Midnight Posted September 24, 2022 Author Report Share Posted September 24, 2022 The last update from CRT was 1st August. The pounds appear to be full on both sides of the summit - why no update? Link to comment Share on other sites More sharing options...
LadyG Posted September 24, 2022 Report Share Posted September 24, 2022 (edited) On 19/09/2022 at 18:23, ditchcrawler said: Have you sorted your overstay notice yet Yes tx, breakdown in communication, or lack of..... Looking at the stoppages map, things seem to be getting worse day by day, I am confident I'll be out of here by the end of the month, just not sure which month! Edited September 24, 2022 by LadyG Link to comment Share on other sites More sharing options...
Midnight Posted October 7, 2022 Author Report Share Posted October 7, 2022 At a meeting last week CRT said despite all pounds being full the HNC will remain closed while reservoirs are low. Considering they only allow 2 boats in each direction per week, and the tunnel pound is like a reservoir, that seems like they don't give a toot that some boaters are stuck trying to get back to base before the winter maintenance kicks in. 1 Link to comment Share on other sites More sharing options...
dmr Posted October 11, 2022 Report Share Posted October 11, 2022 Rochdale Update (maybe I should start a new thread is this is an HNC thread 😀 ) The CRT team has fixed the hole in the aqueduct at lock 35. The water is back in to the two pounds below the summit and lots of water is flowing down from the summit. The summit pound is pretty much full. CRT tidied up the site today, taking away all the bags of silt etc etc, though the safety fences are still in place and locks 33 and 36 still have padlocks on them. I here a rumour that a boat moved up from Todmorden over the weekend and had some problems due to the large amount of water overtopping some of the gates. There are a lot of boats waiting down in Littleborough so when CRT open the canal I assume they will have to escort these over the summit in small groups over a couple of days. If CRT don't open the Rochdale, at least to supervised passages, then all the water flowing down will go to waste. 1 Link to comment Share on other sites More sharing options...
Fender151 Posted October 12, 2022 Report Share Posted October 12, 2022 The HNC currently has significant CRT maintenance work in progress at lock 26, just above Slaithwaite, it looks like replacement of gates, or work on the lock walls, they also have a dredger and a work boat on site. The water levels are looking good at Spath Reservoir and the pounds up to Marden, for the first time in a few months. I haven't seen any boats moving on the HNC for a while, I walk this stretch of the canal several times a week, feel free to PM me if anybody would like an update. 1 Link to comment Share on other sites More sharing options...
dmr Posted October 12, 2022 Report Share Posted October 12, 2022 I might be wrong about the Rochdale, CRT escorted two boats over the summit this morning as they have urgent needs to move. They reported quite low water levels on the Littleborough flight. So lots of water on the Yorkshire side but still possible problems on the Manchester side. Link to comment Share on other sites More sharing options...
jake_crew Posted October 12, 2022 Report Share Posted October 12, 2022 Fender 151 - can you advise of progress on this conversion, on the bank below lock 39E HNC. A few weeks ago it looked like this. Link to comment Share on other sites More sharing options...
Midnight Posted October 12, 2022 Author Report Share Posted October 12, 2022 Open fron Friday 21st October Link to comment Share on other sites More sharing options...
Jon57 Posted October 12, 2022 Report Share Posted October 12, 2022 10 minutes ago, Midnight said: Open fron Friday 21st October Only on the dark side 😁 Link to comment Share on other sites More sharing options...
dmr Posted October 12, 2022 Report Share Posted October 12, 2022 The low pounds that I mentioned earlier were down to CRT, they had dropped the level to do a bit of leakage investigation. CRT are putting quite a bit of effort into the Rochdale. If its the only Penine crossing open then I expect its going to be like a motorway soon, we might even see more than one boat every day. Link to comment Share on other sites More sharing options...
David Mack Posted October 13, 2022 Report Share Posted October 13, 2022 21 hours ago, dmr said: The low pounds that I mentioned earlier were down to CRT, they had dropped the level to do a bit of leakage investigation. CRT are putting quite a bit of effort into the Rochdale. If its the only Penine crossing open then I expect its going to be like a motorway soon, we might even see more than one boat every day. From Monday the Rochdale will be open from Lock 7-34 and 45-92. Passage over the summit is also available for prebooked passages only on Mondays and Fridays. Locks 1-7 remain closed for leak repairs between locks 3 and 4. https://canalrivertrust.org.uk/notices/22796-navigation-closure-lock-1-to-lock-48-rochdale-canal Link to comment Share on other sites More sharing options...
dmr Posted October 13, 2022 Report Share Posted October 13, 2022 54 minutes ago, David Mack said: From Monday the Rochdale will be open from Lock 7-34 and 45-92. Passage over the summit is also available for prebooked passages only on Mondays and Fridays. Locks 1-7 remain closed for leak repairs between locks 3 and 4. https://canalrivertrust.org.uk/notices/22796-navigation-closure-lock-1-to-lock-48-rochdale-canal Ye, that email arrive whilst I was writing the post above 😀 With the aqueduct (culvert) repaired it will be interesting to see if the 35-36 pound now stays in water. My feeling is that the old long term leak was not huge and that the leakage through lock 35 is the more significant water loss. Its looking good at present, I have just walked past it. Link to comment Share on other sites More sharing options...
