Looking for a wood burning eco designed stove second hand
Welcome!
Does your boat have a hearth and flue collar in the roof from a previous stove installation, or will this be the first time a stove is installed? There are important safety things you need to be aware of either way. Hearth materials, insulation, air gaps, distances to combustable materials etc. A good summary of best practice is here. The only bit I and some others find contentious is the use of double skinned flue pipes. Single skin is fine. Other than that, follow that guide.
28 minutes ago, Jen-in-Wellies said:
Welcome!
Read the guide.  Do lots of research until you have sufficient knowledge to ignore the guide. Then do a safe and sensible install.  If you follow the guide then always wear full fireman's gear and have a fire engine standing by when using the stove, for full safety.
 Share
