How to fix a leaky boat
GUMPY
It's very good, two part epoxy putty. Ok on the steel hull below the water line because the temperature there is kept more or less uniform. Viagra is really only good for preventing you from rolling out of bed.
  • Haha 2
Could be nasty too with all the shopping trolleys and low water levels.....
I've heard that Viagra is also used in the burns unit of hospitals to keep the bedclothes off burnt legs...
It can also be ground up and the resulting powder mixed with distilled water to create a solution, a few drops in each eye is perfect for when you need to give something a long, hard looking at...
