Oil dipstick level / engine manual
Hi could anyone point me in the right direction please on this dipstick where should the oil level be up to please ? - see photo  - looks like I’ve overfilled it a little
Engine is on our narrowboat, make is Nanni 4 110KC -  it been able to find a manual for this anywhere, would anyone have one by any chance please
Thansk
Bottom horizontal line is "empty" (needs filling)
Top Horizontal line (above the "1")  is the "Full" line.
I would have guessed the same (but it is only a guess). It's bl**dy confusing. Much better to put the part number towards the top, well away from the oil level and leave two unambiguous lines across the business end.
Edited by David Mack
Cheers David i thought the same all the number where what confused me - never thought part nimbler ! Thanks
Thats a very old engine, possibly a Kubota V12** (V = 4 cylinder, 12 = appox 1200 cc, **= engine series). I think the engine might be a V1202, long since replaced by the  current 05 series engine. You'll find it stamped into the engine casting.
HE = Heat exchanger.
KC = Keel cooler.
Just a different exhaust manifold an extra pump and a bit of plumbing.
https://www.peachment.co.uk/discontinued/4-110h-4-110he/
The main issue regarding servicing is the oil filter, with the 02 series engine using a 3/4" UN thread and the 05 series engine using a M20 thread.
Typical engine number locations for Kubota engines.
https://global.engine.kubota.co.jp/en/support/serialnumber/index.html
Edited by Eeyore
KC = Keel cooler.
Thanks yes it’s 30 years old, will check out the links cheers
