Indoor wood treatment
Hi big boat brain - the wooden window casings inside my boat are looking a bit worse for wear. Can anyone recommend process & products to get em lookin lovely again? Seems like they want stain & oiling rather than varnish?
Unfortunately  water stains like your picture tend to be permanent.
The best you can do is probably a gentle sand along the grain with 240 grit then 400 grit, followed by some teak or danish oil.
N
I would double check and do your research but, it's a problem I'm contemplating on a sailboat I have - how to protect the wood. Varnishing seems to be one of the least resistant, and requires regular maintenance. Oils maybe the answer, but It also requires frequent attention. Some use an epoxy resin to first be absorbed, then varnish for visual aesthetics.
Oxalic acid can be used to remove or reduce staining. A product called the Barkeepers Friend, sold at Dunhelms, contains oxalic acid. Or, it could be obtained via Amazon. Anyway, I'm still mulling over these options.
I have varnished the tiller handle in Schooner. An outdoor varnish. Don't know how it will hold up. Already put on 5 primary coats. Not finished.
Edited by Higgs
Step 1 ) Ensure the water leak (source of water) around the windows has been fixed.
Or, whatever you do to the wood you will be doing again fairly quickly
Easier said than done, with condensation, and with no double-glazed windows. I'd be inclined to use epoxy on the lower areas of wood at the window. The wood will be able to resist the moister better.
I have used Ronseal shed and fence treatment.Water based and in various colours, it goes on easily and although a matt finish, it doesn't look too bad.It's also very durable.
I am not so bothered about looks, I prefer practicality.
5 hours ago, Lady M said:
If you use varnish, please make sure it is NOT water based.  You should be able to tell this from the brush cleaning instructions.  DAMHIK
Interested to hear what happened to you as I stopped using yacht varnish on my exterior wood several years ago and changed to Ronseal 10 year woodstain. Its water based, but performs as well if not better in this application, although I'd give it 5 years rather than 10. Its much easier to use and... wash brushes in water. :)
7 minutes ago, Sue68 said:
I used cooking oil on our interior wood. Cheap and always available.
Sue
On purpose or are you reaping the benefits of being a messy cook? :D
Sadolin is the best treatment , its a stain and a varnish, but not high gloss, you would have to treat the damaged areas first until you near the colour.
Is it possible to remove and replace?
The corner piece cou,d be replaced
Edited by LadyG
The issue you have is that without removal you’ll always have the underside bare and exposed to moisture. Chances of it having been varnished on all sides before fitting are remote.
Ideally you want to take it out, sand it back and then epoxy it on all sides to seal and then your varnish of choice and then refit.   A lot of work but anything else is just treating the visible bits and the water will just creep back underneath.  Will work for a while though.
Sue
Can’t knock it if it works for you but cooking oil doesn’t dry so it’ll just sit there and attract dirt so not really suitable for this application.
Plenty of drying oils available for this purpose.  Osmo generally best of the bunch, but Danish oil, Tung Oil annd others are all readily available.
And they do a clearcoat .  Have to be honest I’m not keen on their colours as they are all a bit muddy looking. Neither paint nor stain. Good for covering up old damaged wood as a quick cosmetic fix though and very long-lasting.
What do you mean by outdoor varnish exactly? Polyurethane varnish is resistant to moisture but it hates UV light which breaks the polymer chains in the varnish. If you're using varnish around windows or anywhere else subject to UV exposure it should be yacht varnish.
Polyurethane varnish may either be water based or solvent based but neither are suitable because of its susceptibility to UV light.
I used Sadolin on the exterior hardwood window frames of a house once and it did look very good. The frames all needed sanding down to get the varnish off first. I don't know how well the Sadolin lasted.
Whatever you use you'll need to sand the frames first.
Schooner can be used indoors. Schooner does give UV protection. And, apparently, it's hardwearing. Suitable for yacht environments. Ticks quite a few boxes.
Schooner Yacht Varnish | International (international-yachtpaint.com)
Edited by Higgs
2 minutes ago, blackrose said:
That's because it a yacht varnish
A good choice. It's being used on a yacht. But specifically, for an outside purpose.
I have some garden gates made of iroko. When supplied they were treated with Osmo Oil and I was advised to recoat them annually. It failed within a year! I carried on with this for 3 years before giving up on Osmo Oil.
I have since treated them with Sikkens Cetol HLS woodstain followed by Sikkens Cetol Filter 7. Four  years on they are as good as the day I painted them
I have since used it on my deckboard with similar results.
Edited by cuthound
Spilchucker interference
I am about to do the same as cuthound on Katy Louise, I have given up on varnish, it doesn't last a year. You have to touch it up as soon as you see any sign of failing, then rub it all back and re-coat it every year. Life is too short. Cetol HLS and filter7, used on yachts, lasts around four to five years easily. The only drawback is that it doesn't have the same gloss as varnish, but it is a small price to pay to get your life back.
They say there are yachts to look at and admire, and for someone else to own.  Super yachts have paid crew who spend their lives skivvying for them.
That seems a bit OTT to me. I recently took out all my 19 year old portholes and the interior oak linings as one of the portholes had started to leak. None of the wood had been treated with anything on the inside and it was butted right up to the steel. Apart from the porthole that was leaking (the lining of which was rotting and only just salvageable), the rest of the wooden linings were all fine - water stained on the backs of course but other than that no problem. I painted the backs of the wood with some primer before putting them back in but epoxying wood on all sides seems only a step away from fitting plastic linings instead of wood! Epoxy is a thermoset polymer after all.
I worked on a 120 year old 91ft Thames steam launch for a couple of years with a lot of varnished areas, especially around the perimiter of the teak deck and wooden bulkhead. We used to use hot air guns and scrapers to remove any failing varnish before reapplying it every year. But we only removed the failing patches, feathered the edges and then re-varnished. It is a pain. Fortunately on most canal boats the exposed varnished areas are fairly limited.
It’s massively over the top and likely most would never do it but it’s probably the only way to (almost) guarantee no water ingress
Osmo would probably tell you it was the wrong oil for iroko, or it was too wet etc etc but to be honest I’ve used Osmo for years and never had an issue even though I’ve frequently ignored their recommended usage specs. I find it generally very forgiving.
That said I use Sikkens Cetol more and more and it’s all round pretty unbeatable.  Great coverage. Easy to apply. Great depth of colour, quick drying and easy clean up.  👍
