commervan Posted June 29, 2022 Report Share Posted June 29, 2022 Hi please can anyone help. We have a paguro 4000 cocoond built in generator in our narrowboat which has developed another water leak this I have traced to the exhaust manifold area which has a water jacket rapped around the manifold down pipe. This again has cracked on one of the joints and leaking antifreeze. I keep getting it soldered up but the vibrations set it off again. I was wondering what purpose it serves and could I bypass it. Water comes in at the top and excites and the bottom so maybe I could just use a pipe to join them together. The water comes from a skin tank which it shares with the main boat engine so is cooled that way. It was mentioned it could be an out let to heat water for the boat. Please has anyone got any ideas. Michael. Link to comment Share on other sites More sharing options...
BEngo Posted June 29, 2022 Report Share Posted June 29, 2022 Nothing immediately disastrous is likely to happen if you bypass the exhaust manifold cooling. The manifold itself will get a lot hotter than usual, and the solder from the repairs you mention may melt and run out. You may need to insulate the manifold to make it safe and comply with the BSS. Consult the BSS guide carefully. The exhaust gasses will be a bit hotter, so have more energy and the exhaust may be different-sounding or louder as a result. You should not block either the water inlet or the outlet to ensure there is no chance of any trapped water in the manifold flashing into steam and causing problems. If you can take some pictures of the problem area we may be able to suggest some repair techniques which will last better. Though, if soft solder has been used it will be difficult to successfully apply alternative techniques like brazing or welding. What are the manifold and cooling jacket made of? You could no doubt use the jacket to heat water for the boat, but you will need to fix the leak first. ☹ You will then need a quite complicated set up to circulate antifreeze through the jacket and then into a calorifier or heat exchanger to get hot water. You will need a header tank for this circuit, and a pump.The heat output is likely to be very small so any usable quantity of hot water will take ages, and not be very warm. It would be easier to circulate the generator coolant via calorifier en route to the skin tank. Thenyou should get a reasonable quantity of hot water, but you might need an extra pump. N Link to comment Share on other sites More sharing options...
Slim Posted June 29, 2022 Report Share Posted June 29, 2022 (edited) 1 hour ago, commervan said: Hi please can anyone help. We have a paguro 4000 cocoond built in generator in our narrowboat which has developed another water leak this I have traced to the exhaust manifold area which has a water jacket rapped around the manifold down pipe. This again has cracked on one of the joints and leaking antifreeze. I keep getting it soldered up but the vibrations set it off again. I was wondering what purpose it serves and could I bypass it. Water comes in at the top and excites and the bottom so maybe I could just use a pipe to join them together. The water comes from a skin tank which it shares with the main boat engine so is cooled that way. It was mentioned it could be an out let to heat water for the boat. Please has anyone got any ideas. Michael. I have the same generator but mine is raw water cooled. I'm struggling to see how they differ, must check out the manual. Advance Yacht Systems phone no 01794 523900 seem to be the importers. They are very helpful. The person to ask for is Rod (assuming he's still there) I've got the manual that covers it. Faymann engine, VTE alternator. the raw water cooled version. Edited June 29, 2022 by Slim Link to comment Share on other sites More sharing options...
Tracy D'arth Posted June 29, 2022 Report Share Posted June 29, 2022 Can it be re-enforced when it is soldered together? If you are soldering, presumably its brass or copper? Picture? Link to comment Share on other sites More sharing options...
commervan Posted June 30, 2022 Author Report Share Posted June 30, 2022 Many thanks for all your replays. I am trying to upload pictures but without success (Looks like I will have to wait for the grandson again 😁). Yes it's in a copper pipe shield this doesn't look factory to me as it's just standard copper pipe so may have been previously repaired by first owner me been the third. Unfortunately their is little room to strengthen the area that leeks as it's very tight against the casing. I will give advanced yacht systems a ring. Cheers for your answers much appreciated. Link to comment Share on other sites More sharing options...
blackrose Posted June 30, 2022 Report Share Posted June 30, 2022 Have you considered ordering a new manifold instead of soldering up the cracks? It must be water cooled for a reason? I looked at Paguro generators at a place in Southamptonb about 15 years ago. I think they have water cooled alternators too which surprised me at the time but perhaps that's a standard feature. Link to comment Share on other sites More sharing options...
commervan Posted June 30, 2022 Author Report Share Posted June 30, 2022 Yes but they have changed engines since ours was made. And the place in Southampton advanced yacht systems only have new ones for the modern engine at around £400. Sometimes they get second hand parts in for the older engine. So I could give them a ring you never know. Thanks Link to comment Share on other sites More sharing options...
blackrose Posted June 30, 2022 Report Share Posted June 30, 2022 Yes it costs nothing to ask if the older part is available. I'd be surprised if it wasn't, but of course it might be expensive. Link to comment Share on other sites More sharing options...
Steve56 Posted July 1, 2022 Report Share Posted July 1, 2022 On 29/06/2022 at 23:35, commervan said: Hi please can anyone help. We have a paguro 4000 cocoond built in generator in our narrowboat which has developed another water leak this I have traced to the exhaust manifold area which has a water jacket rapped around the manifold down pipe. This again has cracked on one of the joints and leaking antifreeze. I keep getting it soldered up but the vibrations set it off again. I was wondering what purpose it serves and could I bypass it. Water comes in at the top and excites and the bottom so maybe I could just use a pipe to join them together. The water comes from a skin tank which it shares with the main boat engine so is cooled that way. It was mentioned it could be an out let to heat water for the boat. Please has anyone got any ideas. Michael. The reason for the water jacket is probably to stop the engine overheating. As you say it is a cocooned set so you need to get that heat away. Without the water jacket that exhaust will give off a lot of heat. If you decide to bypass this water jacket then at a minimum you could lag the exhaust with a good few layers of lagging to try and keep the heat level down. Link to comment Share on other sites More sharing options...
commervan Posted July 1, 2022 Author Report Share Posted July 1, 2022 Thanks certainly will if I go down that route. Link to comment Share on other sites More sharing options...
