtually no resale value, if someone would like it then collect it from Ironbridge, OK for welding pits. Free but a donation for a charity would be nice. Have recently bought a mig That’s a very generous offer and thank you - happy to donate to a charity of your choice. I’m not too far from Ironbridge, so could pick up whenever convenient for you. Many thanks, Dougal
dmr Posted July 19, 2024 Report Posted July 19, 2024 16 hours ago, truckcab79 said: Very generous offer I have a Clarke 180amp mig also. Nice kit. Only takes marginally more to learn than stick. Massive in comparison to arc. Only pain is the cost / availability of gas if you’re not using regularly. I tend to use gasless more often than not for convenience though it’s nowhere near as nice to do. Once you can weld there’s no end to the stuff you can make and repair. Recently picked up a cheap plasma cutter for added fun too. 👍 Interesting comment, I thought the concensus was that stick is harder to learn than MIG. I was originally taught to gas weld, then moved on to MIG. Recently I have been teaching myself to stick weld and am only just starting to get some neat and tidy welds after quite a few hours.
