Multifuel stove with oven and hotplate
Hello,
If anyone has any recommendations for a multifuel stove that has both a small oven and a hot plate for bunging a cast iron pot on i would be ever so grateful.
I'm at a bit of a loss, I've found a couple but neither is floating my boat. No apologies for the pun.  😛
5KW plus, for a rather long narrow boat.
Cheers.
Hiya,
Thank you for the replies,
for clarification I'd like a glass windowed fire, cast iron door oven and a flat steel / cast iron top plate.
I'm just about to start googling your replies, It's been a long day, I'm hungry, but thank you so much for your replies.
11 hours ago, David Mack said:
If you think that's horribly expensive, then you shouldn't look at the Halibut.
And that would before you factor in currency exchange charges and import duty from the US
On second thoughts having checked out the link to the 'Bubble 1 Pie Pod' (you what?), perhaps the Salamander isn't *that* bad.
Edited by Sir Percy
