Lochwarden Posted September 6, 2022 Report Share Posted September 6, 2022 Hello all, new on here. Seems very informative, and looking forward to receiving advice and hopefully giving advice! I’ve just changed the fuel pipe from the lift pump to the fuel filter as it was weeping fuel from a tiny crack in the pipe near the lift pump union. What I need to know is do I just need open the bleed screw on the top of the filter housing to bleed the air out of the new pipe, using the lift pump, or is there more bleeding involved? Thanks, john. Sorry, it’s a 1.5 BMC. Link to comment Share on other sites More sharing options...
matty40s Posted September 6, 2022 Report Share Posted September 6, 2022 Being a BMC, you will probably need to crack every injector as well. Make sure your starter battery is well charged. If you have an injector pump, there may well be at least one , more likely 2 bleed valves on this as well. Link to comment Share on other sites More sharing options...
Tony Brooks Posted September 6, 2022 Report Share Posted September 6, 2022 39 minutes ago, Lochwarden said: Hello all, new on here. Seems very informative, and looking forward to receiving advice and hopefully giving advice! I’ve just changed the fuel pipe from the lift pump to the fuel filter as it was weeping fuel from a tiny crack in the pipe near the lift pump union. What I need to know is do I just need open the bleed screw on the top of the filter housing to bleed the air out of the new pipe, using the lift pump, or is there more bleeding involved? Thanks, john. Sorry, it’s a 1.5 BMC. If you are lucky and keep bleeding for at east 30 seconds after you think that you have got rod of all the air it might work. If it does not work then move to the small hexagon bleed screw in the cylindrical part of the injector pump, observe the at last 30 seconds more thing. Then loosen all the large nuts on the injector unions about one turn. Spin the engine on the starter until fuel drips or spits from each nut. Tighten and it should start. If not repeat. 1 Link to comment Share on other sites More sharing options...
