Adam1991 Posted February 28, 2023 Report Share Posted February 28, 2023 Hi, we’re looking at installing stove pipe for our stove atm. It seems that a lot of the single skin flue pipes are 1.2mm thick. Is this an ok thickness to install? I remember getting information somewhere that it it should be 3 to 4mm. thanks Link to comment Share on other sites More sharing options...
Tracy D'arth Posted February 28, 2023 Report Share Posted February 28, 2023 5 minutes ago, Adam Mc Gowan said: Hi, we’re looking at installing stove pipe for our stove atm. It seems that a lot of the single skin flue pipes are 1.2mm thick. Is this an ok thickness to install? I remember getting information somewhere that it it should be 3 to 4mm. thanks Unless that is stainless steel I would not. Link to comment Share on other sites More sharing options...
Adam1991 Posted February 28, 2023 Author Report Share Posted February 28, 2023 Hi Tracy, I can’t seem to find any online which are thicker than around that thickness. Any recommendations on where we could get a couple of lengths of the thicker stuff? Also do you think at that point to get it welded custom would work out around the same ? cheers! Link to comment Share on other sites More sharing options...
Jen-in-Wellies Posted February 28, 2023 Report Share Posted February 28, 2023 You don't say what diameter you want, but Midland Swindlers sell 1/8" (3.175mm) wall pipe for this in a choice of two diameters. https://www.midlandchandlers.co.uk/products/ag-flue-pipe-steel-4-1-2-o-d-x-1500mm-long-hf-404 https://www.midlandchandlers.co.uk/products/ag-flue-pipe-steel-4-o-d-x-1500mm-hf-401 Also worth trying steel stockholders locally, as will be cheaper. Go with thinner stainless for longer life and a shiny bling flue pipe. Link to comment Share on other sites More sharing options...
BEngo Posted February 28, 2023 Report Share Posted February 28, 2023 1.2 mm mild steel is not going to last long as a flue. A steel stockholder ( or even Parker Steel on line, but expensive) will have mild steel Circular hollow section (CHS to the trade) in 101 and 114.3 mm outside diameters in thicknesses up to 5 mm. Don't go too thick. Mild steel is heavy and your stove top has to some extent to support the pipe. Two metres of 5mm x114.3 CHS is about 30 kg. CHS comes in 6-7m lengths, but a stockholder will cut it into three 2 m lengths for a little money. A whole length should be about the same prices as the chandlers want for 1.5 m. If you happen to be near Somerset I have a couple of spare pieces in the workshop I would happily sell one of. It is about a day's work and a good handful of welding rods to make a double cranked, single skin, mild steel flue if you have the right kit. At London prices that can be expensive, but a cranked flue always looks better than a straight pipe that does not fit the collars properly because the ends have been cut off on the piss to get it to go in at all. N 1 Link to comment Share on other sites More sharing options...
Adam1991 Posted February 28, 2023 Author Report Share Posted February 28, 2023 Hi BEngo, thanks for the advice. We’ll try and get a quote from a steel stockholder. We’re currently waiting on a quote for a welded angled length. Thanks for your offer but we’re up in the midlands. Cheers for your time! Adam Link to comment Share on other sites More sharing options...
MtB Posted February 28, 2023 Report Share Posted February 28, 2023 (edited) 3 hours ago, Jen-in-Wellies said: You don't say what diameter you want, but Midland Swindlers sell 1/8" (3.175mm) wall pipe for this in a choice of two diameters. https://www.midlandchandlers.co.uk/products/ag-flue-pipe-steel-4-1-2-o-d-x-1500mm-long-hf-404 https://www.midlandchandlers.co.uk/products/ag-flue-pipe-steel-4-o-d-x-1500mm-hf-401 Also worth trying steel stockholders locally, as will be cheaper. Go with thinner stainless for longer life and a shiny bling flue pipe. This stuff rots through in about five years in my experience. Perforates around the top just below where it enters the roof collar. Edited February 28, 2023 by MtB Add the emphasis Link to comment Share on other sites More sharing options...
David Mack Posted February 28, 2023 Report Share Posted February 28, 2023 3 minutes ago, MtB said: This stuff rots through in about five years in my experience. Perforates around the top just below where it enters the roof collar. I don't think you can blame the supplier for that. Any mild steel will corrode through in time. All you can do is go thicker or stainless to put off the day. Link to comment Share on other sites More sharing options...
MtB Posted February 28, 2023 Report Share Posted February 28, 2023 3 minutes ago, David Mack said: I don't think you can blame the supplier for that. Any mild steel will corrode through in time. All you can do is go thicker or stainless to put off the day. Yes agreed, I wasn't meaning to suggest MC flue pipe was in any way defective, just that 3mm wall steel flue of which theirs is an example quoted in the previous post, is under-specified and rots through quite quickly. Link to comment Share on other sites More sharing options...
Jen-in-Wellies Posted February 28, 2023 Report Share Posted February 28, 2023 1 hour ago, MtB said: This stuff rots through in about five years in my experience. Perforates around the top just below where it enters the roof collar. That has been my experience too. The next one will probably be stainless steel. A choice of places to buy it as I moor not far from where the material was invented! Link to comment Share on other sites More sharing options...
Tracy D'arth Posted March 1, 2023 Report Share Posted March 1, 2023 If you go stainless and have it cranked be sure that the welder TIGs it and not with mild steel rods or you will have pieces in 2 to 3 years! Link to comment Share on other sites More sharing options...
rusty69 Posted March 1, 2023 Report Share Posted March 1, 2023 (edited) 17 hours ago, Jen-in-Wellies said: That has been my experience too. The next one will probably be stainless steel. A choice of places to buy it as I moor not far from where the material was invented! Yep, I'm going stainless after this winter. Our one is showing pinholes after only 3 years. I am convinced there was a batch of highly toxic smokeless last season that ate into all things metal. Thank fark for pop rivets. Don't tell my BSS inspector. Edited March 1, 2023 by rusty69 there, not their Link to comment Share on other sites More sharing options...
Jen-in-Wellies Posted March 1, 2023 Report Share Posted March 1, 2023 8 minutes ago, Tracy D'arth said: If you go stainless and have it cranked be sure that the welder TIGs it and not with mild steel rods or you will have pieces in 2 to 3 years! There are fewer people around who can weld stainless properly. Fortunately, the flue on my boat is straight. Link to comment Share on other sites More sharing options...
