Colin Brendan Posted July 23, 2022 Report Share Posted July 23, 2022 (edited) Hi. My exhaust stack vanished from the roof - so need a new one. Needs to be 3.5inch Id which seems hard to find on google. Any recommendations on where to get one? I've tried Little Chimney Company and Michael Pinnock - they don't/no longer do exhaust stacks. Any other recommendations greatly appreciated. Thanks Edited July 23, 2022 by Colin Brendan Link to comment Share on other sites More sharing options...
MtB Posted July 23, 2022 Report Share Posted July 23, 2022 I think Simon Wain at Brinklow might make you one. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted July 23, 2022 Report Share Posted July 23, 2022 It will surely be a custom made item to fit the exhaust stub on the roof? Link to comment Share on other sites More sharing options...
Tonka Posted July 23, 2022 Report Share Posted July 23, 2022 2 hours ago, Colin Brendan said: Hi. My exhaust stack vanished from the roof - so need a new one. Needs to be 3.5inch Id which seems hard to find on google. Any recommendations on where to get one? I've tried Little Chimney Company and Michael Pinnock - they don't/no longer do exhaust stacks. Any other recommendations greatly appreciated. Thanks Would the little chimney company not make you one Link to comment Share on other sites More sharing options...
frangar Posted July 23, 2022 Report Share Posted July 23, 2022 Have you looked to see if a steel tube stockholder does something of a suitable size then maybe fit some brass strip etc for a cutter or if you want some bling? Both my stacks are pipe section rather than rolled sheet. Link to comment Share on other sites More sharing options...
Colin Brendan Posted July 23, 2022 Author Report Share Posted July 23, 2022 2 hours ago, Tonka said: Would the little chimney company not make you one Fraid not. I get the impression they are tied up with chimney orders 1 hour ago, frangar said: Have you looked to see if a steel tube stockholder does something of a suitable size then maybe fit some brass strip etc for a cutter or if you want some bling? Both my stacks are pipe section rather than rolled sheet. Thanks Frangar - might go down this route While I'm at it - does anyone have opinions on those flippy rain hats on a spring that you don't have to take on and off? Link to comment Share on other sites More sharing options...
David Mack Posted July 23, 2022 Report Share Posted July 23, 2022 I made my own roof exhaust short pipe by buying a length of thin wall 4" stainless tubing off ebay, slit it down its length with a thin cutting disc on the angle grinder, put big jubilee clips on each end to pull it in to the required diameter, then drilled and pop rivetted through the overlap. Pop riveted some brass strip around the top too (with copper pop rivets). Link to comment Share on other sites More sharing options...
alan_fincher Posted July 23, 2022 Report Share Posted July 23, 2022 1 hour ago, frangar said: Have you looked to see if a steel tube stockholder does something of a suitable size then maybe fit some brass strip etc for a cutter or if you want some bling? Both my stacks are pipe section rather than rolled sheet. Just bear in mind that an exhaust made from solid steel pipe, rather than a much thinner steel rolled and riveted, will be far less unforgiving if it manages to catch on a low bridge or tunnel. With the rolled item, it will likely bend, meaning no damage to the outlet or boat. With the much more solid item, however... 😬 (Please don't ask me how I know this!) Link to comment Share on other sites More sharing options...
frangar Posted July 23, 2022 Report Share Posted July 23, 2022 (edited) 3 minutes ago, alan_fincher said: Just bear in mind that an exhaust made from solid steel pipe, rather than a much thinner steel rolled and riveted, will be far less unforgiving if it manages to catch on a low bridge or tunnel. With the rolled item, it will likely bend, meaning no damage to the outlet or boat. With the much more solid item, however... 😬 (Please don't ask me how I know this!) Hence why I run with a short pipe most of the time....I do see some boats with pipes so tall I wonder how they get through a bridgehole!...I know some dont like the fumes in the face but I quite like the smell of diesel exhaust....and you get a lovely sound off solid pipe! Edited to add When I did catch my tall pipe once on a bridge hole it just rolled off the collar....but it fits outside the collar rather than inside...did take me a while with a magnet to get it back though...another advantage over Stainless! Edited July 23, 2022 by frangar Link to comment Share on other sites More sharing options...
