EnglishRose Posted May 1, 2023 Report Share Posted May 1, 2023 Our doors are looking a bit worse for wear with flaking paint although they are still solid. They are red and I'd like to change the colour (or even just strip them back and varnish them), whichever is likely to last longer. Any suggesting of paint or materials I should look at for longevity? Thanks so much. Link to comment Share on other sites More sharing options...
blackrose Posted May 1, 2023 Report Share Posted May 1, 2023 (edited) The basic process is primer, undercoat, top coats - at least a couple of coats of each. If you're just sanding down the existing paint and you don't go through to the metal or wood then you don't need primer. But the base prep must be good. You can't paint over flaking paint. Choose good quality paint as it's more flexible than the cheap stuff and will cope with thermal expansion & contraction. I like Hemple/Blake's primer/undercoat. For your topcoats you can use household gloss if you choose a good hard-wearing exterior brand. Or buy marine paint at 3 times the price. If you want a really good finish you should be rubbing down between coats. If you don't really care too much just get subsequent coats on within 3 days for maximum adhesion (single part paints). Edited May 1, 2023 by blackrose 1 Link to comment Share on other sites More sharing options...
EnglishRose Posted May 1, 2023 Author Report Share Posted May 1, 2023 18 minutes ago, blackrose said: can use household gloss if you choose a good hard-wearing exterior brand Thank you for your detailed reply. I guessed marine paint is expensive - any particular brand of gloss you'd recommend? Link to comment Share on other sites More sharing options...
BEngo Posted May 1, 2023 Report Share Posted May 1, 2023 Rylards, Craftmaster, Symphony, Tekaloid, Johnstones, Dulux Weathershield, Dacrylate for starters.. It all depends on how shiny you want. For varnish either Epifanes with UV filter or Le Tonkinois. Ronseal exterior yacht varnish at a push. Whatever, if it says anything other than High or Very High VOC on the tin, or cleans up with water, you don't want it. N 1 Link to comment Share on other sites More sharing options...
EnglishRose Posted May 1, 2023 Author Report Share Posted May 1, 2023 My dad has lots of tractor/car paint in his garage (although Ford tractor blue is probably the most common)! It's a very high gloss. Would this be ok for the wooden doors, with a suitable primer/undercoat which he probably has too) once I've got all the flakiness off. Link to comment Share on other sites More sharing options...
BEngo Posted May 2, 2023 Report Share Posted May 2, 2023 Yes, in theory, but most car ans some tractor paint is meant to be sprayed. OK if you can find brushing retardant, though even that may not slow the drying enough to get a decent finish. If they are brushing paints they should be fine. N 1 Link to comment Share on other sites More sharing options...
Higgs Posted May 2, 2023 Report Share Posted May 2, 2023 My approach to painting or varnishing wood is to thin the first coat down. Mainly to help with absorption. When varnishing and usually also when painting wood, stay with the grain. 1 Link to comment Share on other sites More sharing options...
