Has anyone got any experience of hydraulic drives? I need one for my John Deere JD3 due to alignment issues and not wanting to go down the route of prop shafts and universal joints.  Any advice would be greatly appreciated?
@ditchcrawler has one on a BD3 which was the Beta model before JD3
We have a hydraulic drive on a Kelvin J2. It was installed in around 2003 and is the original assembly. We have owned it for 3yrs and so far no particular issues. The system was supplied complete by ARS who are still in business and I have found to be both knowledgeable and helpful. There is a definite sound from the motor but not excessive. Two points that spring to mind. Firstly, ours is a swash plate (variable displacement) type which is an excellent option if more expensive. It gives you infinitely variable control on the pump pressure which means that the system does not have to be perfectly matched at all points - just set end stops for maximum forward and reverse pressure. Secondly, the pump and motor on ours are way oversized for the engine - this does not cause any problem but according to ARS means we should have a very long lifetime out of it. We changed the oil and filter this winter for the first time - checking the filter for bits of metal (none found) and checking the rubber hoses for signs of bulging are all that is needed by way of routine maintenance - and were pleasantly surprised at how cheap the oil is. We switched from 32 to 46 oil on the recommendation of ARS and it has given us slightly better power transfer on long runs at high speed. Another advantage, having an engine in an engine room forward of the back cabin, is full floor to ceiling height throughout.
Overall, I'm not sure that I would buy a system if I didn't need to, but I do rather like having it there.
Alec
This is great information thank you very much. I am really going to have to go down the hydraulic route unless I cut all my engine beds out and change them as my old lister used to have a dropper reduction on the gearbox. I have sent a email to ARS and am waiting for a response, so we shall see.
ARS is not the same company it was when I did mine, They were based about 15 miles from me in Norfolk but sold out and retired. Mine has been in use since 2002. ARS supplied the motor, the pump came from a refuse lorry. Mine is fixed ratio not adjustable that suites me. On big up side is when you get a log of wood in the prop the relief valve just lifts, no damage. I use speed wheel engine control and push /pull gear change. The main reason for the installation was full height in the back cabin.
I assume that any hydraulic pump that works at the same pressure as the motor and can take the RPM would work it doesn’t need to be a specific one for a boat ?
Correct. A constant displacement type such as ditchcrawler has needs to be reasonably matched to the power of the engine whereas a variable displacement type does not. The pump on ours would stall the engine at full displacement - it is rated for 60hp and we only have a 22hp engine.
RPM can be a problem with vintage engines but I don't think you will have an issue there.
In case it isn't clear - protection by the relief valve is true of pretty much all types and designs of hydraulic system.
We also have rod and wheel control - I will at some point make that wheel and wheel as it will be easier to take advantage of the variable pump setting and is correct for a Kelvin.
Alec
Interesting question............a bent axis ,or variable reversing axial piston pump or motor will cost up to $10,000 from the likes of Sunstrand Daikin,Rexroth ,or Linde .........from what I can see the same unit from China will cost in the 100s ..........you can triple that after freight and taxes ,but its still in the hundreds........anyone for a Chinese system?..................Im looking into a hydraulic drive mulcher/mower  to fit on my new excavator and it may be any kind of drive that transmits the power ......gear ,vane,roller stator ,bent axis ,variable axial piston ,or whatever .
No need for a hole in the hull with hydrostatic drive ............the unit can be configured to be a heavy outboard style ,and include a hydraulic lift to clear the prop above water.............I made a number of these in the 1980s for work barges ............the hydraulics in those days were good ole Joe Lucas .........back in the day before KGB operatives in the unions destroyed the company.
11 hours ago, ditchcrawler said:
 One big up side is when you get a log of wood in the prop the relief valve just lifts, no damage.
Not always the case.  I’ve had an ARS variable drive for over 25 years, giving excellent service.  In all that time it the relief valve only once failed to operate;  the resultant damage cost over £1500 to repair.
An ARS trained engineer came to check the system but couldn’t find any reason for the failure.
Thats the catch with hydrostatic drives ............you need a fully equipped test facility to isolate whats gone wrong................the other catch is if a component fails and contaminates the oil with metal ,the whole system is wrecked .
That's precisely what the engineer had. He still couldn't explain the relief valve failure.  Needless to say it worked perfectly when he tested it!
