Sneill Posted November 28, 2021 Report Share Posted November 28, 2021 (edited) Hi guys asking for a mate he’s just bought a trad narrow boat which has a lily king connected to one rad and a calorifier. he’s struggling to achieve a good heat( both water and cabin temp without going thru loads of coal ?) is there a technique to these burners that he is unaware of ? thanks in advance Edited November 28, 2021 by Sneill Link to comment Share on other sites More sharing options...
Bod Posted November 28, 2021 Report Share Posted November 28, 2021 Wood burner, using coal. Wood needs no bottom air to burn, coal needs bottom air, so unless he has a grate that will allow bottom air, then the Lily King will be very inefficient. Bod 2 Link to comment Share on other sites More sharing options...
Jen-in-Wellies Posted November 28, 2021 Report Share Posted November 28, 2021 They seem to be multi-fuel, so should run on coal. If he is starting from a cold boat, then the calorifier may be the problem. If I leave the boat for a few days in winter, then light the fire, then it takes hours for the calorifier to heat up. While it is doing so, it seems to suck almost all the heat from the fire. If possible, keep the stove in and ticking over all the time while on the boat. This keeps not only the cauliflower, but the rest of the boat at a reasonable temperature and is easier to bring up to a higher temperature with a bit more stoking. Other than that, bottom air for coal as @Bod said. I find a combination of top and bottom air works well, but biased to bottom, through the grate. Jen Link to comment Share on other sites More sharing options...
MtB Posted November 28, 2021 Report Share Posted November 28, 2021 7 hours ago, Sneill said: he’s struggling to achieve a good heat( both water and cabin temp without going thru loads of coal ?) Well in my hovel on the bank I struggle to achieve a good heat without burning much fuel too! When I lived aboard I used to burn 2 bags a week of good quality solid fuel (not cheapo 'house coal'). If I was heating water with it too, I'd expect three bags a week. How much solid fuel does your mate consider to be 'loads of coal'? Link to comment Share on other sites More sharing options...
