Which leisure battery?
jhodgski
Hiya,
I am looking to buy a new set of (4?) leisure batteries for my narrowboat. They will be used to power some small 12v appliances but also a 240v, 600W water distiller (via a 12v inverter, so 50A) that usually runs for about 4 hours (200Ah) every day. Charging the batteries will be 600W to 800W of solar panels (via an Epever 60A 6415AN MPPT charge controller).
Could you recommend any particular type or make/model of battery?
Many thanks,
James
Thanks but mains electric isn't an option.
The panels will generate more power than the distiller uses, so I expect the setup will be fine on sunny, or even moderate, summer days.
But it's advice on what would be the most appropriate type/model of battery for this scenario that I'm really looking for?
1 hour ago, jhodgski said:
Hiya,
Many thanks,
James
Taking your figures, along with the 'guide' to only discharge your batteries to a maximim of 50%
4 (typical 100Ah) batteries will give you a 'guide' of a total daily discharge of 400 x 50 % = 200Ah
You water maker uses (every day) 200Ah.
1) what other batteries do you have to run all your other 12v appliances, recharge phones, computers, TV etc etc  ?
The 4 batteries you plan to use will be killed within 'days'.
2) Do you really plan to rely solely on Solar ?  You will need to provide at least 250Ah per day just to recharge the water maker batteries. That'd probably be about 6+ hours of engine running per day (every day) I very much doubt you'd average 25Ah out of 600w of solar and in the 5 months (Oct, Nov, Dec Jan, Feb) probably a vey small fraction of that.
Your plans are not going to work.
Edited by Alan de Enfield
Agreed. From https://re.jrc.ec.europa.eu/pvg_tools/en/tools.html#api_5.2 assuming the only power source is 800W of solar panels with optimum tilt, and the only power use is the water maker:
Edited by IanD
35 minutes ago, Tracy D'arth said:
As I said, you will not recharge your batteries!  They will be scrap within days.
Why do you need a water distiller?
Maybe Cmers hidden away in a backwater and need to make their water to save having to 'come out and be seen'.
Or maybe it is a water distillation plant being put to an alternative use - I wonder if they are moored up near a barley field ?
2 hours ago, jhodgski said:
Hiya,
Many thanks,
James
I want to reinforce what others have told you and beg that you read and digest the battery primer referred to.
On the face of what you have posted, whatever type or make of lead acid battery you buy you are likely to destroy them in a few weeks or maybe a month or two, so buy the cheapest because you will be throwing them away soon. The abilities of LiFePo4 lithium MIGHT give you a better chance of keeping them charged but the price for batteries and the required charge controller equipment may well cost several £1000.
The fundamental problem is he simply hasn't got enough power to run the loads, he needs either a *lot* more solar (which will still not be enough in winter), to run the engine for long periods, buy a generator, or get rid of the water maker...
Edited by IanD
That sums it up, but will he believe us?
5 minutes ago, TheBiscuits said:
They only sell hearing aid batteries so no use for the boat ...
The hearing aid batteries stand about as much chance of coping with the load as new lead acid will.
Did you not want to hear that your solar would not cope?  To ask for advice is noble, to be in denial is foolish.
For water straight out of the canal ?
Not quite. I find these taps all over the place. I don't want to recoat the tank with bitumen again. Not quite sure with what to coat it with. I'm thinking epoxy, for potable water, but prepping the steel looks like a pita.
Useful.
You've suggested a battery capacity of 6000wh which equates to 500ah, which would be about 4 typical lead acid leisure batteries.  Perhaps the OP is wondering what would happen if they greatly increased the number of batteries, say up to 40 batteries.
Here's the answer:
It actually makes matters worse because there will be even fewer days when the batteries actually get a full charge.  So the batteries will get ruined even quicker.
Assuming 1 batteries costs about £100, that will be £4000 wasted.
So to answer the original question, there are no batteries which can be recommended.
3 hours ago, jhodgski said:
Hiya,
Many thanks,
James
What happened to the Generator you bought ?
(Is this still the wooden-top that you bought and had all the problems with - engine, toilet, cabin water leaks, replacing windows, injector pump, cylinder head replacement, leaking stern gland etc etc)
Did you girlfriend ever stay more than that one night when the wooden cabin leaked on her ?