David Mack Posted October 13, 2022 Report Share Posted October 13, 2022 3 hours ago, David Mack said: Locks 1-7 remain closed for leak repairs between locks 3 and 4. That should be "bridges 3 and 4", which are on the pound between lock 3/4 (Tuel Lane) and lock 5. Locks 5 and 6 are very close together so it makes sense to close up to lock 6, but why is lock 7 closed? Link to comment Share on other sites More sharing options...
droshky Posted October 20, 2022 Report Share Posted October 20, 2022 On 12/10/2022 at 15:42, Jon57 said: Only on the dark side 😁 And only for 10 days Link to comment Share on other sites More sharing options...
JemShaun Posted February 24, 2023 Report Share Posted February 24, 2023 Just had a walk and a natter with the contractors on the HNC at Slaithwaite who have been working om the canal bank wall. They say it is due to open officially at the end of March, however with the current work rate it maybe a week to 10 days early Link to comment Share on other sites More sharing options...
Hudds Lad Posted February 24, 2023 Report Share Posted February 24, 2023 13 minutes ago, JemShaun said: Just had a walk and a natter with the contractors on the HNC at Slaithwaite who have been working om the canal bank wall. They say it is due to open officially at the end of March, however with the current work rate it maybe a week to 10 days early Are they sticking any mooring rings atop the new extended wash wall? I've always thought it a crying shame there was no mooring there with easy access to the bakery and brewery. Link to comment Share on other sites More sharing options...
IanD Posted February 24, 2023 Report Share Posted February 24, 2023 1 minute ago, Hudds Lad said: Are they sticking any mooring rings atop the new extended wash wall? I've always thought it a crying shame there was no mooring there with easy access to the bakery and brewery. Is that the bit below the guillotine lock where The Handmade Bakery is? Used to be really difficult to get into the wall there due to depth... Best home-made baked beans on toast I've ever had though... 🙂 Link to comment Share on other sites More sharing options...
JemShaun Posted February 24, 2023 Report Share Posted February 24, 2023 10 minutes ago, Hudds Lad said: Are they sticking any mooring rings atop the new extended wash wall? I've always thought it a crying shame there was no mooring there with easy access to the bakery and brewery. Both the guys i spoke too gave different reply's. The coloured guy was adamant they were. The bakery is amazing, that's where I was heading. Never tried the brewery bottle shop yet, but I will. off into Marsden later for a beer or 2 in my favourite Pub Link to comment Share on other sites More sharing options...
IanD Posted February 24, 2023 Report Share Posted February 24, 2023 (edited) 2 minutes ago, JemShaun said: Both the guys i spoke too gave different reply's. The coloured guy was adamant they were. The bakery is amazing, that's where I was heading. Never tried the brewery bottle shop yet, but I will. off into Marsden later for a beer or 2 in my favourite Pub Very nice beer from the brewery -- if it looks closed knock on the door, they'll probably let you in if anyone's there. I went and stocked up on beer there while daughter's BF wound the lock gates up and down -- 160 turns each way, I seem to remember him telling me cheerfully... 😉 Edited February 24, 2023 by IanD Link to comment Share on other sites More sharing options...
JemShaun Posted February 24, 2023 Report Share Posted February 24, 2023 4 minutes ago, IanD said: Very nice beer from the brewery -- if it looks closed knock on the door, they'll probably let you in if anyone's there. I went and stocked up on beer there while daughter's BF wound the lock gates up and down -- 160 turns each way, I seem to remember him telling me cheerfully... 😉 will keep that in mind.......thank you 😁 1 Link to comment Share on other sites More sharing options...
JemShaun Posted February 24, 2023 Report Share Posted February 24, 2023 21 minutes ago, IanD said: Is that the bit below the guillotine lock where The Handmade Bakery is? Used to be really difficult to get into the wall there due to depth... Best home-made baked beans on toast I've ever had though... 🙂 Sorry Ian, yes exactly there fella. Missed this post at first Link to comment Share on other sites More sharing options...
IanD Posted February 24, 2023 Report Share Posted February 24, 2023 (edited) 8 minutes ago, JemShaun said: Sorry Ian, yes exactly there fella. Missed this post at first I recommend you have a late breakfast or lunch there, mmm... 🙂 Edited February 24, 2023 by IanD Link to comment Share on other sites More sharing options...
JemShaun Posted February 24, 2023 Report Share Posted February 24, 2023 4 minutes ago, IanD said: I recommend you have a late breakfast or lunch there, mmm... 🙂 Always buy my Sour dough from there, it's amazing. Link to comment Share on other sites More sharing options...
beerbeerbeerbeerbeer Posted February 24, 2023 Report Share Posted February 24, 2023 37 minutes ago, Hudds Lad said: Are they sticking any mooring rings atop the new extended wash wall? I've always thought it a crying shame there was no mooring there with easy access to the bakery and brewery. Have you spotted the mooring above the other lock? where a Cafè boat used to be? There’s also a water tap there. Unless it’s now gone. Link to comment Share on other sites More sharing options...
peterboat Posted February 24, 2023 Report Share Posted February 24, 2023 22 minutes ago, JemShaun said: will keep that in mind.......thank you 😁 Remember it well twice takes such a long time to wind it up Link to comment Share on other sites More sharing options...
