Tracy D'arth Posted May 19, 2023 Report Share Posted May 19, 2023 I need new pump belts for Jabsco Par 36000 / 36950 water pumps. My spares list says 30022-0000 but the original belt is 35223-0000. Which is correct? There is another number on the belt, 1146 20. The 30022 are a fantastic price from Xylem Jabscoshop and I can't find another supplier. 55 teeth, 280mm length, 9mm wide but it will take a slightly wider belt. Any one able to help please? Link to comment Share on other sites More sharing options...
rusty69 Posted May 19, 2023 Report Share Posted May 19, 2023 (edited) Quote The Jabsco 30022-0000 belt is for Jabsco 36600, 36680 and 36950 series traditional par pressure pumps, including: 36600-0000, 36600-0010, 36600-0020, 36600-0031, 36680-2000, 36680-2010, 36680-2020, 36950-2000, 36950-2010 and 36950-2020. The pressure pump belt measures 279mm (11") long by 9.5mm (3/8") wide and replaces Jabsco 35223-0000. https://shop.chastheboat.co.uk/products/jabsco-30022-0000-belt-for-pressure-pumps-asjab-30022-0000 https://www.mackengineering.co.uk/30022-0000-jabsco-belt.html https://www.asap-supplies.com/products/jabsco-30022-0000-belt-for-pressure-pumps-jab-30022-0000 https://www.sparesmarine.co.uk/webshop/pumps/jabsco-36950-series/jabsco-36950-1000-was-6950j-water-pump/jabsco-30022-0000-belt/ Edited May 19, 2023 by rusty69 Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 19, 2023 Author Report Share Posted May 19, 2023 Great thanks for that rusty, 2 have no stock. Crazy price for a standard engineering item. It seems that the number has been superseded. I have tried the usual bearing and belt suppliers without success. Link to comment Share on other sites More sharing options...
BEngo Posted May 19, 2023 Report Share Posted May 19, 2023 Not quite sure of the exact belt tooth form and description, but have you had a look at the HPC gears C23 catalogue?. Lots of toothed belts there. I assume that what you want will have one of the standard tooth pitches and profiles. 280 divides by 55 to give a very nearly 5mm tooth pitch, which is a standard pitch. HPC offer the BT5/275, which has a *pitch* length of 275, (which will be near an outside length of 280,) and 55 teeth, various widths available, inc 10mm. Or the reduced backlash timing belt. AT5/280. 56 teeth on that one and available 10mm wide. N Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 19, 2023 Author Report Share Posted May 19, 2023 13 minutes ago, BEngo said: BT5/275 Fabulous info, thank. But they too are out of stock. No one keeps stocks of much anymore. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 19, 2023 Author Report Share Posted May 19, 2023 The tooth form looks to be semi-circular rather than trapezoidal, I am wondering if it will matter. Paying £36+ for a small rubber belt is ludicrous. Link to comment Share on other sites More sharing options...
rusty69 Posted May 19, 2023 Report Share Posted May 19, 2023 8 minutes ago, Tracy D'arth said: Paying £36+ for a small rubber belt is ludicrous. It does, especially as they are about $10 across the pond. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 19, 2023 Author Report Share Posted May 19, 2023 35 minutes ago, rusty69 said: It does, especially as they are about $10 across the pond. £9 plus £11 odd postage etc. £25.39 on ebay from the USA. Hopefully no duty or daft handling charges on top. There must be a UK source at a sensible price. I don't believe that is specially made for just this pump. Link to comment Share on other sites More sharing options...
rusty69 Posted May 19, 2023 Report Share Posted May 19, 2023 How about summit like this: https://uk.rs-online.com/web/p/timing-belts/4749462 or a dyson drive belt? 1 Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 19, 2023 Author Report Share Posted May 19, 2023 15 minutes ago, rusty69 said: How about summit like this: https://uk.rs-online.com/web/p/timing-belts/4749462 or a dyson drive belt? Brilliant, thank you very much. Ordered, job done £3 and a bit each, sensible. Dyson belts are a bit stretchy, different construction. There are geniuses on this forum. Link to comment Share on other sites More sharing options...
rusty69 Posted May 19, 2023 Report Share Posted May 19, 2023 Just now, Tracy D'arth said: Brilliant, thank you very much. Ordered, job done £3 and a bit each, sensible. Dyson belts are a bit stretchy, different construction. There are geniuses on this forum. Well, I dunno if its job done tbh. It will be incredible if the profile does line up, but probably worth a punt for 3 quid. Good luck Link to comment Share on other sites More sharing options...
rusty69 Posted May 27, 2023 Report Share Posted May 27, 2023 On 19/05/2023 at 21:21, Tracy D'arth said: Brilliant, thank you very much. Ordered, job done £3 and a bit each, sensible. Dyson belts are a bit stretchy, different construction. There are geniuses on this forum. Did it fit then, or was it 3 quid wasted? Link to comment Share on other sites More sharing options...
Tracy D'arth Posted May 27, 2023 Author Report Share Posted May 27, 2023 1 hour ago, rusty69 said: Did it fit then, or was it 3 quid wasted? Well, ordered Friday 19th May on 24 hour delivery. Not arrived by 24th. they were coming from France by UPS. Told RS. They shipped some more from Germany. Arrived 25th. Yes they fitted perfectly, right size and profile. Upgraded all my PAR pumps and have spares for the future. Then I get a demand for payment by email, I had already paid on order! Someone at RS has lost the plot. 1 Link to comment Share on other sites More sharing options...
