Extreme Canals - north south east west
Good question.
How about Longwood Junction to Sharpness via Horseley Fields and Aldersley Junction?
Or go the other way at Aldersley and head to Ellesmere Port.
Assuming we count the Severn above Gloucester as non-tidal (which it can be if you pick the right day) then I guess it may be longer to turn left at Horseley Fields, follow the Wolverhampton level to Spon Lane, cut back down Spon Lane locks, turn left at Bromford and head to Kings Norton then via the Startford and Avon to Tewkesbury and onward to Sharpness.
I'm going to have to consult CanalPlan.
You can get from Longwood to Poolstock bottom lock via the SU without going uphill. That's over 131 miles.
26 minutes ago, Tony Brooks said:
#One bit of that is semi-tidal, so may not count. If it does, then extend it to Sharpness
We've missed a critical point that @Loddon got. Glocester lock is uphill.
51 minutes ago, magnetman said:
Lechlade to Teddington?
It's further from Marston Doles to Teddington and at 138 miles it beats my suggestion of Longwood to Poolstock.
Edited by Captain Pegg
18 minutes ago, Captain Pegg said:
Good question.
Ellesmere Port locks down to the Manchester Ship Canal doesn't it?
I think Longwood Junction to Poolstock locks via the Middlewich Branch, T&M and Bridgewater works too (I should know this really, I'm on this route with only a couple of detours)
Top of Foxton to Marmount Priory lock on the Middle Level?
I think (without checking) that Longwood to Stourport would be further if you went via Horseley Fields, Old Main Line to Smethwick, then New Main Line, Netherton Tunnel, Dudley and Stourbridge Canals.
11 hours ago, TheBiscuits said:
 Well it's certainly the most northern so far!
Having had geographic extremes and vertical extremes we may need to set temporal parameters too - is this too early? I also note the article refers to boats being dragged, which suggests the water may have been a lubricant on a boat slide rather than a navigation.
Tavistock Canal.
I was looking on a map and wondering if the Par Canal was even further south, may need OS grid references to confirm
Almost certainly, but I'm still doubtful the resulting journey would be longer than Marston Doles to Teddington or whatever the answer is, otherwise you wouldn't have to check 😉
4 minutes ago, magnetman said:
The royal military canal is quite far south east.
More compass points needed.
 There is a book, I can't recall the name, but the author travels to Birmingham from the sub cardinal points of the network. Sub cardinal being NW, NE, SE, SW
We can have a go at identifying them!
Only on spring tides it's not tidal on neaps
So yes Birmingham to Gloucester at the right time of the month.
Uphill from there
Edited by Loddon
I could allow Lechlade to Richmond Half Tide Barrier, providing you do the last section during the bottom half of the tidal cycle.
What size boat does this  need to be as you could start at Cricklade
I assumed a normal canal boat as there was mention of doing locks. You could take a canoe and carry it around locks.
To be fair it is sometimes possible to get quite a lot further than Lechlade. I went past Hannington bridge in a kayak many yars ago but more realistically I think @Loddon has been quite a long way past Inglesham in a 11ft6 wide barge...
But even a small cabin cruiser can get further then Lechlade
16 minutes ago, magpie patrick said:
Is Tewitfield north of Ripon? I haven't checked.
Kendal is definitely north of Ripon, but the canal to Kendal closed long before the Ribble Link opened
According to the signpost in Vines Park, Droitwich that lists the outlying points of the inland network Tewitfield is further north than Ripon.
7 minutes ago, Heartland said:
My Friend Steve has a poor opinion of the Dingwall Canal. We went to look at the Canal in 2007. He called it a river, but of course it is a man made waterway.
It is pretty much the canalised river Peffery, & I've just realised there are 2 more canals in mainland Scotland further north than Dingwall, the Rosehall Canal & Culmaily Canal.
I grounded a couple of hundred yards short of Hannington Bridge I was aiming to get under what I consider the navigable bridges on the Thames. We started at QE2 Bridge.
This was in July 2003 when there had been a lot of water about.
Edited by Loddon
Yes.  Ripon used to be the northernmost point on the connected system, but the Ribble Link made the Lancaster Canal technically connected.
The Lanky lot are still moaning about the sudden jump on their boat licence fees!
7 hours ago, magpie patrick said:
Par Canal
That's quite enough of that language on the forum 😁
Edited by TheBiscuits
Add a bit
