MyWayMatt Posted January 27, 2022 Report Share Posted January 27, 2022 Hello there!! Can you travel from Lancashire to Heartfordshire on a wide beam boat? Not sure if the whole way is wide enough in regards to locks. thanks matt Link to comment Share on other sites More sharing options...
mrsmelly Posted January 27, 2022 Report Share Posted January 27, 2022 Not Inland. Link to comment Share on other sites More sharing options...
David Mack Posted January 27, 2022 Report Share Posted January 27, 2022 Only by sea or on the back of a truck. Link to comment Share on other sites More sharing options...
MtB Posted January 27, 2022 Report Share Posted January 27, 2022 37 minutes ago, MyWayMatt said: Hello there!! Can you travel from Lancashire to Heartfordshire on a wide beam boat? Not sure if the whole way is wide enough in regards to locks. thanks matt No reason not to do it with a lorry. (The locks are only 7ft wide at the chicane.) Prolly cost you about £2k, including the crane lifts at each end. Link to comment Share on other sites More sharing options...
Stroudwater1 Posted January 27, 2022 Report Share Posted January 27, 2022 If you are looking to restore and need work doing by anyone else you will find it a lot cheaper generally to get the work done in the North, so might be best to factor that bit in too? Link to comment Share on other sites More sharing options...
blackrose Posted January 28, 2022 Report Share Posted January 28, 2022 (edited) 15 hours ago, MtB said: No reason not to do it with a lorry. (The locks are only 7ft wide at the chicane.) Prolly cost you about £2k, including the crane lifts at each end. Probably more like £4K these days. I had my widebeam lifted out, transported by road and put back in 6 years ago and that was more than £3K in total. That was the absolute cheapest price I could get from a transport broker. I had other quotes of over £5K direct including one from Tuckeys. This assumes you have to hire a 100T crane at either end as most boatyard cranes won't be able to lift more than about 20 tonnes. Edited January 28, 2022 by blackrose Link to comment Share on other sites More sharing options...
