Adam1991 Posted February 21, 2023 Report Share Posted February 21, 2023 Hi all, I have two sets of 12v cables that I can’t identify since I accidentally chopped the ends off with the identifying number. In the electrical cupboard the negatives are now wired up in the negative busbar and the positives are not yet connected to the control panel (loose) In the cabin the positive and negative ends in which I’ll connect the accessories are just in wagos. How can I identify which positive cable is which in the electrical cupboard? Link to comment Share on other sites More sharing options...
Tracy D'arth Posted February 21, 2023 Report Share Posted February 21, 2023 Meter the resistance when you short one to a negative, simple. Link to comment Share on other sites More sharing options...
Adam1991 Posted February 21, 2023 Author Report Share Posted February 21, 2023 Hi Tracy, how do you do this? I have a multimeter but the confusing part is where I connect the multimeter ends to since the negatives are already in bus bar Link to comment Share on other sites More sharing options...
Tracy D'arth Posted February 21, 2023 Report Share Posted February 21, 2023 22 minutes ago, Adam Mc Gowan said: Hi Tracy, how do you do this? I have a multimeter but the confusing part is where I connect the multimeter ends to since the negatives are already in bus bar Temporarily short one positive to the negative bus bar with a bit of wire. Go to the other end and with multimeter measure resistance, continuity, between both the positives ( one at a time) and a negative. One of them will be short circuit, the other open circuit. The short one is the one still connected to the negative bar at the other end. Link to comment Share on other sites More sharing options...
Adam1991 Posted February 21, 2023 Author Report Share Posted February 21, 2023 Hi Tracy, thank you! I’ll give this a go tomorrow. Link to comment Share on other sites More sharing options...
Onewheeler Posted February 22, 2023 Report Share Posted February 22, 2023 On 21/02/2023 at 12:24, Tracy D'arth said: Temporarily short one positive to the negative bus bar with a bit of wire. Go to the other end and with multimeter measure resistance, continuity, between both the positives ( one at a time) and a negative. One of them will be short circuit, the other open circuit. The short one is the one still connected to the negative bar at the other end. It might be a good idea to check that the wire you're about to connect to -ve hasn't any voltage on it! Just in case... Link to comment Share on other sites More sharing options...