The tests showed that after more than twenty years' use, the hydraulic pressure was exactly as it was when new.
Some of the test equipment.
I have a hydraulic drive with voac/parker pumps/motors and it works very well however I imagine to buy such a system now would be very expensive although you can pick up the pumps on ebay quite cheap if you are prepared to wait. They are very efficient and as you have said allows the engine to be placed anywhere. Mine is under the front deck so you can hardly hear the engine when boating. Why don't you use a PRM drop box. An oversize one such as a PRM601 would probably give you about the right drop. Cutting the beds about with an angle grinder isn't that difficult and even if you can't weld you could get someone in to do this.
I have considered cutting the beds out and lowering the engine as I am a certified welder but there are a few issues such as the engine would need to be lifted out again and it means removing the roof to do so. I have down some pricing and there is not much between the systems by the time I have purchased a drive plate, gearbox and aqua drive plus the cost of removing the engine and time welding beds in. It’s Parker hydraulics that I have been looking at they seem the best for the money.
I made up a lifting frame inside the boat out of scaffold tube and key clamps so you can lift the engine clear and its always useful if you need to change the engine mounts etc. What is on the back of the JD now? They are SAE flywheels/housing. I had to make up my own drive plate. JD did marinise their own engines but tick over is about 800rpm and Beta tried to run them slower but that caused problems so you might be going too fast in a narrowboat at tickover with a JD3 so a variable swash plate motor may be better than a fixed bent axis one to give you better control at low speed.
Currently it just has an exposed flywheel there are a series of bolts that I plan on making an end plate to bolt the hydraulic drive too. I can get a drive plate made to any spline so I will just need to take measurements off the spline on the pump, all sound simple but very rarely is.
I have had to make several alternations to the engine to try and get it to work in a boat as beta did.
59 minutes ago, ditchcrawler said:
Saw this today on the Peak Forest canal done by Stow Hill a few years back originally called Anne
Originally paired with William, the butty was a real butty then, only when separated, the drive was added.
Remember them well, always seemed a strange combination as the butty looked like a motor with a butty stern
Catch with outside of  hull hydrostatic drives is a burst hose can land you in loads of hot water .......i built some of these 40 years ago ,and even then a big oil slick would land you in trouble if anyone ratted you out to the H&M ......no EPA in those days.
Also.......be very aware of the danger of any hydraulic leak ,and the danger of hydraulic fluid penetrating the skin and tissue,causing extensive damage,and even death.
  • 10 months later...
An old post I know but just seen it.
ARS/Parker hydraulic drive with bow thruster here, driven by a big old plodding Perkins. I should imagine it would be eye wateringly expensive to kit out now but I love it, very smooth and controllable, right down to a crawl and more than enough grunt to do the Ribble Link and still leave new narrowboats for dead (albeit with a bit of a smoke haze astern....)
I keep the oil and filter clean and just use it, boats don't do many hours compared to what the pumps are built for- constant industrial use.
Make sure you stick a big strong magnet somewhere in the tank below the oil return to catch any bits of steel.
From an environmental/pollution point of view I have slowly replaced all hoses with way over spec (I think 500 bar versus 300 bar as I remember) to negate the fact that we don't change the hoses as often as the makers recommend. Only slightly more expensive and made up at my local hydraulic shop. I have also only run hoses in places where an immediate burst would only spill oil inside the boat. I did re- route the bow thruster hoses as they ran above the well deck, potentially spilling straight overboard through the scuppers. I am also considering changing the oil for biodegradable oil in case of a spill.
Another useful safety point- I have installed an automatic fire extinguisher in the engine space- a burst hose at 200 bar spraying oil straight onto the engine manifold would be a bit of a fire risk to say the least.
Hydraulic hoses normally fail from thing that wont occurr in a boat.......flexing,chafing,fail of the rubber jacket from sun exposure .........once the rubber cracks,the steel braid is exposed to rust ,and the hose bursts without steel reinforcement.............You can also get bio degradable fluid ,which is manadated for excavators etc working on waterways.................I recall one repair job,I had let go a small  spill of fluid while replacing a hose on a council job.......a council inspector came up to me and said 'I assume that is an approved fluid ".......Of course ,says I .......We both knew it wasnt ,but the head contractor had 'fixed up'' the council to avoid problems on the job.
